查看: 19625|回复: 10
MCMT希捷F3 MCMT报错不识别恢复数据 [复制链接]
发表于 2014-3-11 16:27:07 |只看该作者 |倒序浏览
此案例最早发表于 2014-1-13 13:39:41 |  PC3000中国区数据恢复技术支持论坛高级区。
现转发到普通技术区免费释放SEAGATE F3 数据恢复技术给有需要朋友!
硬盘家族: 3F
3F, Pharaoh
硬盘型号:ST500DM002-1BD142
上电后在终端提示如下信息:
Boot 0x10M
Spin Up
RECOV Servo Op=0100 Resp=0005[0x00000000][0x0000B67C][0x0000BA10]
Trans.
Rst 0x10M
MC Internal LPC Process
Spin Up
(P) SATA Reset
报错如下:读取MCMT失败
MCMTFileHandler: EXCEPTION: Failed MCMT read request
此问题最快数据恢复方案:
用PC3000UDMA 终端,直接写系统文件 03  346 . 成功几率99.9%。 整个时间不会超过3分钟。
就是这样简单!详细日志如下:
找一个好硬盘,固件版本相同,读取固件。信息如下:
HDD family detecting...
Family ID: 3F
Selected family......................... : 3F, Pharaoh
Model by ID............................. : ST500DM002-1BD142
Loading default settings!
Use the options dialog to review and save utility settings.
Then press OK!
Family default settings loading!
Tech Key...
Requesting FW Pkg ver ........ PH0X2D.CCD6.KS06CB.KC65
Detecting Phys Sct Size...
Result.................................. : 4096
Detecting Max Head number...
Phys. heads............................. : 2
Obtaining Saved Mode Pages File information...
Reading Saved Mode Pages...
Parsing Saved Mode Pages...
SMP Dbl: 0x3C000317 - 0x037FF7FF (0x0000000F)
LBA alignment........................... : 0
Obtaining Registry File information...
Reading Registry File...
Parsing Registry File...
Media Cache
MC       : enabled
MC Size  : 0x997E28
MCMT Ver : MCMTV02
Collecting Sys Files information...
  ID        Len
   0          4  Reserved Defect Table (SA defect table)
   1          2  Drive Information File (DIF)
   2         16  Performance Parameter File (PPF)
   3       3787  Primary Defect File (P-List))
   4         12  Servo Adaptive Parameter File (SAP)
   5          4  Manufacturing Information File (MIF)
   6         66  Read Adaptive Parameters File (RAP)
   7          1  Controller Adaptive Parameters File (CAP)
   8       4800
   9          1  SMART Configuration File
   A       2251  SMART Data File
   B       1000
   C      64000  Serial Port Test Results File (Self Scan Log)
   D        160
   E        432  Data Integrity Check (DIC), HEAD 0
   F        223  DIC Dummy File
  13          8  Disc Registry File (settings, security, etc)
  15        100  BGMS File (Directed Offline Scan)
  16          2
  17         40
  19         24  Log File
  1A         33  Log File
  1B          1  Log File
  1C          9
  1D        128  Physical Overlay File 0
  1E        128  Physical Overlay File 1
  1F        640  Physical Overlay File 2
  22         80  Drive Self Test (DST), Head 0
  23         80  Drive Self Test (DST), Head 1
  2A          9  Saved Mode Pages (HDD settings)
  2B       1196  R/W Operating Parameters (translator, etc)
  2C        432  Data Integrity Check (DIC), HEAD 1
  33       4576
  34        640  Packed CONGEN XML definition
  35         26  SMART Data
  3A          4
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
  ID     MemOffs        Len
   0     6037200      33792  Read Adaptive Parameters File (RAP)
   1     6037000        512  Controller Adaptive Parameters File (CAP)
   4     4002C00       4096  Servo Adaptive Parameter File (SAP)
         602BE00       4096
              total    8192
   5       6C000      81920  Servo Firmware Table
   A     60C5AB8       3072  Seek Profile
  13     60D3DF8        864  Dependent Zone Table for User Area
  14     60D4158         96  Dependent Zone Table for System Area
  15           0     524288  Flash ROM
  1B     60D09DC      13340  Dependent Zone Group Tables for User Area
  1C     60D089C        320  Dependent Zone Group Tables for System Area
  1D     6037220        352  VBAR Configuration File
  1E     60374B0       2416  Zone Format Parameters File
RAM:
  ID     MemOffs        Len
   2     6037380        304  Zone Table
         602BE00       4096
              total    8192
   6      28F444      40996  Servo Flaw Table
  16     6037200         32  Drive Configuration Table
  17     6039240       1216  Temperature Control Configuration
  1F     618D6E4       1088  RW working user preamp table
  20     618DB24         64  RW working system preamp table
Collecting DT Infos completed
Reading autotuning buffer...............   Ok
Searching module table in RAM...........   Ok
Searching volume 3 file table in RAM....   Ok
Searching volume 0 file table in RAM....   Ok
Searching SMP RAM FID in RAM............   Ok
Searching Non Resident G-List FID in RAM   Ok
Searching CFW OVL FID in RAM............   Ok
Searching DT table(RAM, WR) in RAM......   Ok
Searching DT table(RAM, RD) in RAM......   Ok
System Files I/O method detection... ATA(direct)
Test  : Create loader
Saving LOD to folder.................... : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Pharaoh\ST500DM002-1BD142-KC65-S2A49M49\Data\LDR\SgF3LDR.lod
Scanning LOD files...
reading file FC00620D...
Parsing container segment....... CFW Overlay
Segment: CUSTFW
Parsing segment....... CUSTFW
Warning! Segment whole-space check sum is not zero: 00000BF7
End parsing segment... CUSTFW
End parsing container segment... CFW Overlay
   Appending: Disk FW / CFW Overlay
reading file FC355100...
   Appending: Overlay ID = 00
reading file FC356101...
