查看: 5844|回复: 0
The new PC-3000 SSD software version 1.0 is released [复制链接]
发表于 2014-9-30 23:32:36 |只看该作者 |倒序浏览
September
30, 2014
2014
930
The new PC-3000 SSD software version 1.0 isreleased
PC3000SSD软件释放1.0版本
As you see how quickly many SSD are appearing,it is high time to start tacking this new data recovery challenge!
ACE Laboratory anticipates the needs andprovides the
PC-3000 SSD – the only solution inthe world that restores SSD in the technological mode.
现在你能看到更多快速的SSD固态硬盘,在数据恢复领域有一个新的挑战!
ACE实验室预计的需求并提供PC-3000 SSD -在技术模式恢复固态硬盘,是世界上唯一的解决办法。
Repairing SSD and recovering data from SSD using the technological mode greatlysimplifies and accelerates the restoration process, not to mention theenormously increased efficiency.  The PC-3000 SSD product has a rich list of SSD which can be recovered using themost state-of-the-art techniques.
修复SSD使用技术模式从固态硬盘中恢复数据,大大简化和加快了恢复过程,更不用说大大提高了效率。在PC-3000 SSD产品拥有固态硬盘设备的支持列表,可以使用先进设备,最先进的技术。
All users who purchased the PC-3000 Flash SSD Edition till the 1st of June 2014will get the PC-3000 SSD FREE of charge! To use it, you should tell us on whichplatform you want to install it – Express, UDMA or Portable - and provide usthe following information:
谁购买了PC-3000闪存的SSD版,直到201461日,所有用户将获得PC-3000 SSD免费!(201461日前购买PC3000FLASH 用户将能免费获得这个SSD) 要使用它,你应该告诉我们在哪个平台上要安装它 - Express, UDMA-E Portable(必须是Express, UDMA-E Portable3个产品才可以附加PC3000SSD,老的绿色的UDMA 将不能支持SSD!) - 并为我们提供了以下信息:
·       Company name
·       公司名
·       Update box login name
·       更新盒子进入名字(使用人名字)
·       PC-3000 product with a serial number which should be usedwith the PC-3000 SSD (please choose between Express, UDMA or Portable)
·       PC3000SSD 一起使用产品的SN号(必须是Express, UDMA-E Portable3个产品号码,没有这3个产品号将不能添加SSD
·       PC-3000 Flash with a serial number
·       PC3000FLASH的序列号
You can get that quantity of the PC-3000 SSD copies that is similar of PC-3000Flash Kits you bought before the 1st of June, 2014.
你能获得PC3000 SSD 的数量等同于201461日之前你购买的PC3000FLASH 数量
Since the PC-3000 SSD is the software product it is much easier to buy it. Ifyou still doubt now whether you need to invest into the SSD recovery or not,you can get the PC-3000 SSD the same day when your customer brings you SSD, asno shipment is required.
由于PC-3000固态硬盘的软件产品很容易购买。如果你还怀疑现在是否需要投资到固态硬盘的恢复与否,你可以在你的客户给你带来固态硬盘同一天购买PC-3000SSDSSD不需要货运。
想要升级的用户请发送你们的名字卡号公司名信息到下面的邮箱
另外的问题能咨询(pc3000udma@vip.qq.com )13341136118.
如果你没有老的FLASH 在14年6月1号前购买,  你如果想要全新SSD,这就需要花钱购买,而不是免费升级,价格是16000元。
还有些用户咨询,2个设备的注册名字不同能不能绑定, 注册用户名不同就说明设备所有者不同,ACE不会把别人的设备绑定到你的卡上的!(ACE之前早有就禁止买卖二手工具)
GMT+8, 2026-9-10 01:38 , Processed in 0.095441 second(s), 14 queries .
