查看: 53910|回复: 0
PC3000UDMA/UDMAE/Express/SSD/SAS/5.9版本升级详细内容 [复制链接]
发表于 2015-3-13 23:14:42 |只看该作者 |倒序浏览
PC3000Portable/PC3000UDMA/PC3000Express 新版本5.9.21
PC3000ExpressSetup.exe (55.40 Mb)
Published: Tue, 24 Feb 2015 20:26:35 +0400
Description: PC-3000 Express (5.9x) setup.exe
PC3000USBSetup.exe (55.44 Mb)
Published: Tue, 24 Feb 2015 20:32:34 +0400
Description: Installation setup file for PC-3000 Portable (5.9x)
PC3000SASSetup.exe (24.54 Mb)
Published: Thu, 12 Mar 2015 16:31:51 +0400
Description: Setup.exe file for PC-3000 SAS version 5.9x
PC3000UDMAESetup.exe (55.39 Mb)
Published: Tue, 24 Feb 2015 20:29:36 +0400
Description: PC-3000 UDMA-E 5.9x version installation setup.exe
PC3000UDMASetup.exe (47.39 Mb)
Published: Tue, 24 Feb 2015 20:27:27 +0400
Description: PC-3000 UDMA 5.9х version installation setup.exe
PC3000Portable/PC3000UDMA/PC3000UDMA-E /PC3000Express (同步更新)!
PC3000软件下载地址用户名和密码:(PC3000正式用户可以进入下载)
PC3000UDMA/UDMAE/Express/SAS 5.9.19新版本DE 注意事项
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=5564&extra=page%3D1
这一次正常升级的任何PC3000用户,都可以享受
PC3000 UDMA-E Express portable 高级区 账号,下次正常升级时延续正常升级,高级帐号可以持续持有。 这里有大量的数据恢复实用技术资料案例可以搜索查找
正常升级用户请发送工具卡号,使用者名字,电话,论坛用户名,信息到:11552946@qq.com ,我将核实后开通高级UDMA账号。
电梯直达
发表于 4 天前 |只看该作者 |倒序浏览 | 取消回复通知
04.03.2015 DataExtractor version 5.2.24
   - Fixed a bug in the implementation of procedures prevnesennaya asynchronous write to disk receiver.
     Manifested as an arbitrary interrupt the copy process, most often in the case of
     several tasks.
03.03.2015 DataExtractor version 5.2.23
   - Fixed bug made on the Beta-testing stage and is manifested in some problems with the creation of
     copy cleanly mapped drive when working from Explorer DE (copying files, analysis modes).
     A running mode is suspended for 60 seconds, and then output to log message
     Error read / write disk receiver, and then work with the disk receiver was impossible.
   - RAID Edition, fixed bug entered in the Beta-version has not been determined for operation Talica
     RAID5 RA and RAID5 RS.
27.02.2015 WD Marvell
   - Added support for families Malibu
   - For families and Europa Esprit adds support for editing cards goals in RAM.
   - Take into account the feature of mapping heads for new families since Tressels.
24.02.2015 WD Caviar, WD Caviar Cyl32, WD Caviar Cyl32 SATA, WD Marvell (not ROYL HDD)
- Added checksum and header modules for reading modules.
18.02.2012 Seagate
   - Optimized initialization procedure Safe Mode
02/18/2015 Uploaded release (version 5.9.15)
2/18/2015 All utilities
   - Fixed updating passports
18.02.2015 PC-3000SSD (All tools)
   - Fixed a bug when creating a task DE based SSD utility with pop-up window enter the number of parts of the memory chip.