   Appending: Overlay ID = 01
reading file FC357102...
reading file FC358103...
   Appending: Overlay ID = 04
reading file FC359104...
   Appending: Overlay ID = 05
reading file FC35A105...
reading file FC35B106...
reading file FC35C107...
reading file FC35D108...
reading file FC35E109...
reading file FC35F10A...
reading file FC36010B...
reading file FC36110C...
reading file FC36210D...
Çàâåðøåíî...
新版本加入LDR建立和加载功能。
好硬盘读取系统文件,正常。日志如下:
Test  : Reading System Files
Reading System Files to profile folder
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Pharaoh\ST500DM002-1BD142-KC65-S2A49M49\Data\SysFiles\
Copies : 0
Sys File FC000000(0).................................................. : Ok
Sys File FC001203(0).................................................. : Ok
Sys File FC002204(0).................................................. : Ok
Sys File FC003205(0).................................................. : Ok
Sys File FC004206(0).................................................. : Ok
Sys File FC00520C(0).................................................. : Ok
Sys File FC00620D(0).................................................. : Ok
Sys File FC00720E(0).................................................. : Ok
Sys File FC342001(0).................................................. : Ok
Sys File FC343019(0).................................................. : Ok
Sys File FC34401A(0).................................................. : Ok
Sys File FC34501B(0).................................................. : Ok
Sys File FC34601C(0).................................................. : Ok
Sys File FC34801D(0).................................................. : Ok
Sys File FC34901E(0).................................................. : Ok
Sys File FC34701F(0).................................................. : Ok
Sys File FC34A020(0).................................................. : Ok
Sys File FC34D028(0).................................................. : Ok
Sys File FC34E029(0).................................................. : Ok
Sys File FC34F035(0).................................................. : Ok
Sys File FC350036(0).................................................. : Ok
Sys File FC351037(0).................................................. : Ok
Sys File FC34B03F(0).................................................. : Ok
Sys File FC352052(0).................................................. : Ok
Sys File FC353061(0).................................................. : Ok
Sys File FC368093(0).................................................. : Ok
Sys File FC36D0BC(0).................................................. : Ok
Sys File FC37C0BF(0).................................................. : Ok
Sys File FC37D0C0(0).................................................. : Ok
Sys File FC355100(0).................................................. : Ok
Sys File FC356101(0).................................................. : Ok
Sys File FC357102(0).................................................. : Ok
Sys File FC358103(0).................................................. : Ok
Sys File FC359104(0).................................................. : Ok
Sys File FC35A105(0).................................................. : Ok
Sys File FC35B106(0).................................................. : Ok
Sys File FC35C107(0).................................................. : Ok
Sys File FC35D108(0).................................................. : Ok
Sys File FC35E109(0).................................................. : Ok
Sys File FC35F10A(0).................................................. : Ok
Sys File FC36010B(0).................................................. : Ok
Sys File FC36110C(0).................................................. : Ok
Sys File FC36210D(0).................................................. : Ok
Sys File FC363110(0).................................................. : Ok
Sys File FC364115(0).................................................. : Ok
Sys File FC365116(0).................................................. : Ok
Sys File FC366131(0).................................................. : Ok
Sys File FC367132(0).................................................. : Ok
Sys File FC36A133(0).................................................. : Ok
Sys File FC36B134(0).................................................. : Ok
Sys File FC36C135(0).................................................. : Ok
Sys File FC393136(0).................................................. : Ok
Sys File FC37E137(0).................................................. : Ok
Sys File FC37F138(0).................................................. : Ok
Sys File FC383139(0).................................................. : Ok
Sys File FC38413A(0).................................................. : Ok
Sys File FC38513B(0).................................................. : Ok
Sys File FC39413C(0).................................................. : Ok
Sys File FC38613D(0).................................................. : Ok
Sys File FC38713E(0).................................................. : Ok
Sys File FC38813F(0).................................................. : Ok
Sys File FC389140(0).................................................. : Ok
Sys File FC38A141(0).................................................. : Ok
Sys File FC390143(0).................................................. : Ok
Sys File FC392144(0).................................................. : Ok
Sys File FC37214E(0).................................................. : Ok
Sys File FC31014F(0).................................................. : Ok
Sys File FC311150(0).................................................. : Ok
Sys File FC312151(0).................................................. : Ok
Sys File FC313152(0).................................................. : Ok
Sys File FC314153(0).................................................. : Ok
Sys File FC315154(0).................................................. : Ok
Sys File FC316155(0).................................................. : Ok
Sys File FC317156(0).................................................. : Ok
Sys File FC318157(0).................................................. : Ok
Sys File FC319158(0).................................................. : Ok
Sys File FC31A159(0).................................................. : Ok
Sys File FC31B15A(0).................................................. : Ok
Sys File FC31C15B(0).................................................. : Ok
Sys File FC31D15C(0).................................................. : Ok
Sys File FC31E15D(0).................................................. : Ok
Sys File FC31F15E(0).................................................. : Ok
Sys File FC32015F(0).................................................. : Ok
Sys File FC321160(0).................................................. : Ok
Sys File FC322161(0).................................................. : Ok
Sys File FC323162(0).................................................. : Ok
Sys File FC324163(0).................................................. : Ok
Sys File FC325164(0).................................................. : Ok
Sys File FC326165(0).................................................. : Ok
Sys File FC327166(0).................................................. : Ok
Sys File FC328167(0).................................................. : Ok
Sys File FC329168(0).................................................. : Ok
Sys File FC32A169(0).................................................. : Ok
Sys File FC32B16A(0).................................................. : Ok
Sys File FC32C16B(0).................................................. : Ok
Sys File FC32D16C(0).................................................. : Ok
Sys File FC37316D(0).................................................. : Ok
Sys File FC37416E(0).................................................. : Ok
Sys File FC380171(0).................................................. : Ok
Sys File FC381177(0).................................................. : Ok
Sys File FC382178(0).................................................. : Ok
Sys File FC38F195(0).................................................. : Ok
Sys File FC38B1D0(0).................................................. : Ok
Sys File FC38C1D1(0).................................................. : Ok
Sys File FC3911D2(0).................................................. : Ok
Sys File FC33D203(0).................................................. : Ok
Sys File FC33E204(0).................................................. : Ok
Sys File FC33F205(0).................................................. : Ok
Sys File FC340206(0).................................................. : Ok
Sys File FC341208(0).................................................. : Ok
Sys File FC369209(0).................................................. : Ok
Sys File FC34C300(0).................................................. : Ok
Sys File FC354301(0).................................................. : Ok
Sys File FC36E304(0).................................................. : Ok
Sys File FC36F305(0).................................................. : Ok
Sys File FC370306(0).................................................. : Ok
Sys File FC371307(0).................................................. : Ok
Sys File FC37530A(0).................................................. : Ok
Sys File FC37630E(0).................................................. : Ok
Sys File FC377317(0).................................................. : Ok
Sys File FC378318(0).................................................. : Ok
Sys File FC379319(0).................................................. : Ok
Sys File FC37A31A(0).................................................. : Ok
Sys File FC37B31B(0).................................................. : Ok
Sys File FC38D32C(0).................................................. : Ok
Sys File FC38E32D(0).................................................. : Ok
Sys File FC395346(0).................................................. : Ok
Sys File 04421093(0).................................................. : Ok
System Files reading process completed
接上坏硬盘调到高速率,读系统文件日志如下:
Folder: C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SgF3\Pharaoh\3F 500G\Data
Copies : 0 1
Rd Sys File: vol = 0, FID = 000, Copy = 000...
