查看: 5208|回复: 3
新手上路,遇。。。。。 [复制链接]
    2018-11-17 10:22:15
  • 签到天数: 59 天
    发表于 2014-2-27 16:41:49 |只看该作者 |倒序浏览
    ROM:
    ROM reading............................. : Ok
    ROM Data size........................... : 192 Kb
    ROM version............................. : 12.4GD
    ROM generation.......................... : 12.4HD
    Link table version...................... : 04.0H.
    Consolidated ROM version................ : 0012004G
    ROM Modules:
    Flash ROM dir reading................... : Ok (Active)
    Flash ROM dir reading (Ext)............. : Ok
    Modules directory address............... : 81 319
    SA regions address...................... : by default
    SA Translator loading................... : Ok
    SA defects assigned..................... : 1
    Heads configuration..................... : by map
    Heads number............................ : 2
    Heads number in use..................... : 2
    Switched off heads...................... : No
    Heads map............................... : 0,1
    ROM Firmware version.................... : 0012004G
    Service area:
    Permanent overlay....................... : Loaded
    SA dir reading (ID)..................... : Ok
    SA Access............................... : Copy 0,Copy 1
    Configuration reading................... : Ok
    Master Password......................... : has not been set
    User Password........................... : has not been set
    Scan and remap defects
    Initial LBA............................. : 0
    Final LBA............................... : 976 773 167
    Test type............................... : Verify
    Error Code : 51A2....................... : DISK ECU UNSAFE ERROR
    这个是盘是什么问题
    2014-3-29 18:24:35
    发表于 2014-3-20 10:55:19 |只看该作者
    看看学习
    2014-4-13 17:09:59
    发表于 2014-3-23 15:30:14 |只看该作者
    52323eq额外特特
    发表于 2023-7-26 16:55:20 |只看该作者
    我也支持 加油
    GMT+8, 2026-7-27 00:49 , Processed in 0.096996 second(s), 11 queries .