02/17/2015 Uploaded release (version 5.9.14)
16.02.2015 DataExtractor version 5.2.22
   - Fixed a bug in the filter file systems are the result of the analysis
   - Fixed a bug that occurs in rare cases when saving files and folders from Explorer mode when Windows
     does not create a folder in the presence of the same name of the file (after the situation of the virus)
16.02.2015 WD Marvell
   - Added support for family Makalu 2.5 "
02/16/2015 Win7Disk utility for PC-3000 SAS
   - Fixed connection (disk capacity is less than 1 sector)
12.02.2015 WD Marvell
   - For PATA HDD (Pinnacle PATA, Atlantis PATA) Fixes crash when reading data of more than 128 sectors,
   - When reading the existing copies of the module are not corrected the error message
10.02.2015 Samsung
   - Added tehnoklyuch Trinity Drive Firmware Architecture "for Apple".
02/10/2015 Uploaded release (version 5.9.12)
09.02.2015 DataExtractor version 5.2.21 (Beta)
- Added a control connection cable for SATA-drives attached to ports PC3000.
        - Fixed bug with "export a report," resulting in some cases in the closure of the application
06.02.2015 DataExtractor version 5.2.20 (Beta)
- Fixed prevnesennaya in Beta-version error "loop" in the treatment of loss of readiness
        - HFS + fixed bug sector 4 k, it was not possible to re-open the card employed / unemployed
04.02.2015 DataExtractor version 5.2.19 (Beta)
        - In the "map object", added new card transactions
- Combine two cards
                - The intersection of two cards
                - Not crossing two cards
                - Cut from the first card of the second
                - Inversion maps
                - Compression Card
        - In the "map object", added the ability to clear rung comments
        - To form the task is added circular indicator (in the upper right corner of the dashboard disc)
          to display the process standby readiness disks connected to the ports of the board PC3000
        - Fixed bug with management "heads" provided work
          "physical sector size" for a virtual disk with a sector size of 512 bytes message
          Enforcement of the wrong type)
        - Is likely to finally fixed the bug Beta-version, which led to the conclusion in the log message
          "TDrive_Lock Error"
- Fixed a bug which caused not open files in the "Raw recovery"
- Fixed a bug when creating a "snapshot" of FS with the head map and legend, provided the work
- "Create a virtual disk (VMDK) of selected files" is now displayed only if
directly within the directory has files with the extension * .vmdk
- Added support for files in the XFS sparsed
- RAID Edition
- Fixed bug with setting RS-XOR / XOR-RS
- Fixed a bug with the placement of indices by default for the RS in asynchronous algorithms RAID6
31.01.2015 OCZ Barefoot3
   - Added fix to work with storage capacity of 512GB
27.01.2015 Samsung
   - Fixed a bug due to which changes during the tank through the passport data editor module port 9D PARAM_DM;
   - Added ability to view the report on the translation table zones (Work with service area - Table broadcast zones - Button "Report");
   - Added ability to select the heads, which will be recorded for writing in Physics (Utility status - Access to physics - Read / write only the selected head);
   - Improved test "Change head map in RAM". Added loading module 9D PARAM_DM from the service area in RAM before editing. Earlier rules module only in RAM, which could lead to errors when re-broadcast the change card without switching the power head.
27.01.2015 WD Marvell
   - Added Repair P-List according to the logs PST
   - Fixed a composite reading modules for disks with four copies of SA
   - Added Plugin to work with modules 129, 130, as well as the title search modules including with displacement are not multiples of the sector
   - Finalized "Download Dir RAM" - Added loading from a file, added the optional loading LDR after loading Dir
   - Finalized "Report on the tables of defects"
27.01.2015 OCZ Barefoot 3
   - Added read test identifiers NAND flash chips
   - Added test save dump NAND flash chips
   - Added ability to work with NAND flash memory chips of task DE
   - Added a form of "Utility status"
   - Fixed a critical error in the analysis of translation tables drive, leading to instability of the complex
   - Added tests for the translation of the drive mode "Safe" to "Normal", and vice versa
   - Added error handling when subtraction data storage
   - Implemented the correct drive initialization after power reconnected
   - Added a test to unlock and purification password information for drives work correctly in "Normal" mode
15.01.2015 Seagate F3
   - Modified dekdirovanie ROM for the proper analysis of images with a size of 1MB
23.01.2015 WD Marvell
   - Added fields and corrects errors in the report Drive Info Table (information on HDD)
19.01.2015 DataExtractor version 5.2.17 (Beta)
   - File system NTFS, fixed in version 5.2.16 prevnesennaya error incorrectly displays a map of MFT
     (Only the method of "Map of the table MFT", the logic of the file system was not broken)
   - Editor sector added drawing in the lower right corner of the white square to the "empty" sector (filled with zeros)
   - Fixed a situation where the creation (by pressing select a directory), and when you open the directory selection task form
     opened with the wrong home directory
   - SSD Edition, Fixed a bug where it was impossible to create / open two tasks based utilities for two identical SSD,
     connected to different ports PC3000
16.01.2015 Toshiba
   - In read mode utility when the option to read PBA added data loading P-List from a file.