Receiving file  FILE_0_000_0, length = 2048
Sys File FD000000(0).................................................. : Ok
Rd Sys File: vol = 0, FID = 000, Copy = 001...
Receiving file  FILE_0_000_1, length = 2048
Sys File FD000000(1).................................................. : Ok
Rd Sys File: vol = 0, FID = 203, Copy = 000...
Receiving file  FILE_0_203_0, length = 4096
Rd Sys File: vol = 0, FID = 203, Copy = 001...
Receiving file  FILE_0_203_1, length = 4096
Sys File FC001203(1).................................................. : Ok
Rd Sys File: vol = 0, FID = 204, Copy = 000...
Receiving file  FILE_0_204_0, length = 1536
Rd Sys File: vol = 0, FID = 204, Copy = 001...
Receiving file  FILE_0_204_1, length = 1536
Sys File FC002204(1).................................................. : Ok
Rd Sys File: vol = 0, FID = 205, Copy = 000...
Receiving file  FILE_0_205_0, length = 1024
Rd Sys File: vol = 0, FID = 205, Copy = 001...
Receiving file  FILE_0_205_1, length = 1024
Sys File FC003205(1).................................................. : Ok
Rd Sys File: vol = 0, FID = 206, Copy = 000...
Receiving file  FILE_0_206_0, length = 1024
Rd Sys File: vol = 0, FID = 206, Copy = 001...
Receiving file  FILE_0_206_1, length = 1024
Sys File FC004206(1).................................................. : Ok
Rd Sys File: vol = 0, FID = 20C, Copy = 000...
Receiving file  FILE_0_20C_0, length = 197120
Rd Sys File: vol = 0, FID = 20C, Copy = 001...
Receiving file  FILE_0_20C_1, length = 197120
Sys File FC00520C(1).................................................. : Ok
Rd Sys File: vol = 0, FID = 20D, Copy = 000...
Receiving file  FILE_0_20D_0, length = 921600
Rd Sys File: vol = 0, FID = 20D, Copy = 001...
Receiving file  FILE_0_20D_1, length = 921600
Sys File FC00620D(1).................................................. : Ok
Rd Sys File: vol = 0, FID = 20E, Copy = 000...
Receiving file  FILE_0_20E_0, length = 921600
Rd Sys File: vol = 0, FID = 20E, Copy = 001...
Receiving file  FILE_0_20E_1, length = 921600
Sys File FC00720E(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 001, Copy = 000...
Receiving file  FILE_3_001_0, length = 33792
Rd Sys File: vol = 3, FID = 001, Copy = 001...
Receiving file  FILE_3_001_1, length = 33792
Sys File FC342001(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 019, Copy = 000...
Receiving file  FILE_3_019_0, length = 8192
Rd Sys File: vol = 3, FID = 019, Copy = 001...
Receiving file  FILE_3_019_1, length = 8192
Sys File FC343019(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 01A, Copy = 000...
Receiving file  FILE_3_01A_0, length = 1024
Rd Sys File: vol = 3, FID = 01A, Copy = 001...
Receiving file  FILE_3_01A_1, length = 1024
Sys File FC34401A(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 01B, Copy = 000...
Receiving file  FILE_3_01B_0, length = 1938944
Rd Sys File: vol = 3, FID = 01B, Copy = 001...
Receiving file  FILE_3_01B_1, length = 1938944
Sys File FC34501B(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 01C, Copy = 000...
Receiving file  FILE_3_01C_0, length = 103424
Rd Sys File: vol = 3, FID = 01C, Copy = 001...
Receiving file  FILE_3_01C_1, length = 103424
Sys File FC34601C(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 01D, Copy = 000...
Receiving file  FILE_3_01D_0, length = 20480
Rd Sys File: vol = 3, FID = 01D, Copy = 001...
Receiving file  FILE_3_01D_1, length = 20480
Sys File FC34801D(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 01E, Copy = 000...
Receiving file  FILE_3_01E_0, length = 82944
Rd Sys File: vol = 3, FID = 01E, Copy = 001...
Receiving file  FILE_3_01E_1, length = 82944
Sys File FC34901E(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 01F, Copy = 000...
