查看: 3880|回复: 0
PC-3000 Portable III 温度说明 [复制链接]
发表于 2024-6-14 23:22:19 |只看该作者 |倒序浏览
有些客户反馈 ACE Lab PC-3000 Portable III内部CPU过热,并试图使用第三方风扇冷却内部处理器。
请注意:Portable III设备不存在高温问题。该工具设计为在主处理器单元温度为60C的情况下全天候工作。
当温度升高超过60C时,内部Portable III风扇开始旋转。如果温度变高,风扇会旋转得更快。
如果温度保持在60C以下,风扇会自动关闭。如果温度高于90C,Portable III将显示过热错误消息。
但由于正常使用,温度不可能高于65-67C度!如果您的温度高于这些值,
那么您的Portable III存在风扇旋转或灰尘问题。
Portable PRO将具有相同的温度场景,因此60C是该设备的默认温度,Portable III也是如此。
some of customers  said ACE Lab that PC-3000 Portable III has too hot CPU inside and trying to cold down internal processor using some third-party FANs.
PLEASE NOTE THAT: there is no problem with high temperature with Portable III device.
This tool was design to work 24/7 with 60C temperature of the Main Processor Unit.
Internal Portable III FAN start to rotate when the temperature rise more than 60C. It rotates faster,
if temperature become High. If temperature is kept lower than 60C, the FAN is switched off automatically.
If temperature is higher than 90C, Portable III will show an error message for overheating.
But due to the normal use, it's not possible to get the temperature even higher than 65-67C degree!
If you have temperature higher than these values, then your Portable III has a problem with FAN rotation or with the dust. Portable PRO will have the same temperature scenario, so 60C is a default temperature for this device, as well as in Portable III.
GMT+8, 2026-8-15 02:23 , Processed in 0.106447 second(s), 15 queries .
