查看: 14935|回复: 3
PC3000 FLASH 最新版本7.0.2 已释放 [复制链接]
发表于 2015-8-3 21:25:16 |只看该作者 |倒序浏览
PC3000FLASH SSD  升级版本7.0.2
没过一年升级有效期内的用户免费升级.超过一年免费升级有效期的用户可以付费升级
升级流程:
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=4050
下载地址:
Not much time has passed since PC-3000 Flash software ver. 7.0.1 became available, and the ACE Lab Team is ready with one more new release.
PC-3000Flash版本 7.0.1刚释放不久,ACE实验室团队又准备推出新的版本。
In the latest version, the PC-3000 Flash users will get the new TOOLS, which automate the routine operations helping to save your time:
在最新的版本中,pc3000用户可以应用新的工具,这些新增的工具将自动执行一些常规的操作从而帮助客户节省时间
·        The "Copy/Paste ECC" tool enables you to transfer the already detected ECC from one result to another
复制/粘贴ECC 工具可以帮助你快速的把已发现的ECC 转换成另一种输出结果
·        The "View ECC Information" tool helps you to know the type of the defined ECC and its format for a particular result
查看ECC信息 工具可以帮助你去了解ECC的特殊类型和格式
·        The "Reread Map Generator" tool significantly decreases the time for rereading in case of a large number of bad sectors
Reread Map Generator  工具可以有效的减少重读大量坏扇区时间
·        The "Block Cutting" tool is a new visual mode for cutting unused blocks from an already built image
Block Cutting   可以从已经建立的镜像中去剪切未使用的模块
The newest PC-3000 Flash software gives you an opportunity to recover data from such models of Flash drives that were not supported earlier or could be recovered only to a small extent:
这个最新版本的PC3000FLASH 支持从FLASH 驱动器的型号 恢复数据,这在过去并不支持或只能恢复一小部分。
New translator algorithm in EXTENSIONS for "EV268" controller
新的编译运算法则为了  EV268 控制器
·        New translator algorithm in EXTENSIONS for "SM2685F" controller
·        新的编译运算法则为了  SM2685F 控制器
·        The translator algorithms for "ITE1167" and "SSS6677" have been significantly improved for working with partially damaged translator tables
·        ITE1167和SSS6677的编译运算法则可以更好的工作在编译表损坏的情况下
The PC-3000 Flash software ver. 7.0.2 makes it possible:
Pc3000FLASH版本有更多的功能
·        to search by mask in the GREP search
·        在GREP 搜索里去按 mask 搜索
·        to cut bad bytes in one click (using the CTRL + left mouse button)
·        一键剪切坏的字节(CTRL + 鼠标左键)
The PC-3000 Flash software ver. 7.0.2 also contains the following new functionality:
Pc3000还同时具有以下新功能
·        A lot of new ECC types 多种ECC类型
·        A lot of new XOR types 多种XOR类型
·        A lot of new ReadRetry types 多种 ReadRetry 类型
·        The improved way of searching XOR in the list of XORs
·        在XORS列表中更快的寻找到XOR
    2014-12-26 14:08:29
    发表于 2015-8-3 22:57:52 |只看该作者
    升级了N多实用功能啊,下载地址在什么地方啊
    2017-8-1 13:49:56
  • 签到天数: 37 天
    发表于 2015-8-4 16:06:37 |只看该作者
    下载地址: https://yadi.sk/d/yvzvPkHliBZh6
    2017-7-6 16:08:32
    发表于 2015-8-11 14:09:58 |只看该作者
    7.0.1刚升级 又来2
    GMT+8, 2026-7-12 13:35 , Processed in 0.096055 second(s), 12 queries .
