- 专业度
- 10059
- 元宝
- 114243
- 金钱
- 9999
- 最后登录
- 2026-9-8
- 注册时间
- 2011-7-19
- 精华
- 6
- 积分
- 145076
- 阅读权限
- 200
- 帖子
- 686
该用户从未签到 - 金钱
- 9999
- 元宝
- 114243
- 专业度
- 10059
PC3000FLASH SSD 升级版本7.0.1
没过一年升级有效期内的用户免费升级.超过一年免费升级有效期的用户可以付费升级
升级流程:
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=4050
The release of the new PC-3000 Flash software ver. 7.0.1The new software update for the PC-3000 Flash is available now.
WHAT'S NEW
- Explore the new opportunity to expand your PC-3000 Flash Reader functionality!
It has become possible to make a firmware update of the PC-3000 Flash Reader. Detailed manual is available in your Personal Update Box. - The new preparation method "Join by Dumps for N sources"
- In the "Page Designer" mode, you can select ranges of the same length by double click
- The support of the pages larger than 128Kb
- New types of ReadRetry options
- New types of ECC
- New types of XOR (SM325x, SM326x, SM268x, IS9xx, SSS669x, AU69xx, Sandisk, Kingston SD and others)
- New translator algorithm for SSS5523 controller
- New translator algorithm for some SanDisk controllers
- New translator algorithm for Innostor (IS902, IS903, IS916) controllers
- Updated dynamic XOR patterns for Phison controllers
- New weekly-updated automatic database with new XOR, ECC, and other resources
