查看: 6853|回复: 3
PC3000FLASH 新版本程序 7.0.5 已释放 [复制链接]
发表于 2016-12-8 23:59:46 |只看该作者 |倒序浏览
PC3000FLASH/PC3000Portable/PC3000UDMA-E /PC3000Express/PC3000SAS (同步更新)!
PC3000软件下载地址用户名和密码:(PC3000正式用户可以进入下载:英文版本)
2016年12月8日
新的PC-3000 Flash 软件版本 7.0.5 可以使用
PC-3000 Flash expands the scope of solutions for data recovery from NAND-based devices like Memory Sticks, SD cards, microSD, USB Flash drives and other devices. Alongside with the new adapters, a new software version has been released.
Here is the list of latest enhancements:
  • Introduced support for new sets of adapters:
  • Added a XOR map analysis tool for tasks on AU and SSS controllers. The tool enables you to solve tasks which have non-standard XOR applied on the basis of standard one.
  • Added a mode in compiler “Block Number SD/CF”, which allows to switch off add-on optimization. In other words, the mode does not sort all add-ons based on their relevance, but adds everything that is found during structure analysis.
  • Added methods of manual block rotation (page-by-page) in the “Block/Page Cutting” tool and implementation of the version into the translator. This is necessary to enable block rotation if it is in the translator version.
  • Optimized performance of the compiler “Block Number SM 3257” in relevant marker search mode.
  • Enhanced performance of the compiler “ITE 1167 translator”.
  • Completely rewritten the block rotation preparing tool for SD/CF Phison Controllers. Now TLC microchips with 32 sector page and sector merge cases for MLC memory are supported.
  • Added new XOR and ECC to the resource database.
PC-3000 Flash扩展了从基于NAND的设备(如MemoryStickSD卡,microSDUSB闪存驱动器和其他设备)恢复数据的解决方案。新的适配器和软件版本已经发布。
以下是最新增强功能:
支持新适配器套装:
新的PC-3000FLASH 多板适配器-Multiboard,包括可更换的焊接模块:Monolith模块,BGA-152 / VBGA-100模块,LGA-52 /TSOP-48模块。
PC-3000FLASH卡适配器-Card Adapter
AUSSS控制器上的任务添加了XOR映射分析工具。该工具使您能够解决在标准的任务基础上应用非标准XOR
在编译器“Block Number SD/CF”,中添加了一个模式,允许关闭优化。换句话说,该模式不会根据其相关性对所有加载项进行排序,但会添加在结构分析期间找到的所有内容。
“Block/Page Cutting”工具中添加了手动块旋转(逐页)方法,并将版本执行到翻译器中。如果在翻译器版本中启用块旋转,这是必要的方法。
在相关标记搜索模式下优化编译器“Block Number SM 3257”的性能。
增强了编译器性能“ITE 1167 translator”
完全重写了SD / CF Phison控制器的块旋转准备工具。现在支持用于MLC存储芯片的具有32个扇区页和扇区合并的TLC芯片。
数据库添加了新的XORECC
所有授权的正式用户可以下载PC-3000 Flash最新软件版本的安装文件。
请联系我们,了解如何成为授权的技术支持用户。
PC-3000技术支持专线:010-62681656.
找技术支持工程师 张工,庞工,朱工
周一至周五,早9:10-晚5:30周六日休息.
PC3000-Flash技术支持
1QQ:2244873427
2 QQ: 1297101924
PC3000UDMAE SAS EXPRESS SSD技术支持
手机:13126710536
1QQ:1271957638
2QQ: 1297101924
金牌会员
存储设备研发专员
    2016-12-18 14:51:16
  • 签到天数: 13 天
    发表于 2016-12-9 08:11:07 |只看该作者
    小板凳做起来,升级!
    2019-10-8 12:08:23
  • 签到天数: 71 天
    发表于 2016-12-9 09:21:51 |只看该作者
    张总12点还在发帖子 辛苦了
    2019-7-8 08:48:40
    发表于 2016-12-16 18:07:46 |只看该作者
    修正了不少704存在的BUG 顶一下
    一直用703终于可以升级啦
    美中不足的是有些功能对原始DUMP进行操作且不做说明,这样对一些新手来讲有些弊端。
    BLOCK NUMBER TYPE1 编译没有703精确,可能考虑因素更多吧
    还有一些问题不一一列举了。不过总体来讲PC3000最棒的FLASH数据恢复软件
    GMT+8, 2026-9-10 01:38 , Processed in 0.099022 second(s), 14 queries .
