查看: 7394|回复: 0
PC3000UDMAE/EXPRESS/SAS/SSD6.0版本新增功能 [复制链接]
发表于 2015-11-24 02:52:29 |只看该作者 |倒序浏览
完整版本下PDF文件下载地址:
http://pan.baidu.com/s/1eQz5aVo
简要介绍:
PC3000UDMA /UDMAE /EXPRESS/SAS /SSD 6.0.15新增功能简介
2015-11-24释放
10/16/2015 Uploaded release of version6.0.10
释放版本6.0.10
10/16/2015 hadrons the PC-3000
   - For all utilities madepermanent, automatic saving of the log and data terminal (to create a profileof HDD / SSD utility in the profile folder, then create a profile in theprofile data is transferred and, if necessary, are added to the stored there
对于所有的实用程序制成永久性的,自动保存日志和数据终端(在配置文件夹中创建的HDD/ SSD的资料,然后创建在描述文件数据的资料传送,如果必要,将被添加到存储)
16.10.2015 Toshiba
   - The mechanism ofgrouping of defects in the tracks.
自动组合磁道缺陷
16.10.2015 DataExtractor version 5.3.1build 3280
  DE 版本5.3
  - Fixed a bug in the parsingprevnesennaya subdirectories ExFat
修正解析 Exfat 子目录问题。
  - Fixed error in the analysisof HFS +. Invalid HardLink-processed and files (with a negative value as aresult)
修正分析HFS+错误,  处理无效的硬连接和文件(用一个负数结果)
  - Fixed a bug in the analysissections Ext. Tighten control Inode. Without this tightening analyzed"junk  修复分析扩展部分漏洞,缩小控制索引节点"
    data, resulting inslower and vnekotoryh cases in a significant increase in memory usage.
数据,随着内存的使用增加使用运算速度变慢
- Fixed a bug in the parsing LVM whendetermining the amount of segments修复分析LVM 判断片段数量漏洞
  - Added ability to display allversions of LVM segments 增加功能去展示所有LVM片段的版本
  - RAID Edition, to form a RAIDadds the ability to select a polynomial to calculate RS code
RAID 编辑  RAID模块 增加功能选择算法去计算RS 代码
07/10/2015 Uploaded release of version6.0.10 释放版本6.0.10
07.10.2015 Samsung 4.4.4.785
- Fixed "Out of memory"when recording downsize geometry script; 修正:当重写缩小的几何脚本修复“内存不足”
- Works on elimination of mistakes"List index out of bounds" when the function is called "fill thegaps" in the editor defects; 清除错误“索引列表超出范围” 当缺陷编辑器提示“填充空白”
- Fixed "List index out of bounds",which arises when you restart the combined test surface.
修复重新启动表面测试界面时出现的“索引列表超出范围”
02.10.2015 Seagate / Seagate F3
- Removed deadlock, occurs whenperdёgivanii supply during the process of working with the terminal
移除密码锁通过终端
02.10.2015 WD Caviar (SATA)
- Altered treatment S.M.A.R.T.
修改S.M.A.R.T .
30.09.2015 DataExtractor Version 5.3.1(Beta) build 3279
- Added scanning methods LVM metadatato disks and partitions with proper type;
- Raw recovery增加使用适当的类型扫描LVM元数据和 磁盘分区的方法
- Fixed bug when saving related to exposureinvalid characters in the name and directory fayov
修复当保存相关无效名称和目录的字符时发生的错误
- Added new LVM structure and methodsof construction of specialized maps
新增 LVM 结构和构建特定的位图的方法
- File System VMFS, fixed bugchecking header at the Root node for VMFS5
文件系统 VMFS 修复在VMFS5根节点检测数据头的漏洞
- The file system is NTFS,the implementation of the method "search patterns" added a new methodfor determining the start of the intended clustering
NTFS文件系统,方法执行“搜索模式”增加确定簇的开始位置的新方法
   section, which improvedthe quality of recovery in difficult cases.
提高复杂案例的恢复几率。
- The database structuresDaubal stuktury ApplePartitionScheme and HFS +  该数据库结构Daubal stuktury苹果分区SchemeHFS+
- Added a reaction topressing the "Pause" during the execution of the script whenprocessing the loss of availability or read errors
新增的功能在处理可用性丢失或读取错误执行脚本时可按下“暂停”
- Fixed a bug in theformation of the path for copying selected files into several sections with the"shoot to mark the saved"
修复在形成一个路径为了拷贝选定的文件到几个部分通过“标记保存”的漏洞
- Fixed problem ofinconsistency in the output status of the calculated and stored number of filesand their size.
解决输出状态下计算的和储存文件数量和大小不一致的问题
28.09.2015 Toshiba
   - The mechanism of hidingdefects  缺陷的隐藏的机制
24.09.2015 WDMarvell
   -"Searching for modules in SA" and "Edit Dir" redesignedmechanism Dir build on the results of the search / editing;
“在服务区搜索模块”和“编辑目录”重新设置搜索/编辑目录结果
   - In the"Search modules in SA" added the possibility to add the module fromthe list found in the Dir HDD.
