查看: 36|回复: 0
FHDD PC-USB Terminal5 双端口终端适配器 [复制链接]
发表于 5 天前 |只看该作者 |倒序浏览
FHDD PC-USB Terminal5 双端口终端适配器,可同时读/2个硬盘ROM
传输速率可达6000000,性价比高,花一份钱等于购买了2com终端.
支持3.3V,2.5V,1.8V电压自动调整
通过PC-USB-Terminal-5适配器的可编程开关 支持自动将SSD固态硬盘切换到安全模式并返回功能。
FHDD PC-USB Terminal5 2FHDD ADP COM多种硬盘COM端口
每个FHDD ADP COM集成WD 3.5/WD2.5 SATA(FUJ MHV)/WD2.5 USB/
SEAGATE 3.5/SEAGATE 2.5/FUJ MHT/SAMSUNG 2.5/TOSHIBA 2.5/
FHDD PC-USB Terminal5 Dual-Port Terminal Adapter
The FHDD PC-USB Terminal5 dual-port terminal adapter enables simultaneous reading and writing of ROM data from two hard drives.
It delivers a transmission speed up to 6,000,000, offering outstanding cost performance — you get the functionality of two COM terminals for the price of one.
It supports automatic voltage adjustment among 3.3V, 2.5V and 1.8V.
Equipped with programmable switches on the PC-USB-Terminal-5 adapter, it features automatic SSD safe mode switching and recovery functions.
The FHDD PC-USB Terminal5 comes with two sets of FHDD ADP COM boards compatible with various hard drive COM interfaces.
Each FHDD ADP COM integrates interfaces for:
WD 3.5” / WD 2.5” SATA (FUJ MHV) / WD 2.5” USB /
Seagate 3.5” / Seagate 2.5” / FUJ MHT / Samsung 2.5” / Toshiba 2.5”
GMT+8, 2026-7-12 11:23 , Processed in 0.097172 second(s), 15 queries .
