查看: 7917|回复: 2
西数不认盘,无法访问固件 [复制链接]
    2015-11-9 10:50:53
  • 签到天数: 23 天
    发表于 2014-5-28 14:41:38 |只看该作者 |倒序浏览
    WD1600BEVS的盘,能就绪,不认盘,访问不了固件,磁头确定是好的,做热交换读不了故障盘的模块,大家帮忙看看该怎么搞?
    Techno mode key
    Techno mode key......................... : Ok
    RAM:
    HDD Info reading........................ : Ok
    Heads number............................ : 4
    Cyl Count............................... : 96
    Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
    ROM:
    ROM reading............................. : Ok
    ROM Data size........................... : 192 Kb
    ROM version............................. : 11.86H
    ROM generation.......................... : 11.86H
    Link table version...................... : 03.8F.
    Consolidated ROM version................ : 00110086
    ROM Modules:
    Flash ROM dir reading................... : Ok
    SA regions address...................... : by default
    SA Translator loading................... : Ok
    Heads configuration..................... : by map
    Heads number in use..................... : 4
    Switched off heads...................... : No
    Heads map............................... : 0,1,2,3
    ROM Firmware version.................... : 00110086
    Service area:
    Permanent overlay....................... : Not loaded
    SA dir reading (ID)..................... :  DISK ECU UNSAFE ERROR
    SA SPT Detect........................... : FAIL
    SA dir reading (ABA/CHS)................ : Dir reading error ABA 65536 reading error Physical read error C/H/S: -96/1/1 - Device Error Detected: "DISK ECU UNSAFE ERROR"
    SA Access............................... : NONE
    Configuration reading................... : Module 02 not found
    2014-11-25 12:22:23
  • 签到天数: 12 天
    发表于 2014-6-2 20:49:57 |只看该作者
    重盘哦。。。4个头子。。。。这个盘能做热交换的撒!一定是你的方法不对。。。
    发表于 2023-7-28 11:31:12 |只看该作者
    感谢分享,学习学习
    GMT+8, 2026-7-27 07:31 , Processed in 0.098810 second(s), 11 queries .
