查看: 13163|回复: 4
PC-3000 UDMA [复制链接]
发表于 2014-4-16 01:27:20 |只看该作者 |倒序浏览
PC-3000 UDMA
The PC-3000 UDMA is a hardware-software solution intended for diagnosing and repairing HDD based on SATA (Serial ATA) and ATA (IDE) interfaces for numerous vendors (Seagate, Western Digital, Fujitsu, Samsung, Maxtor, Quantum, IBM (HGST), HITACHI, TOSHIBA), for various capacities (from 500MB to 4 TB) and various form factors: 3.5" - desktop drives, 2.5" and 1.8" - laptop drives, and 1.0" - portable drives with Compact Flash interfaces.
PC-3000 UDMA是一个软件和硬件解决方案用于诊断和修复基于SATA(串行ATA)和ATA(IDE) 接口硬盘的。支持许多厂商(希捷,西部数据,富士通,三星,迈拓,昆腾,IBM(HGST )日立,东芝),支持多种硬盘容量(从500MB到4 TB)和各种规格的硬盘:3.5“- 台式机硬盘,2.5”和1.8“- 笔记本电脑硬盘和1.0”- 便携式硬盘和闪存接口硬盘。
The PC-3000 UDMA coupled with the Data Extractor UDMA forms the PC-3000 UDMA Professional System that allows you to recover data from SATA, ATA (IDE) HDD. If you wish to repair these HDD, you need only the PC-3000 UDMA, and for data recovery you need the combination of PC-3000 UDMA and Data Extractor UDMA.
PC-3000 UDMA再加上Data Extractor UDMA形成PC-3000 UDMA专业系统,可以让你恢复从SATA,ATA(IDE)硬盘驱动器的数据。如果你想修复这些硬盘驱动器,你只需要PC-3000 UDMA,为了数据恢复你需要PC-3000 UDMA和Data Extractor UDMA的组合。
THE PC-3000 UDMA Hardware
The new PC-3000 UDMA is a three-port tester-board which is inserted into a PCI-Express expansion slot and has 2 SATA ports (data transfer speed up to 133 Mb/sec) and 1 PATA (speed up to 100 Mb/sec) port. The primary port is SATA0 while SATA1 is a secondary port which is switchable with the PATA port. The PC-3000 UDMA provides two simultaneous connections for two drives – the first port is used for SATA and the second one can be used either for SATA or for PATA (it depends on your needs). Thus, you can work either with 2 SATA drives or 1 SATA and 1 PATA at the same time.
When developing the new PCI-Express-based PC-3000 UDMA system, we used the main features from the previous generation of PCI-based PC-3000 UDMA, which proved to be the best, most reliable, and most optimally performing data recovery system possible, while at the same time maintaining a reasonable price.
新的PC-3000 UDMA的是一个三端口测试板其插入到PCI-Express扩展插槽,具有2个SATA接口(数据传输速度高达133 MB/秒)和1个PATA(速率高达100 MB/秒)端口。主端口是SATA0, SATA1是一个辅助端口其切换与PATA端口。PC-3000 UDMA提供了同时连接两个硬盘驱动器- 第一个端口用于SATA和第二个端口可以用于SATA或PATA(这取决于你的需要)。因此,你可以在同一时间操作任何一个,2个SATA硬盘驱动器或1个SATA和PATA1。在开发新的PCI-Express架构的PC-3000 UDMA的系统中,我们使用的主要特征从上一代的基于PCI总线的PC-3000 UDMA,这被证明是最好的,最可靠,最优化执行可能的数据恢复系统,而在同一时间保持在合理的价格。
Processing modes:
处理模式:
  • SATA x2 — UDMA133, UDMA100, UDMA66, UDMA33, PIO4, PIO3, PIO2, PIO1, PIO0
  • PATA x1 - UDMA100, UDMA66, UDMA33, PIO4, PIO3, PIO2, PIO1, PIO0
Two ports are separable, but when they are both in use they are dependent. There is a slight reduction in performance on the second channel when the first one is fully loaded (no more than 20% reduction) as the PC-3000 UDMA is based on a single-channel PCI-Express bus. At the same time, this technical solution allows a reduction of the total cost of the board and makes it more attractive for small and mid-sized data recovery companies.