Receiving file  FILE_3_01F_0, length = 1918464
Rd Sys File: vol = 3, FID = 01F, Copy = 001...
Receiving file  FILE_3_01F_1, length = 1918464
Sys File FC34701F(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 020, Copy = 000...
Receiving file  FILE_3_020_0, length = 1835520
Rd Sys File: vol = 3, FID = 020, Copy = 001...
Receiving file  FILE_3_020_1, length = 1835520
Sys File FC34A020(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 028, Copy = 000...
Receiving file  FILE_3_028_0, length = 612352
Rd Sys File: vol = 3, FID = 028, Copy = 001...
Receiving file  FILE_3_028_1, length = 612352
Sys File FC34D028(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 029, Copy = 000...
Receiving file  FILE_3_029_0, length = 153088
Rd Sys File: vol = 3, FID = 029, Copy = 001...
Receiving file  FILE_3_029_1, length = 153088
Sys File FC34E029(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 035, Copy = 000...
Receiving file  FILE_3_035_0, length = 655872
Rd Sys File: vol = 3, FID = 035, Copy = 001...
Receiving file  FILE_3_035_1, length = 655872
Sys File FC34F035(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 036, Copy = 000...
Receiving file  FILE_3_036_0, length = 655872
Rd Sys File: vol = 3, FID = 036, Copy = 001...
Receiving file  FILE_3_036_1, length = 655872
Sys File FC350036(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 037, Copy = 000...
Receiving file  FILE_3_037_0, length = 1311744
Rd Sys File: vol = 3, FID = 037, Copy = 001...
Receiving file  FILE_3_037_1, length = 1311744
Sys File FC351037(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 03F, Copy = 000...
Receiving file  FILE_3_03F_0, length = 6144
Rd Sys File: vol = 3, FID = 03F, Copy = 001...
Receiving file  FILE_3_03F_1, length = 6144
Sys File FC34B03F(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 052, Copy = 000...
Receiving file  FILE_3_052_0, length = 2621952
Rd Sys File: vol = 3, FID = 052, Copy = 001...
Receiving file  FILE_3_052_1, length = 2621952
Sys File FC352052(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 061, Copy = 000...
Receiving file  FILE_3_061_0, length = 512
Rd Sys File: vol = 3, FID = 061, Copy = 001...
Receiving file  FILE_3_061_1, length = 512
Sys File FC353061(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 093, Copy = 000...
Receiving file  FILE_3_093_0, length = 4608
Rd Sys File: vol = 3, FID = 093, Copy = 001...
Receiving file  FILE_3_093_1, length = 4608
Sys File FC368093(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 0BC, Copy = 000...
Receiving file  FILE_3_0BC_0, length = 278528
Rd Sys File: vol = 3, FID = 0BC, Copy = 001...
Receiving file  FILE_3_0BC_1, length = 278528
Sys File FC36D0BC(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 0BF, Copy = 000...
Receiving file  FILE_3_0BF_0, length = 5120
Rd Sys File: vol = 3, FID = 0BF, Copy = 001...
Receiving file  FILE_3_0BF_1, length = 5120
Sys File FC37C0BF(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 0C0, Copy = 000...
Receiving file  FILE_3_0C0_0, length = 512
Rd Sys File: vol = 3, FID = 0C0, Copy = 001...
Receiving file  FILE_3_0C0_1, length = 512
Sys File FC37D0C0(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 100, Copy = 000...
Receiving file  FILE_3_100_0, length = 65536
Rd Sys File: vol = 3, FID = 100, Copy = 001...
Receiving file  FILE_3_100_1, length = 65536
Sys File FC355100(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 101, Copy = 000...
Receiving file  FILE_3_101_0, length = 65536
Rd Sys File: vol = 3, FID = 101, Copy = 001...
Receiving file  FILE_3_101_1, length = 65536
Sys File FC356101(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 102, Copy = 000...
Receiving file  FILE_3_102_0, length = 327680
Rd Sys File: vol = 3, FID = 102, Copy = 001...
Receiving file  FILE_3_102_1, length = 327680
Sys File FC357102(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 103, Copy = 000...
Receiving file  FILE_3_103_0, length = 196608
Rd Sys File: vol = 3, FID = 103, Copy = 001...
Receiving file  FILE_3_103_1, length = 196608
Sys File FC358103(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 104, Copy = 000...
Receiving file  FILE_3_104_0, length = 131072
Rd Sys File: vol = 3, FID = 104, Copy = 001...
Receiving file  FILE_3_104_1, length = 131072
Sys File FC359104(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 105, Copy = 000...
Receiving file  FILE_3_105_0, length = 65536
Rd Sys File: vol = 3, FID = 105, Copy = 001...
Receiving file  FILE_3_105_1, length = 65536
Sys File FC35A105(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 106, Copy = 000...
Receiving file  FILE_3_106_0, length = 65536
Rd Sys File: vol = 3, FID = 106, Copy = 001...
Receiving file  FILE_3_106_1, length = 65536
Sys File FC35B106(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 107, Copy = 000...
Receiving file  FILE_3_107_0, length = 65536
Rd Sys File: vol = 3, FID = 107, Copy = 001...
Receiving file  FILE_3_107_1, length = 65536
Sys File FC35C107(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 108, Copy = 000...
Receiving file  FILE_3_108_0, length = 65536
Rd Sys File: vol = 3, FID = 108, Copy = 001...
Receiving file  FILE_3_108_1, length = 65536
Sys File FC35D108(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 109, Copy = 000...
Receiving file  FILE_3_109_0, length = 327680
Rd Sys File: vol = 3, FID = 109, Copy = 001...
Receiving file  FILE_3_109_1, length = 327680
Sys File FC35E109(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 10A, Copy = 000...
Receiving file  FILE_3_10A_0, length = 196608
Rd Sys File: vol = 3, FID = 10A, Copy = 001...
