查看: 11910|回复: 8
希捷硬盘F3家族系列模块和系统文件对照表 [复制链接]
发表于 2014-4-30 15:46:01 |只看该作者 |倒序浏览
希捷硬盘F3家族模块表
模块ID        模块功能描述
00 = SA defect list
01 = Drive Information File
02 = Performance Parameter File
03 = P-List
04 = SAP (Servo Adaptive Parameters)
05 = Manufacturing Information File
06 = RAP (Read Adaptive Parameters)
07 = CAP (Controller Adaptive Parameters)
08 = unknown purpose
09 = SMART config (filled with a pattern)
0A = SMART Frame
0B = unknown purpose, filled with a pattern
0C = Self Scan Log
0D = unknown purpose, filled with a pattern
0E = DIC (Data Integrity Check), HEAD 0
0F = DIC Dummy File
13 = disk registry(configuration settings, Security)
15 = offline surface self-test file (DOS)
16 = unknown purpose
17 = unknown purpose, filled with a pattern
19 = unknown purpose, some log
1A = unknown purpose, filled with a pattern
1B = unknown purpose, some log
1C = unknown purpose, filled with a pattern
1D = overlay 0
1E = overlay 1
1F = unknown purpose, filled with a pattern
22 = surface self-test file, head 0
23 = surface self-test file, head 1
24 = surface self-test file, head 2
25 = surface self-test file, head 3
26 = surface self-test file, head 4
27 = surface self-test file, head 5
28 = surface self-test file, head 6
29 = surface self-test file, head 7
2A = Saved Mode Pages – HDD settings
2B = RW operations, translator
2C = DIC (Data Integrity Check), HEAD 1, pattern
2D = DIC (Data Integrity Check), HEAD 2, pattern
2E = DIC (Data Integrity Check), HEAD 3, pattern
2F = DIC (Data Integrity Check), HEAD 4, pattern
30 = DIC (Data Integrity Check), HEAD 5, pattern
31 = DIC (Data Integrity Check), HEAD 6, pattern
32 = DIC (Data Integrity Check), HEAD 7, pattern
33 = FDE service file
34 = packed CONGEN structure descriptor
35 = SMART
以上表为例,我们可以看到 2B为翻译器模块,在硬盘固件损坏不识别情况下,可以首先切换到终端模式,设置高传送速率,可以读取系统文件 卷号:03 文件ID: 028 ,见下表
FILE_3_01A_0 = ~0001.rpm  卷号:3   系统文件ID号:01A   副本:0    对应的模块ID: 01( Drive Information File)
FILE_3_019_0 = ~0002.rpm
FILE_3_01B_0 = ~0003.rpm
FILE_3_03F_0 = ~0004.rpm
FILE_3_300_0 = ~0005.rpm
FILE_3_001_0 = ~0006.rpm
FILE_3_208_0 = ~0007.rpm
FILE_3_31B_0 = ~0008.rpm
FILE_3_133_0 = ~0009.rpm
FILE_3_134_0 = ~000A.rpm
FILE_3_319_0 = ~000C.rpm
FILE_3_30A_0 = ~0013.rpm
FILE_3_306_0 = ~0015.rpm
FILE_3_115_0 = ~0019.rpm
FILE_3_131_0 = ~001A.rpm
FILE_3_301_0 = ~001B.rpm
FILE_3_110_0 = ~001C.rpm
FILE_3_100_0 = ~001D.rpm
FILE_3_101_0 = ~001E.rpm
FILE_3_093_0 = ~002A.rpm
FILE_3_028_0 = ~002B.rpm
FILE_3_32C_0 = ~0034.rpm
FILE_3_135_0 = ~0035.rpm
例子: FILE_3_01A_0 = ~0001.rpm
Service information module = ~0001.rpm
System File = FILE_3_01A_0
Volume = 3
File ID (FID) = 01A
Copy = 0
    2014-7-9 13:33:01
    发表于 2014-4-30 16:34:53 |只看该作者
    好资料,谢谢张总。
    2020-3-6 15:01:21
  • 签到天数: 219 天
    发表于 2014-5-7 09:37:49 |只看该作者
    果断收藏!
    2020-3-6 15:01:21
  • 签到天数: 219 天
    发表于 2014-5-7 09:38:12 |只看该作者
    果断收藏!
    发表于 2014-6-25 09:16:09 |只看该作者
    加上这个
    Module        Sys. file          Description
    00   Defect list of SA
    01 0x001A Drive information file
    02 0x0019 Performance parameter file
    03 0x001B P-List
    04 0x003F SAP (Servo Adaptive FParameters)
    05 0x0300 Manufacturin information file
    06 0x0001 RAP (Read Adaptives Parameters)
    07 0x0208 CAP (Controller Adaptives Parameters)
    09 0x0133 SMART config (filling by pattern)
    0A 0x0134 SMART Frame
    0C 0x0139 Self scan log
    0E
    DIC (Data integrity check), Head 0
    0F   DIC Dummy file
    13 0x030A Disk reestr (Security settings)
    15 0x0306 Offline selfscan of surface (DOS)
    1D 0x0100 Overlay 0
    1E 0x0101 Overlay 1
    22   File selfscan surface, head 0
    23   File selfscan surface, head 1
    24   File selfscan surface, head 2
    25   File selfscan surface, head 3
    26   File selfscan surface, head 4
    27   File selfscan surface, head 5
    28   File selfscan surface, head 6
    29   File selfscan surface, head 7
    2A 0x0093 Saved Mode pages (Edit HDD ID)
    2B 0x0028 RW operations, (Translator)
    2C   DIC (Data Integrity Check), Head 1, pattern
    2D   DIC (Data Integrity Check), Head 2, pattern
    2E   DIC (Data Integrity Check), Head 3, pattern
    2F   DIC (Data Integrity Check), Head 4, pattern
    30   DIC (Data Integrity Check), Head 5, pattern
    31   DIC (Data Integrity Check), Head 6, pattern
    32   DIC (Data Integrity Check), Head 7, pattern
    33   Service file FDE
    34 0x032C Packed structure descriptor COUGEN
    35 0x0135 SMART
    发表于 2014-7-14 16:47:17 |只看该作者
    我终于理解了
    2014-8-21 10:59:02
    发表于 2014-8-21 10:56:51 |只看该作者
    果断收藏!
    2016-5-27 22:17:31
    发表于 2014-10-11 06:48:10 |只看该作者
    好东西,学习下
    发表于 2017-3-29 16:02:44 |只看该作者
    好好学习,天天向上
    GMT+8, 2026-9-10 01:38 , Processed in 0.110204 second(s), 17 queries .