两个端口是可分离的,但是当它们都在使用中它们是相关的。有一个在性能稍有下降时第一个满载的第二通道(减少不超过20%),其对PC-3000 UDMA基于单通道PCI-Express总线。与此同时,该技术方案可减少电路板的总成本,并使其成为小型和中型数据恢复公司更具吸引力。
Reading performance for two HDD drives
2个硬盘驱动器的读性能
According to the diagram, the reading speed of two channels on the new PC-3000 UDMA is much higher than the reading speed of the previous generation of PC-3000 UDMA on the PCI bus.
根据该图中,两个通道上的新的PC-3000 UDMA的读出速度比上一代的PCI总线的PC-3000 UDMA的读出速度高得多。
Power supply adapterA double-channel power supply adapter is located on the board controller and provides independent +5 V, +12 V voltage supply and protection from overvoltage and current overloading. In case of any contingency the HDD power supply is switched off automatically.
In addition, every channel has a feedback circuit with special management software that controls the supplying voltage values and informs the user about any issue with the feed circuit.
电源适配器的双通道电源适配器位于主控板上,并提供独立的+5 V,+12 V电源电压和过压过流保护。在任何意外情况下硬盘电源会自动关闭。 此外,每个通道都有反馈电路和专用管理软件,控制供给电压值和通知用户任何问题。
Resource Management of the PC-3000 UDMA board
One of the most important new features of the PC-3000 UDMA allows for launching of the PC-3000 utility and Data Extractor tasks as separate OS processes. The "PC-3000 Resource manager" software makes using the new PC-3000 UDMA very easy and effective. The "PC-3000 Resource manager" manages port and related process activity, controls the status of the ports, checks process conditions and kills processes when it is necessary.
Once a process is started it can use more than one port. For instance, two processes can be used for every port or two ports can be used by one process.
一个最重要的新特征可以用单独的系统进程启动 PC-3000实用程序和数据提取任务 。在“PC-3000资源管理”软件,使用新的PC-3000 UDMA非常容易和有效。在“PC-3000资源管理”有管理端口和相关的流程活动,控制端口状态,在那时如果必要可以检查程序和杀死进程。
一旦程序开始可以使用一个以上的端口。例如两个进程,可用于每个端口或两个端口可以使用一个进程。
Port selection process in the PC-3000 UDMA
PC-3000 UDMA Resource Manager
THE PC-3000 UDMA Kit
  • PC-3000 UDMA-E controller
  • PC-USB-TERMINAL adapter
  • PC-2" adapter
  • SATA-micro SATA adapter
  • MX-SAFE adapter
  • PC-FUJ.SATA adapter
  • PC-QUANTUM adapter
  • PC-SAMSUNG adapter
  • PC-SEAG.SATA adapter
  • PC-SEAGATE adapter
  • PC-TOSH.SATA adapter
  • ATCS, ATDA probe unlock
  • USB2.0 Defender cable
  • SATA RAID edition (80 cm) cable
  • UDMA80 (80 cm) flat cable
  • IDC10 (30 cm) cable
  • MX-SAFE power cable
  • SATA HDD (80 cm) power cable
  • PATA HDD (70 cm) power cable
  • PATA-SATA (10 cm) power adapter
  • PC-3000 UDMA software, resource database
  • User manual
PC-3000 UDMA Kit
PC-FUJ.SATA, PC-QUANTUM, PC-SAMSUNG, PC-SEAG.SATA, PC-SEAGATE, PC-TOSH.SATA connectors
HDD 10 pin cable
How to connect PC-USB-TERMINAL adapter
How to connect PC-SEAG.SATA adapter
PC-MX-SAFE adapter intended for working with MAXTOR HDD in safe mode
Tester (ATCS, ATDA) intended for unlocking HITACHI/IBM HDD
PC-2" adapter intended for connecting 2,5" and 1,8" HDD
PC micro SATA adapter
HDD SATA (80 cm) power supply cable
HDD PATA (70 cm) power supply cable
    2014-7-9 13:33:01
    发表于 2014-4-16 11:13:53 |只看该作者
    终于发布新版本了
    发表于 2014-4-16 21:10:44 |只看该作者
    这种3个端口的什么价格
    武汉天浩数据
    2018-7-14 10:40:31
  • 签到天数: 333 天
    发表于 2014-4-19 14:20:07 |只看该作者
    又要更新了哟!又要花银子了!
    2014-11-25 12:22:23
  • 签到天数: 12 天
    发表于 2014-4-30 12:08:10 |只看该作者
    关心价格问题 呵呵
    GMT+8, 2026-9-10 01:37 , Processed in 0.106067 second(s), 15 queries .
