查看: 14644|回复: 0
PC-3000 SSDNEW [复制链接]
发表于 2014-10-1 00:24:57 |只看该作者 |倒序浏览
PC-3000 SSDNEW
The PC-3000 SSD Software System operates in tandem with one of the three up-to-date hardware platforms  – PC-3000 Express,  PC-3000 UDMA, or PC-3000 Portable – and it is intended for SSD repair and diagnosis and for data recovery from SSDs with SATA, PATA, mSATA, and M.2 (NGFF) interfaces and the capacity from 64 GB to 1 Tb produced by different manufacturers, such as OCZ, Corsair, Crucial, RunCore, A-DATA, G.Skill, Micron, Plextor, Intel, Samsung, Seagate, Kingston and others.
The PC-3000 SSD contains a set of specialized utilities for working with solid-state drives. This set includes the Universal Utility for diagnosing any SSD based on the ATA-8 specification (both currently existing models and those that will be manufactured in future) and the Active Utilities (Special Utilities) intended for working with a particular drive model  in technological mode. It enables to deeply diagnose SSDs, to perform service operations, to re-write the drive's microcode, to rebuild the translator, to get direct access to memory chips, to carry out low-level formatting blocking the damaged cells and placing their addresses into the defect table, and to perform many other useful operations.
The PC-3000 SSD is started from the main window of the  PC-3000 Express, UDMA, or Portable System by means of clicking a button on the desktop panel.
PC-3000 SSD has the following functions for data recovery:
  • verify and restore the SSD's service information
  • read and write the content of the SSD's ROM
  • load the microcode into the drives's RAM
  • emulate the translator operation in order to get access to user data
  • view the password and reset the password that was earlier set on an SSD
  • turn off background processes in an SSD to prevent data damage
  • provide direct access to the content of memory chips (it makes unsoldering unnecessary)
  • work with the Data Extractor
PC-3000 SSD has the following functions for SSD repair (to recover normal operation):
  • diagnose an SSD in technological mode
  • view the logs of hidden defects (P-page, G-page)
  • perform low-level formatting to hide the discovered defects
  • change the configuration and identification parameters
  • reset the logs and S.M.A.R.T. parameters
  • search for the damaged memory chips
The list of Active Utilities of the PC-3000 SSD System is expanded as soon as new SSD models are studied, and it is a continuous process. Those utilities that are currently available allow you to successfully recover data from all contemporary solid-state drives and to resolve the majority of wide-spread SSD problems. It is planned to add special adapters and connectors that will allow to use technological interfaces to diagnose and repair drives.
The PC-3000 SSD delivery package
  • the System's software, the resource database – 1 DVD
  • User manual – 1 book
Delivery package options for the System:
The PC-3000 SSD System can be operated via the PC-3000 Express,  PC-3000 UDMA, or PC-3000 Portable controllers,so there are several delivery options:
In a package with PC-3000 Express
In a package with PC-3000 UDMA
In a package with PC-3000 Portable
Quick Online Access to the PC-3000 SSD
There is no need when the PC-3000 SSD will be shipped when you have an urgent SSD recovery case from your important customer.
The PC-3000 SSD software can be available immediately at the day of the payment.
Since the payment is done you will find the following in the Customer Update Box:
  • the resource database
  • User manual
System's functionality:
  • repair functions
  • data recovery functions
  • service and diagnostic functions
Compatibility with hardware:
  • PC-3000 Express
  • PC-3000 UDMA-E - PC-3000 Portable
Compatibility with software:
  • compatible with Data Extractor Express (RAID Edition)
  • compatible with Data Extractor UDMA (RAID Edition)
  • compatible with Data Extractor Portable
SSD operation modes:
  • UDMA, PIO, Terminal
Supported interfaces:
  • PATA,
  • SATA,
  • mSATA (if there is an adapter),
  • M.2 (NGFF) (if there is an adapter).
Working techniques:
  • standard technological modes for SSD
  • the System's proprietary advanced technological modes
  • the possibility of working with dumps in the manual mode
Supported SSDs:
Utility Manufacturer Model Data recovery Repair
Indilinx BarefootOCZVertex+-
OCZVertex Turbo+-
OCZVertex Plus+-
OCZVertex Ex+-
OCZSolid 2+-
OCZAgility+-
OCZAgility Ex+-
CorsairExtreme+-
CorsairNova+-
CrucialM225+-
RunCorePro IV+-
A-DATANobility+-
A-DATA500 series+-
G.SkillFalcon+-
[all SSDs based on IDX110M0x controller]
Marvell VanGoghCrucialM4++
CrucialC300++
CrucialC400++
CrucialM500++
MicronC300++
MicronC400++
Marvell VanGogh 2Intel510 Series+-
PlextorM3+-
PlextorM5+-
PlextorM5 Pro+-
Intel PostvilleIntelX25-M (Gen.2)++
IntelX25-V (Gen.2)++
Intel320 series++
Intel710 Series++
Samsung SSDSamsungPM 410+-
SamsungPM 800+-
Samsung470 series++
Samsung830 series+-
SamsungP830 series mini+-
Samsung840 series+-
Samsung840 Pro Series+-
Seagate SSDSeagateSeries 600-+
SeagateSeries 600 Pro-+
SeagateSeries 600 Enterprise-+
JMicronKingstonV100+-
[all SSD based on JMF61x controller]
GMT+8, 2026-9-10 01:37 , Processed in 0.100595 second(s), 15 queries .