16.01.2015 DataExtractor version 5.2.16 (Beta)
   - When saving files from "Raw recovery" added the choice of strategy of
     how to deal with existing files
   - Before you save the file in Windows Explorer and in the process added sohranneniya control space.
     Before sohranneniem in the case when calculate the required size, provides options (suddenly compressed files are stored
     or the user is going to clean section) in the conservation process where space is interrupted.
   - In HFS + Fixed a bug with the "disappearance" of cards CatalogFile, ExtentsFile, AttributesFile, AllocationFile
     Sector 512 bytes of non-
15.01.2015 DataExtractor version 5.2.15 (Beta)
   - Fixed a bug in the Beta-version, when you create a copy of a variant of a "physical" sectors, when copying files from Windows Explorer,
     files erroneously mentioned in the report and moved to the directory "! Problem" (if their sector have not been previously deducted).
   - Fixed a bug in the Beta-version, when you create a copy of a variant of a "physical" sectors, in some cases,
     open the form parameters, an error occurred.
   - When you create a copy of a variant of a "physical" sectors for analysis result adds the ability to
     "Take a picture with the head map"
   - Refined error handling mode avtoinitsializatsii and remove the password after avtoinitsializatsii
15.01.2015 Hitachi-IBM-ARM.
   - Fixed a bug in adscititious removal procedure password
15.01.2015 WD Marvell
   - While retaining modules (composite reading) added control checksum
15.01.2015 Toshiba
   - For models 46GSX, 52GSX, 55GSXF, 55GSXN, 55GSX, 56GSY Fixed bug with reading the CP with access to SATA
   - With latent defects to G-List LBA address over 1073741823 hiding will not be at logic scan if found defects with more 1073741823 LBA, then hiding only to P-List
06.01.2015 DataExtractor version 5.2.14 (Beta)
     does not consider the size of the maximum storage transferadlya receiver. If this size is less than 128 KB, an error occurs when copying, cleaning, filling with Pattern
   - Fixed a bug in the Beta-version, when you create a copy of a variant of a "physical" sectors, there is a
     "Error writing to disk receiver" with details "Error TDrive._Lock!"
   - Fixed a bug when filling Pattern for sectors> 512 bytes, Pattern fills only the first 512 bytes of the sector.
12.30.2014 The core of PC-3000 version 5.9.6
   - Fixed dead-lock, which could occur when the power (button) during the execution of tests in utilities or perform reading tasks DE.
30.12.2014 DataExtractor version 5.2.13 (Beta)
   - Fixed a bug in the Beta-version for drives that have internal "physical" sector size different from the size of a logical
     sector when creating a copy in the version with "physical" sectors recorded incorrectly card. This error is critical!
     Tasks that are deducted in this mode (work with "physical" sectors) must be repeated, so get confusion
     (Synchronous card correctly written asynchronously - with an error). We apologize beta testers. Unfortunately, the early stages of testing
     the error was discovered.
   - Fixed a bug in the form of editing options SAS / SCSI drives was the limit for the maximum LBA.
30.12.2014 WD Marvell USB / COM
   - Fixed shutdown mode heads.