Receiving file  FILE_3_10A_1, length = 196608
Sys File FC35F10A(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 10B, Copy = 000...
Receiving file  FILE_3_10B_0, length = 131072
Rd Sys File: vol = 3, FID = 10B, Copy = 001...
Receiving file  FILE_3_10B_1, length = 131072
Sys File FC36010B(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 10C, Copy = 000...
Receiving file  FILE_3_10C_0, length = 65536
Rd Sys File: vol = 3, FID = 10C, Copy = 001...
Receiving file  FILE_3_10C_1, length = 65536
Sys File FC36110C(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 10D, Copy = 000...
Receiving file  FILE_3_10D_0, length = 65536
Rd Sys File: vol = 3, FID = 10D, Copy = 001...
Receiving file  FILE_3_10D_1, length = 65536
Sys File FC36210D(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 110, Copy = 000...
Receiving file  FILE_3_110_0, length = 4608
Rd Sys File: vol = 3, FID = 110, Copy = 001...
Receiving file  FILE_3_110_1, length = 4608
Sys File FC363110(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 115, Copy = 000...
Receiving file  FILE_3_115_0, length = 12288
Rd Sys File: vol = 3, FID = 115, Copy = 001...
Receiving file  FILE_3_115_1, length = 12288
Sys File FC364115(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 116, Copy = 000...
Receiving file  FILE_3_116_0, length = 16896
Rd Sys File: vol = 3, FID = 116, Copy = 001...
Receiving file  FILE_3_116_1, length = 16896
Sys File FC365116(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 131, Copy = 000...
Receiving file  FILE_3_131_0, length = 16896
Rd Sys File: vol = 3, FID = 131, Copy = 001...
Receiving file  FILE_3_131_1, length = 16896
Sys File FC366131(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 132, Copy = 000...
Receiving file  FILE_3_132_0, length = 982016
Rd Sys File: vol = 3, FID = 132, Copy = 001...
Receiving file  FILE_3_132_1, length = 982016
Sys File FC367132(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 133, Copy = 000...
Receiving file  FILE_3_133_0, length = 512
Rd Sys File: vol = 3, FID = 133, Copy = 001...
Receiving file  FILE_3_133_1, length = 512
Sys File FC36A133(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 134, Copy = 000...
Receiving file  FILE_3_134_0, length = 1152512
Rd Sys File: vol = 3, FID = 134, Copy = 001...
Root Sys File Rd Err!
HDD power supply switching OFF/ON...
Sys File FC36B134(1).................................................. : Error
Error : Can not read!
Rd Sys File: vol = 3, FID = 135, Copy = 000...
Receiving file  FILE_3_135_0, length = 13312
Rd Sys File: vol = 3, FID = 135, Copy = 001...
Sys File FC36C135(1).................................................. : Error
Rd Sys File: vol = 3, FID = 136, Copy = 000...
Receiving file  FILE_3_136_0, length = 131072
Rd Sys File: vol = 3, FID = 136, Copy = 001...
Receiving file  FILE_3_136_1, length = 131072
Sys File FC393136(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 137, Copy = 000...
Receiving file  FILE_3_137_0, length = 512
Rd Sys File: vol = 3, FID = 137, Copy = 001...
Sys File FC37E137(1).................................................. : Error
Rd Sys File: vol = 3, FID = 138, Copy = 000...
Receiving file  FILE_3_138_0, length = 512
Rd Sys File: vol = 3, FID = 138, Copy = 001...
Receiving file  FILE_3_138_1, length = 512
Sys File FC37F138(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 139, Copy = 000...
Receiving file  FILE_3_139_0, length = 5120
Rd Sys File: vol = 3, FID = 139, Copy = 001...
Receiving file  FILE_3_139_1, length = 5120
Sys File FC383139(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 13A, Copy = 000...
Receiving file  FILE_3_13A_0, length = 1024
Rd Sys File: vol = 3, FID = 13A, Copy = 001...
Receiving file  FILE_3_13A_1, length = 1024
Sys File FC38413A(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 13B, Copy = 000...
Receiving file  FILE_3_13B_0, length = 512
Rd Sys File: vol = 3, FID = 13B, Copy = 001...
Receiving file  FILE_3_13B_1, length = 512
Sys File FC38513B(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 13C, Copy = 000...
Receiving file  FILE_3_13C_0, length = 33792
Rd Sys File: vol = 3, FID = 13C, Copy = 001...
Receiving file  FILE_3_13C_1, length = 33792
Sys File FC39413C(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 13D, Copy = 000...
Receiving file  FILE_3_13D_0, length = 512
Rd Sys File: vol = 3, FID = 13D, Copy = 001...
Receiving file  FILE_3_13D_1, length = 512
Sys File FC38613D(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 13E, Copy = 000...
Receiving file  FILE_3_13E_0, length = 512
Rd Sys File: vol = 3, FID = 13E, Copy = 001...
Receiving file  FILE_3_13E_1, length = 512
Sys File FC38713E(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 13F, Copy = 000...
Receiving file  FILE_3_13F_0, length = 262144
Rd Sys File: vol = 3, FID = 13F, Copy = 001...
Receiving file  FILE_3_13F_1, length = 262144
Sys File FC38813F(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 140, Copy = 000...
Receiving file  FILE_3_140_0, length = 10240
Rd Sys File: vol = 3, FID = 140, Copy = 001...
Receiving file  FILE_3_140_1, length = 10240
Sys File FC389140(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 141, Copy = 000...
Receiving file  FILE_3_141_0, length = 51712
Rd Sys File: vol = 3, FID = 141, Copy = 001...
Receiving file  FILE_3_141_1, length = 51712
Sys File FC38A141(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 143, Copy = 000...
Receiving file  FILE_3_143_0, length = 512
Rd Sys File: vol = 3, FID = 143, Copy = 001...
