查看: 6757|回复: 1
PC3000FLASH 新版本6.5.1 [复制链接]
发表于 2014-5-23 17:10:04 |只看该作者 |倒序浏览
PC3000FLASH 最新版本和升级流程:
2014年5月15日ACE释放新版本:PC3000FLASH 6.5.1
New version 6.5.1 of PC-3000 Flash SSD Edition is released新版本PC3000FLASH SSD 6.5.1释放
New features are available NOW! They are the following: 现在可用如下新功能:
  • New memory chips with the 16-8 JEDEC and the 16-8 ONFI type of reading have been added
  • 新存储芯片16-8JEDEC 和16-8 ONFI 有添加
  • New XOR patterns and ECC types have been added
  • 添加新的XOR 和ECC
  • New analysis algorithm for the SSS6677 controller has been added
  • 有添加新算法控制器SSS6677
  • the PC-3000 UDMA-E appears in the hardware controller selection while launching the Active Utility mode
  • 启动实用程序模式可以发现控制PC3000UDMA-E ,这意味着可以控制UDMA-E卡上的SSD硬盘。
  • New ability for adding the user's own ECC description has been added (recommended only for advanced users)
  • 新功能添加用户自定义的ECC描述(推荐为了只是高级用户)
  • New mode for adding elimination based on XOR has been added
  • 新模式添加消除基础XOR
  • the ECC auto detection tools have been improved
  • 改进ECC 自动发现工具
  • New synchronization method of the "Block's sorting" has been added
  • 有添加新的同步方法"Block's sorting"(块排序)
  • Matching version mode has been seriously improved
  • 改进模式匹配版本
  • A lot of different bug fixes and improvements in Kernel part of the PC-3000 Flash have been done
  • 改进PC3000FLASH 核心部分和许多问题修正
更多的:
http://acelaboratory.ru/pc3000flash/viewtopic.php?f=4&t=1431
武汉天浩数据
    2018-7-14 10:40:31
  • 签到天数: 333 天
    发表于 2014-5-26 08:46:56 |只看该作者
    已经升级,有改进,
    GMT+8, 2026-9-10 01:38 , Processed in 0.099994 second(s), 14 queries .