30.12.2014 Toshiba
   - Technological reading mode adds the ability to perform the reading error when initializing a translator.
26.12.2014 OCZ Barefoot 3
   - Added to the master drive transfer mode Safe;
   - Added the ability to save the firmware in the drive base PC3000;
   - Added build a compiler for the storage capacity of 512 GB and above for more;
   - Fixed a bug that does not allow re-read the current translator;
   - Fixed a bug that caused the exclusion of "udma timeout" when applying technological key;
26.12.2014 Intel Postville
   - Fixed bug when updating drive firmware using the resource base of the PC3000.
   - Added handling of read errors when building the translator to drive family G2;
26.12.2014 DataExtractor version 5.2.12 (Beta)
   - The file system is FAT, fixed bug in prevnesennaya in Beta-version, which in some cases resulted in
     interrupt the execution of the method "Analysis of the data section."
   - RAID Edition, corrected errors in the auto detect RAID parameters based on metadata MDADM version 0.9;
26.12.2014 WD Marvell
   - Added Edit mode SA regions in the RAM
26.12.2014 WD Marvell USB / COM
   - During operation via COM-port added to the interrupt response (cancellation) of the current operation;
   - Fixed bug with reading sectors Editor sector at work via COM-port.
25.12.2014 DataExtractor version 5.2.11 (Beta)
   - Most likely fixed the bug manifests itself in some very rare cases when the mode "Search structures NTFS"
     and "Analysis of the data partition NTFS". After completion of the first stage (actually searching) applications are closed. The error occurred
     only on some operating systems (probably depended on the Service Pack) and not at every startup.
   - Fixed a bug when creating a copy, to the status of the process do not end up unread sector (errors and loss of status) and sector
     missed due to the interruption of the scan chain of errors.
22.12.2014 DataExtractor version 5.2.10 (Beta)
     sector when creating a copy in the version with "physical" wrong sectors is reading through the utility.
12.22.2014 The core of PC-3000 version 5.9.4
   - Sleep for the teams and recalibration bug fixed (use a timeout problem DE, which could lead to a timeout error)
22.12.2014 Toshiba
   - Fixed CP record for families HDD 32GSX, 34GSX, 35GSS, 37GSX, MQ01ABDH, MQ01ABD, 02TSKB
12.19.2014 The core of PC-3000 version 5.9.3
   - Complex units for the PC-3000 Express and UDMA-E returned to the driver version 8.18
19.12.2014 DataExtractor version 5.2.10
   - RAID Edition
- For RAID levels 5, 5EE, 6, add the parameter "Row Shift", allows you to move the table to the specified number of rows
- Correctly defined RAID level 6 for mdamd (table shifted by 1 line)
- Fixed bringing in a previous beta version error when opening forms a RAID
18.12.2014 DataExtractor version 5.2.9
  - Fixed a bug for drives that have internal "physical" sector size different from the logical sector size when creating a copy
    in the version with "physical" sectors wrong to draw maps of goals
17.12.2014 WD Marvell
  - Editor of passport data HDD added:
Editing the serial number in the ROM;
Editing DCM and creation date.
edited version of firmware;
Editing WWN;
On / Off and editing User password;
change Security level;
on / off and edit Master password revision code and for him;
On / Off Self encrypting drive;
the ability to change the following fields:
Spin-up / Spin-down after power-up
Disable look ahead;
Enable write cache;
Support power-up in standby
Disable support UDMA all
Disable support UDMA 66 and above
Disable support UDMA 100 and above
Disable support UDMA 133 and above
Support automatic acoustic management
Disable support automatic acoustic management
Enable automatic acoustic management
Disable security mode support
Disable host protected area
Enable relocation
  - Added editor passport data in RAM HDD.
  - Added command disk
Techno ON
Techno OFF
Firware restart
Warm reset
Spin down and reset
Spin up
Spin down
  - Fixed minor bugs.