Receiving file  FILE_3_143_1, length = 512
Sys File FC390143(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 144, Copy = 000...
Receiving file  FILE_3_144_0, length = 512
Rd Sys File: vol = 3, FID = 144, Copy = 001...
Receiving file  FILE_3_144_1, length = 512
Sys File FC392144(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 14E, Copy = 000...
Receiving file  FILE_3_14E_0, length = 4096
Rd Sys File: vol = 3, FID = 14E, Copy = 001...
Receiving file  FILE_3_14E_1, length = 4096
Sys File FC37214E(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 14F, Copy = 000...
Receiving file  FILE_3_14F_0, length = 49152
Rd Sys File: vol = 3, FID = 14F, Copy = 001...
Sys File FC31014F(1).................................................. : Error
Rd Sys File: vol = 3, FID = 150, Copy = 000...
Receiving file  FILE_3_150_0, length = 49152
Rd Sys File: vol = 3, FID = 150, Copy = 001...
Sys File FC311150(1).................................................. : Error
Rd Sys File: vol = 3, FID = 151, Copy = 000...
Receiving file  FILE_3_151_0, length = 49152
Rd Sys File: vol = 3, FID = 151, Copy = 001...
Sys File FC312151(1).................................................. : Error
Rd Sys File: vol = 3, FID = 152, Copy = 000...
Receiving file  FILE_3_152_0, length = 184320
Rd Sys File: vol = 3, FID = 152, Copy = 001...
Sys File FC313152(1).................................................. : Error
Rd Sys File: vol = 3, FID = 153, Copy = 000...
Receiving file  FILE_3_153_0, length = 184320
Rd Sys File: vol = 3, FID = 153, Copy = 001...
Sys File FC314153(1).................................................. : Error
Rd Sys File: vol = 3, FID = 154, Copy = 000...
Receiving file  FILE_3_154_0, length = 184320
Rd Sys File: vol = 3, FID = 154, Copy = 001...
Sys File FC315154(1).................................................. : Error
Rd Sys File: vol = 3, FID = 155, Copy = 000...
Receiving file  FILE_3_155_0, length = 70144
Rd Sys File: vol = 3, FID = 155, Copy = 001...
Sys File FC316155(1).................................................. : Error
Rd Sys File: vol = 3, FID = 156, Copy = 000...
Receiving file  FILE_3_156_0, length = 70144
Rd Sys File: vol = 3, FID = 156, Copy = 001...
Sys File FC317156(1).................................................. : Error
Rd Sys File: vol = 3, FID = 157, Copy = 000...
Receiving file  FILE_3_157_0, length = 70144
Rd Sys File: vol = 3, FID = 157, Copy = 001...
Sys File FC318157(1).................................................. : Error
Rd Sys File: vol = 3, FID = 158, Copy = 000...
Receiving file  FILE_3_158_0, length = 15360
Rd Sys File: vol = 3, FID = 158, Copy = 001...
Sys File FC319158(1).................................................. : Error
Rd Sys File: vol = 3, FID = 159, Copy = 000...
Receiving file  FILE_3_159_0, length = 15360
Rd Sys File: vol = 3, FID = 159, Copy = 001...
Sys File FC31A159(1).................................................. : Error
Rd Sys File: vol = 3, FID = 15A, Copy = 000...
Receiving file  FILE_3_15A_0, length = 15360
Rd Sys File: vol = 3, FID = 15A, Copy = 001...
Sys File FC31B15A(1).................................................. : Error
Rd Sys File: vol = 3, FID = 15B, Copy = 000...
Receiving file  FILE_3_15B_0, length = 238592
Rd Sys File: vol = 3, FID = 15B, Copy = 001...
Sys File FC31C15B(1).................................................. : Error
Rd Sys File: vol = 3, FID = 15C, Copy = 000...
Receiving file  FILE_3_15C_0, length = 238592
Rd Sys File: vol = 3, FID = 15C, Copy = 001...
Sys File FC31D15C(1).................................................. : Error
Rd Sys File: vol = 3, FID = 15D, Copy = 000...
Receiving file  FILE_3_15D_0, length = 238592
Rd Sys File: vol = 3, FID = 15D, Copy = 001...
Sys File FC31E15D(1).................................................. : Error
Rd Sys File: vol = 3, FID = 15E, Copy = 000...
Receiving file  FILE_3_15E_0, length = 274944
Rd Sys File: vol = 3, FID = 15E, Copy = 001...
Sys File FC31F15E(1).................................................. : Error
Rd Sys File: vol = 3, FID = 15F, Copy = 000...
Receiving file  FILE_3_15F_0, length = 274944
Rd Sys File: vol = 3, FID = 15F, Copy = 001...
Sys File FC32015F(1).................................................. : Error
Rd Sys File: vol = 3, FID = 160, Copy = 000...
Receiving file  FILE_3_160_0, length = 274944
Rd Sys File: vol = 3, FID = 160, Copy = 001...
Sys File FC321160(1).................................................. : Error
Rd Sys File: vol = 3, FID = 161, Copy = 000...
Receiving file  FILE_3_161_0, length = 119296
Rd Sys File: vol = 3, FID = 161, Copy = 001...
Sys File FC322161(1).................................................. : Error
Rd Sys File: vol = 3, FID = 162, Copy = 000...
Receiving file  FILE_3_162_0, length = 119296
Rd Sys File: vol = 3, FID = 162, Copy = 001...
Sys File FC323162(1).................................................. : Error
Rd Sys File: vol = 3, FID = 163, Copy = 000...
Receiving file  FILE_3_163_0, length = 119296
Rd Sys File: vol = 3, FID = 163, Copy = 001...
Sys File FC324163(1).................................................. : Error
Rd Sys File: vol = 3, FID = 164, Copy = 000...
Receiving file  FILE_3_164_0, length = 238592
Rd Sys File: vol = 3, FID = 164, Copy = 001...