- 在“搜索模块在服务区”中增加功能从列表添加模块在硬盘目录
24.09.2015 Samsung SSD 1.2.3.2800
   Changes for the familiesof 470 and 830:
   - Improvedalgorithms for constructing the translator;
改进算法建立翻译器
   - Improved existing andadded new loaders;
改进现有的和增加新的LDR
   - Added support for AppleSSD for these families.
增加对苹果SSD 家族系列的支持
   Changes to utilities ingeneral : 在通用模式下切换到实用模式
   - Added ability to selectthe type of loader manually; 增加功能可以手动选择LDR 类型
   - Substantially reducethe amount of the final dll due to optimization of storage;
大幅度降低链接数量,由于存储的优化;
   - In the "Utilitystatus" added information about the storage used in memory chips;
在实用程序状态中增加关于存储在内存芯片的信息
   - Changedselection window families. Now the family is selected by the firmware versionand controller type.
改变选择家族的窗口。现在的家族由选中的固件版本和控制器类型所决定。
22.09.2015 Samsung 4.4.4.780
   - Test "Workwith service area - Table broadcast areas" has been replaced with greatercapacity test "Utility extensions - Disable zones and heads";
- 测试“操作服务区区域表 broadcast"”已被替换成更大的容量测试“实用程序扩展 - 禁用区域和磁头”;
   - Added handlingof the situation when the table storage unit is on the first track of theservice area;
增加处理存储单元表在服务区第一磁道的情况
   - Added utility samsungactions when reading data through the Data Extractor;
-通过DE 读取数据 添加三星实用程序选项
   - Added handling of thesituation, when editing module PARAM_DM storage capacity has not changedbecause of the setpoint Max LBA module PROFILE;
增加处理编辑参数管理模块存储容量时没有随设定最大LBA值分布而改变的情况
   - It isautomatically directed to the DBG> and vice versa when reading the ROM,making the procedure more stable;
读取ROM的时候,使程序更加稳定自动定向到DBG> 模式
   - Added an alternativeparser zone allocation table for the family N3;
增加备用解析器区域分配表为了家族N3;
   - For theregime of "Finding donors," added the preservation of the reportaccording to the search;
对于“查找供体-备件盘,”根据搜索保存报告;
   - Fixed minor bugs. 修复镜像漏洞
09/09/2015 hadrons the PC-3000
   - For thePC-3000 SAS Fixed a bug due to which, after the HDD power read errorsencountered when running utilities passports.
- PC-3000 SAS修复漏洞,当硬盘运行实用程密钥时遇到错误。
09.09.2015 SCSI Tester
   -Fixed test reading the HDD file - the sector errors are not recorded.
修复测试读取硬盘文件 - 扇区的错误不被记录。
07.09.2015 WDMarvell
   - In the "Searchmodules in SA" preserving Dir as the file and write to RAM HDD
在“搜索模块在服务区”中保存目录为文件,并写入硬盘内存
04.09.2015 Seagate F3
   - Now that you have aniformatsii System Files utility loader from properly created and set to readthrough the terminal
系统文件程序加载器无法正确地创建并设置为由终端读取
   - The toolworks with objects SA to work with System Files adds the ability to work with apart of file - from Offset (bytes), the size Size (bytes)
服务区对象操作系统文件增加去操作-部分文件的功能 - 从偏移量(字节),尺寸大小(字节)
01.09.2015 Seagate F3
   - Added instument,allowing the group to hide the mini-storage areas (to cover the head inclusive)through the addition of NonResident G-List
添加菜单,允许该组通过添加非常驻的G表来隐藏微型存储区域(去覆盖包含的磁头)
08.25.2015 The core of PC-3000
   - Controllers to thePC-3000 Express and UDMA-E made additional optimization of read / writeoperations to UDMA. Increased read and write speeds (~ 5 Mb / s). Reduced haddanee within ~ 5 Mb / s dependence read / write speed of the CPU performance.
PC-3000 ExpressUDMA-E控制器的读/写操作额外优化UDMA。提高读取和写入速度(5 MB/秒)。降低了内5 Mb / s的依赖性读/CPU的性能的速率。
25.08.2015 WD Marvell
   - Added entry moduleslike statics 添加附加模块
   - In the "EditDir" preserving Dir as the file and write to RAM HDD
在“编辑目录”保留目录为文件,并写入到硬盘内存
   - Changedthe mechanism of "shift of the Regions"
改变“地址偏移”的机制
   - Improved mode"Viewing and editing resource HDD"
改进模式“查看和编辑硬盘资源”
GMT+8, 2026-7-26 23:55 , Processed in 0.092909 second(s), 13 queries .
