查看: 9456|回复: 2
PC3000SAS [复制链接]
发表于 2014-4-16 01:17:46 |只看该作者 |倒序浏览
PC3000SAS 4端口同时工作,速度最高。300M/S
The PC-3000 SAS is a hardware-software solution intended for testing and restoring damaged HDDs with SAS (Serial Attached SCSI) or SCSI based interfaces.
The PC-3000 SAS coupled with the Data Extractor SAS forms the PC-3000 SAS/SCSI Professional System, which allows you to recover data from SAS or SCSI based HDDs. To repair these HDDs, you only need the PC-3000 SAS – for data recovery you need both the PC-3000 SAS and the Data Extractor SAS.
PC-3000 SAS可以用于测试和修复损坏的硬盘驱动器 是基于SAS(串行连接SCSI)或SCSI接口的软硬件解决方案。
PC-3000 SAS再加上Data Extractor SAS 构成PC-3000 SAS/ SCSI专业版系统,它可以让你恢复基于SAS或SCSI 硬盘驱动器数据。要修复这些硬盘驱动器,你只需要PC-3000 SAS - 数据恢复需要PC-3000 SAS 和Data Extractor SAS.
The PC-3000 SAS Controller
PC3000 SAS 控制器
The new specialized PC-3000 SAS Controller is a PC extension board for the PCI Express x4 bus that takes two adjacent slots which allows for working with four HDDs simultaneously.
新的专业PC-3000 SAS控制器是一台PC扩展板的PCI Express x4总线,采用两个相邻的插槽,允许同时四块硬盘的工作。
The PC-3000 board
PC3000SAS板
Four independent channels provide up to a 300 MB/sec data transfer rate.
四个独立的通道提供高达300 MB /秒的数据传输速率..
Chart performance for four SAS HDD drives
图表为四个SAS硬盘驱动器..
Working with SATA HDDs
The PC-3000 SAS controller allows you to connect SATA HDDs in read-write modes, test their surface, copy data, and make fast image copies.
在PC-3000 SAS控制器,允许你连接SATA硬盘在读写模式下,测试其表面,复制数据,并进行快速的映像备份。
Power supply adapter The four-channel power control adapter supplies power and protects the HDD from overvoltage and current overloading. In case of any contingency the HDD power supply is switched off automatically.
Resource Management of the PC-3000 SAS boardOne of the most important new features of the PC-3000 SAS is allowing for launching of the PC-3000 utility and Data Extractor tasks as separate OS processes. The "PC-3000 SAS Resource manager" software makes using the new PC-3000 SAS very easy and effective. It manages port and related process activity, controls the status of the ports, checks process conditions and kills processes if necessary. Once a process is started it can use any of the available ports on the PC-3000 SAS board. For instance, four processes can be used for every port or one process can use four ports etc.
Port selection for the PC-3000 SAS process
The PC-3000 SAS Resource manager
PC-3000 SAS Kit:
  • PC-3000 SAS controller
  • SAS SFF-8482/SATA/Molex (100cm) cable
  • HDD SCSI (50 cm) power cable
  • PC-3000 SAS software
  • User manual
PC3000SAS 带宽300M/S,实测SSD OCZ 达到180-210M/s,平均值202M/S 。PC3000SAS硬件每个端口带宽已经达到300MB/S,但是,PC3000SAS 端口所接的硬盘也要达到300MB/S ,你才能看到这个速度,我们常见的硬盘也就是100MB/S到170MB/S之间。
发表于 2014-5-7 11:48:33 |只看该作者
PC-3000 SAS 及 Data Extractor SAS,分別多少銭?
发表于 2014-6-3 11:21:24 |只看该作者
好牛的东西,不知道多少钱!
GMT+8, 2026-8-14 22:35 , Processed in 0.111131 second(s), 16 queries .