Sys File FC325164(1).................................................. : Error
Rd Sys File: vol = 3, FID = 165, Copy = 000...
Receiving file  FILE_3_165_0, length = 238592
Rd Sys File: vol = 3, FID = 165, Copy = 001...
Sys File FC326165(1).................................................. : Error
Rd Sys File: vol = 3, FID = 166, Copy = 000...
Receiving file  FILE_3_166_0, length = 238592
Rd Sys File: vol = 3, FID = 166, Copy = 001...
Sys File FC327166(1).................................................. : Error
Rd Sys File: vol = 3, FID = 167, Copy = 000...
Receiving file  FILE_3_167_0, length = 119296
Rd Sys File: vol = 3, FID = 167, Copy = 001...
Sys File FC328167(1).................................................. : Error
Rd Sys File: vol = 3, FID = 168, Copy = 000...
Receiving file  FILE_3_168_0, length = 119296
Rd Sys File: vol = 3, FID = 168, Copy = 001...
Sys File FC329168(1).................................................. : Error
Rd Sys File: vol = 3, FID = 169, Copy = 000...
Receiving file  FILE_3_169_0, length = 119296
Rd Sys File: vol = 3, FID = 169, Copy = 001...
Sys File FC32A169(1).................................................. : Error
Rd Sys File: vol = 3, FID = 16A, Copy = 000...
Receiving file  FILE_3_16A_0, length = 33792
Rd Sys File: vol = 3, FID = 16A, Copy = 001...
Sys File FC32B16A(1).................................................. : Error
Rd Sys File: vol = 3, FID = 16B, Copy = 000...
Receiving file  FILE_3_16B_0, length = 33792
Rd Sys File: vol = 3, FID = 16B, Copy = 001...
Sys File FC32C16B(1).................................................. : Error
Rd Sys File: vol = 3, FID = 16C, Copy = 000...
Receiving file  FILE_3_16C_0, length = 33792
Rd Sys File: vol = 3, FID = 16C, Copy = 001...
Sys File FC32D16C(1).................................................. : Error
Rd Sys File: vol = 3, FID = 16D, Copy = 000...
Receiving file  FILE_3_16D_0, length = 49152
Rd Sys File: vol = 3, FID = 16D, Copy = 001...
Receiving file  FILE_3_16D_1, length = 49152
Sys File FC37316D(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 16E, Copy = 000...
Receiving file  FILE_3_16E_0, length = 164864
Rd Sys File: vol = 3, FID = 16E, Copy = 001...
Receiving file  FILE_3_16E_1, length = 164864
Sys File FC37416E(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 171, Copy = 000...
Receiving file  FILE_3_171_0, length = 512
Rd Sys File: vol = 3, FID = 171, Copy = 001...
Receiving file  FILE_3_171_1, length = 512
Sys File FC380171(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 177, Copy = 000...
Receiving file  FILE_3_177_0, length = 4608
Rd Sys File: vol = 3, FID = 177, Copy = 001...
Receiving file  FILE_3_177_1, length = 4608
Sys File FC381177(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 178, Copy = 000...
Receiving file  FILE_3_178_0, length = 130560
Rd Sys File: vol = 3, FID = 178, Copy = 001...
Receiving file  FILE_3_178_1, length = 130560
Sys File FC382178(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 195, Copy = 000...
Receiving file  FILE_3_195_0, length = 102400
Rd Sys File: vol = 3, FID = 195, Copy = 001...
Receiving file  FILE_3_195_1, length = 102400
Sys File FC38F195(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 1D0, Copy = 000...
Receiving file  FILE_3_1D0_0, length = 2342912
Rd Sys File: vol = 3, FID = 1D0, Copy = 001...
Receiving file  FILE_3_1D0_1, length = 2342912
Sys File FC38B1D0(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 1D1, Copy = 000...
Receiving file  FILE_3_1D1_0, length = 1116160
Rd Sys File: vol = 3, FID = 1D1, Copy = 001...
Receiving file  FILE_3_1D1_1, length = 1116160
Sys File FC38C1D1(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 1D2, Copy = 000...
Receiving file  FILE_3_1D2_0, length = 1024
Rd Sys File: vol = 3, FID = 1D2, Copy = 001...
Receiving file  FILE_3_1D2_1, length = 1024
Sys File FC3911D2(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 203, Copy = 000...
Receiving file  FILE_3_203_0, length = 4096
Rd Sys File: vol = 3, FID = 203, Copy = 001...
Receiving file  FILE_3_203_1, length = 4096
Sys File FC33D203(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 204, Copy = 000...
Receiving file  FILE_3_204_0, length = 1536
Rd Sys File: vol = 3, FID = 204, Copy = 001...
Receiving file  FILE_3_204_1, length = 1536
Sys File FC33E204(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 205, Copy = 000...
Receiving file  FILE_3_205_0, length = 1024
Rd Sys File: vol = 3, FID = 205, Copy = 001...
Receiving file  FILE_3_205_1, length = 1024
Sys File FC33F205(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 206, Copy = 000...
Receiving file  FILE_3_206_0, length = 1024
Rd Sys File: vol = 3, FID = 206, Copy = 001...
Receiving file  FILE_3_206_1, length = 1024
Sys File FC340206(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 208, Copy = 000...
Receiving file  FILE_3_208_0, length = 512
Rd Sys File: vol = 3, FID = 208, Copy = 001...
Receiving file  FILE_3_208_1, length = 512
Sys File FC341208(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 209, Copy = 000...
Receiving file  FILE_3_209_0, length = 1536
Rd Sys File: vol = 3, FID = 209, Copy = 001...
Receiving file  FILE_3_209_1, length = 1536
Sys File FC369209(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 300, Copy = 000...
Receiving file  FILE_3_300_0, length = 2048
Rd Sys File: vol = 3, FID = 300, Copy = 001...