15.12.2014, Seagate F3
  - The editor of the defect list P List, TA List, Servo Flaws List added mechanism for adding and editing individual records
  - Added action presents tools for DE
       - Work with the head map in RAM (can be set MaxHead, active physical and logical head map)
       - Load loader (Update Microcode) (providing opportunities rather than damaged podgruzki Tech and Diag overlay in RAM)
15.12.2014 PC3000 SSD version 2.0.0
  - Added utility OCZ Barefoot 3
  - Added utility Corsair SSD Neutron series
11.12.2014 DataExtractor version 5.2.9
  - Added a new legend for the decrypted sectors and the ability to work with it
  - Added ability to decipher the sector, previously read without decryption
  - Drive in which the internal "physical" sector size different from the logical sector size when creating a copy
    added option of working with "physical" sectors to optimize the creation of copies for problematic drives
  - For virtual file systems, which are the result of the analysis (eg "Scan MFT", "the analyst") adds the ability to create
   "Snapshots" with the head map or legend, which allows for example to select whole or problematic files, depending on the
    selected settings. (For example, you can select files that have troubled sectors heads or vice versa, the whole problem or files)
  - Fundamentally change control DRQ and its options. Added option to control when aborting execution. Apart From
    Among other things, it greatly increased the speed of read / write drives connected to the ports of the PC-3000 platforms
    Express and UDMA-Express.
  - Added ability to select the interface works with regular disks (SPTI or work as a file)
  - Implemented the "broadcast" membership card (s) for RAID and "wrapper" that changes the size of a sector that has allowed to build subkarty
    taking into account the legend, generate reports, etc ..
  - A rough recovery added the definition of new types of files and improved algorithms for old
  - In the "Search GREP" added the ability to specify a step more than 65536 sectors
  - Improved search algorithm in the "Fast Disk Analysis"
  - Oprimizirovan mode of mapping heads bisection (eliminated by repeated appeals for information on the sector).
  - For the "change of Legends", "clean card", "Mapping heads" implemented closure and a return to the state before the start of the regime.
  - Fixed problem when saving files from UNICODE-names, code page which does not coincide with the set,
    files are not transferred in! Problem.
  - Fixed a bug in the filter does not look for a file _ (abc _ *. * Is sought, abc_cd *. * Is not searched)
  - Fixed a bug that caused an increase in memory usage in the "Raw recovery", "search structures NTFS", "Data Analysis section"
    and was associated with an error in parsing parts catalogs FAT (problems arose when there were a lot)
  - NTFS file system
- Fixed wrong map was constructed for sparse files in the results of the analysis (scanning MFT, data analysis section)
        - Fixed a bug when parsing "a corrupt" resident Extends was no proper control, which could lead to the discharge application.
  - EXT4 file system
        - Added ability to process the results of incomplete data analysis section, which is useful for assessing the prospects
          analysis and RAID recovery
- Fixed wrong map was constructed for sparse files when the file starts with a tenuous chain
  - UFS file system
       11.12.2014 Hitachi-IBM-ARM.
   - If you go to the utility with one drive and then connect the other hand, when you call the editor if the NV-RAM
     rereading NV-RAM will fail tehnoklyucha supply, the editor was given the image of NV-RAM from the buffer.
     Fixed.
12.10.2014 The core of PC-3000
   - Complex units for the PC-3000 Express and UDMA-E, a new driver version 9.22
01.12.2014 The core of PC-3000
   - Solved the problem of flickering LED + 5V
   - Settings for COM-port option has been added "on demand"
01.12.2014 WD Marvell (USB / COM)
   - Added interrupt response read / write operations
   - Added optional data storage read at the entrance to the utility during operation via COM-port
   - Fixed a memory card to HDD with 10 heads
   - Improved Plugin to work with ROM dump (WD Marvell ROM Map), adds the ability to add modules extract the ROM.
