查看: 8972|回复: 4
PC3000进入WD程序后默认检查到的信息 [复制链接]
发表于 2011-10-21 00:47:55 |只看该作者 |倒序浏览
硬盘型号:WDC WD3200AAJS-00YZCA0
家族系列:Tahoe LT
档案:Marvell ROYL 20B
提示:多注意硬盘信息,观察硬盘模块和信息之间的关系,你将有新的收获!
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1290
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 00.1GA
ROM generation.......................... : 00.1HA
Link table version...................... : 03.0C.
Consolidated ROM version................ : 0000001G
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 156 333 (24)
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 0000001G
Service area:
SA dir reading.......................... : Ok
SA Access............................... : Copy 0
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
    2019-9-27 17:08:05
  • 签到天数: 102 天
    发表于 2011-10-21 11:50:00 |只看该作者
    谢谢技术指导
    发表于 2011-10-22 09:46:40 |只看该作者
    谢谢指导!
    武汉天浩数据
    2018-7-14 10:40:31
  • 签到天数: 333 天
    发表于 2011-10-28 12:39:14 |只看该作者
    发表于 2012-2-24 21:21:27 |只看该作者
    呵呵呵,这些信息有是还是比较有用的
    GMT+8, 2026-9-10 01:37 , Processed in 0.101020 second(s), 14 queries .