Receiving file  FILE_3_300_1, length = 2048
Sys File FC34C300(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 301, Copy = 000...
Receiving file  FILE_3_301_0, length = 512
Rd Sys File: vol = 3, FID = 301, Copy = 001...
Receiving file  FILE_3_301_1, length = 512
Sys File FC354301(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 304, Copy = 000...
Receiving file  FILE_3_304_0, length = 20480
Rd Sys File: vol = 3, FID = 304, Copy = 001...
Receiving file  FILE_3_304_1, length = 20480
Sys File FC36E304(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 305, Copy = 000...
Receiving file  FILE_3_305_0, length = 1024
Rd Sys File: vol = 3, FID = 305, Copy = 001...
Receiving file  FILE_3_305_1, length = 1024
Sys File FC36F305(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 306, Copy = 000...
Receiving file  FILE_3_306_0, length = 51200
Rd Sys File: vol = 3, FID = 306, Copy = 001...
Receiving file  FILE_3_306_1, length = 51200
Sys File FC370306(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 307, Copy = 000...
Receiving file  FILE_3_307_0, length = 2048
Rd Sys File: vol = 3, FID = 307, Copy = 001...
Receiving file  FILE_3_307_1, length = 2048
Sys File FC371307(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 30A, Copy = 000...
Receiving file  FILE_3_30A_0, length = 4096
Rd Sys File: vol = 3, FID = 30A, Copy = 001...
Receiving file  FILE_3_30A_1, length = 4096
Sys File FC37530A(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 30E, Copy = 000...
Receiving file  FILE_3_30E_0, length = 114176
Rd Sys File: vol = 3, FID = 30E, Copy = 001...
Receiving file  FILE_3_30E_1, length = 114176
Sys File FC37630E(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 317, Copy = 000...
Receiving file  FILE_3_317_0, length = 81920
Rd Sys File: vol = 3, FID = 317, Copy = 001...
Receiving file  FILE_3_317_1, length = 81920
Sys File FC377317(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 318, Copy = 000...
Receiving file  FILE_3_318_0, length = 512000
Rd Sys File: vol = 3, FID = 318, Copy = 001...
Receiving file  FILE_3_318_1, length = 512000
Sys File FC378318(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 319, Copy = 000...
Receiving file  FILE_3_319_0, length = 32768000
Rd Sys File: vol = 3, FID = 319, Copy = 001...
Receiving file  FILE_3_319_1, length = 32768000
Sys File FC379319(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 31A, Copy = 000...
Receiving file  FILE_3_31A_0, length = 512000
Rd Sys File: vol = 3, FID = 31A, Copy = 001...
Receiving file  FILE_3_31A_1, length = 512000
Sys File FC37A31A(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 31B, Copy = 000...
Receiving file  FILE_3_31B_0, length = 2457600
Rd Sys File: vol = 3, FID = 31B, Copy = 001...
Receiving file  FILE_3_31B_1, length = 2457600
Sys File FC37B31B(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 32C, Copy = 000...
Receiving file  FILE_3_32C_0, length = 327680
Rd Sys File: vol = 3, FID = 32C, Copy = 001...
Receiving file  FILE_3_32C_1, length = 327680
Sys File FC38D32C(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 32D, Copy = 000...
Receiving file  FILE_3_32D_0, length = 327680
Rd Sys File: vol = 3, FID = 32D, Copy = 001...
Receiving file  FILE_3_32D_1, length = 327680
Sys File FC38E32D(1).................................................. : Ok
Rd Sys File: vol = 3, FID = 346, Copy = 000...
Sys File FC395346(0).................................................. : Error
Rd Sys File: vol = 3, FID = 346, Copy = 001...
Sys File FC395346(1).................................................. : Error
Rd Sys File: vol = 4, FID = 093, Copy = 000...
Receiving file  FILE_4_093_0, length = 4608
Rd Sys File: vol = 4, FID = 093, Copy = 001...
Sys File 04421093(1).................................................. : Error
发现 vol = 3, FID = 346, Copy0和COPY1都损坏。
将好硬盘的固件写入后,硬盘可以识别,之后清除非常驻缺陷表和重建编译器后,数据恢复成功。
希捷硬盘F3家族系列模块和系统文件对照表
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=5413&extra=
    发表于 2014-3-12 12:54:07 |只看该作者
    非常驻缺陷表指的是哪个菜单下的?不是G-LIST表吧
    难过
    2014-2-22 13:50:59
  • 签到天数: 127 天
    发表于 2014-3-12 13:22:38 |只看该作者
    谢谢张总
    难过
    2014-2-22 13:50:59
  • 签到天数: 127 天
    发表于 2014-3-12 13:23:16 |只看该作者
    谢谢张总的无私奉献!
    2019-11-22 09:43:43
  • 签到天数: 77 天
    发表于 2014-3-20 15:48:53 |只看该作者
    故障盘不识别,怎么直接通过终端写入固件呢
    发表于 2014-4-9 16:15:56 |只看该作者
    对啊, 硬盘不识别, 怎么用终端回写呢?
    发表于 2014-6-13 16:46:59 |只看该作者
    Sys File FC395346 这个是什么作用?没看懂
    发表于 2014-6-13 16:49:44 |只看该作者
    对啊, 硬盘不识别, 怎么用终端回写呢?[/quote]
    新版本加入LDR建立和加载功能。
    发表于 2014-7-4 09:43:01 |只看该作者
    FAIL  Servo Op=0100 Resp=0007
    是什么问题
    2015-4-30 09:20:32
  • 签到天数: 12 天
    发表于 2014-7-13 13:10:08 |只看该作者
    非常驻缺陷表指的是哪个菜单下的?不是G-LIST表吧[/quote]
    清除非常驻缺陷表的菜单在“Tests -> Defect lists -> Clearing Non Resident GList”
    GMT+8, 2026-8-26 19:21 , Processed in 0.222504 second(s), 12 queries .