01.12.2014 Toshiba
   - Added a data access HDD to SATA for families 29GSG, 46GSX, 52GSX, 55GSXF, 55GSXN, 55GSX, 56GSY, 59GSMP, 59GSM, 59GSXP, 59GSX, 61GSY, 63GSX, 64GSY, 65GSXN, 65GSX, 75GSX, 76GSX. Access to the data terminal is also possible. Access switch in the "Utility status"
   - Added support for family 02TSKB (3,5 ")
   - Added Plugin CP-DD mode CP directory
12/01/2014 Tools PC-3000
   - For redimov "Resource Editor HDD" and "Edit sector" added lock "Close" button to complete the process of reading
13.11.2014 Fujitsu
   - Changed the algorithm for determining a set of commands (PATA / SATA) taking into account the hang of some firmware MHV
12.11.2014 HGST SAS
   - Added a family HUC1090xxCSxx;
   - Added a loading table modules from CP 82;
   - A complete revision of the utility, fixed some small bugs.
12.11.2014 Seagate SAS
   - For families: Cheetah 15K.7, Cheetah NS.2, Barracuda ES.2, Savvio 10K.3, Savvio 10K.4, Savvio 15K.2, Constellation, Constellation ES, Constellation ES.2 added:
      - Read / Write System Files;
      - Editing Non Resident G-List;
      - Cleaning Non Resident G-List;
      - Editing P-List;
      - Editing Non Resident Primary DST List.
   - For families: Cheetah 15K.6, Cheetah 15K.7, Cheetah NS.2, Barracuda ES.2, Savvio 10K.3, Savvio 10K.4, Savvio 15K.2, Constellation, Constellation ES added editing passport data when working with way Flash ROM (Tools - Utility extensions - Work with the image of Flash ROM);
   - For families: Savvio 10K.5, Savvio 15K.3, Constellation.2, Constellation ES.2 added editing passport data and maps heads when working with the image of Flash ROM;
30.10.2014 Seagate F3
   - Added action tools for DE: Disable DIC (Data Integrity Check) - prohibits to shift power test
     Recording Time nakopiteya - accelerates reading in many BAD-ah
27.10.2014 Seagate F3
   - For the convenience of manual research destroyed the translator added dialogue shell conversion LBA in physics
21.10.2014 Seagate F3
   - Added the ability to print the table view object modules of SA in the record
   - Added the ability to scan the list of the last executed command for RW 32 vyvleniya errors
     read files of official information
17.10.2014 Seagate F3
   - Improved initializer boot-code mode
   - Improved start dialogue utilirty - added elemienty management:
         - Reconnect the COM port
         - Power Management HDD
         - Submit Soft / Hard reset
         - Read the passport
         - File initialization signals Boot Code mode / command mode terminal
16.10.2014 Samsung
   - Improved editing procedure of passport data in storage architecture Trinity;
   - Take measures to eliminate the error "Out of Memory" in the process of long-term operation of the utility.
15.10.2014 Seagate F3
   - For drives that do not go in readiness, but giving access to termnalu added initialization tables and modules
     Sys Files terminal. Mode is launched when the utility can also run it from the dialogue state
     utility, it also starts in the absence of information about Sys Files function calls Resource Reservation
     and creating a reference.
14.10.2014 Seagate F3
   - A sector subtraction algorithm Sys Files wizard viewing objects overhead changed so
     in that case, if the utility knows the size of the desired file, it is possible through a terminal subtraction in the case
     if the beginning of the file is corrupted
13.10.2014 Seagate F3
   - Added list editor defects TA List, Servo Flaws List
   - Added plugin parsing data buffers TA List, Servo Flaws List
   - Improved removal of passwords through the terminal. Now it works and Momentus Thin (Julius1 / Yarra / Sapta)
08.10.2014 Hitachi-IBM-ARM
   - Fixed how to store a list of defects from the editor RDMT (G-List).
     Error in it led in some cases to the impossibility of changing the G-List
     with the message "module is not loaded (RDMT, module G-List)"
06.10.2014 Seagate F3
   - Added setting descriptions Sys Files modules based on the table
版本升级
GMT+8, 2026-9-10 01:38 , Processed in 0.103321 second(s), 14 queries .
