查看: 7154|回复: 0
日立ARM无法访问固件 [复制链接]
    2015-11-9 10:50:53
  • 签到天数: 23 天
    发表于 2014-5-28 14:17:30 |只看该作者 |倒序浏览
    日立ARM系列的盘进程序后不认盘不断电退出重进程序能识别到型号和固件版本序列号,但无法识别到容量,固件也无法访问,UDMA提示如下:该如何处理?
    Selected family......................... : 7232A7
    Model by ID............................. : HGST HTS725050A7E630
    Techno mode key......................... : Error
    ROM reading...
    Possible Tech Key is found. Checking...
    Result.................................. : Ok
    Error startintg command: Reading SA [0x3F0000004, 0x4]
    Device error detected (ABR)
    Error startintg command: Reading SA [0x3F0000004, 0x1]
    Error reading module USAG(0): Error startintg command: Reading SA [0x3F0000004, 0x1]
    Error startintg command: Reading SA [0x3F0100004, 0x4]
    Error startintg command: Reading SA [0x3F0100004, 0x1]
    Error reading module USAG(1): Error startintg command: Reading SA [0x3F0100004, 0x1]
    Loading modules table................................................. : Error
    Error :............................................................... : Module USAG: no copies read!
    Loading the table of "open" modules................................... : Error
    Error :............................................................... : Error executing loading "open" modules dir command
    是否是NV损坏,但ARM系列的盘又没法做NV适配。怎么恢复数据,求助。。。。。。。。。
    GMT+8, 2026-8-26 20:00 , Processed in 0.093476 second(s), 11 queries .
