查看: 6199|回复: 4
PC3000FLASH SSD 相机卡-SM266BF-数据分析 学习要点 [复制链接]
发表于 2011-10-20 22:02:44 |只看该作者 |倒序浏览
这个视频非免费,军达成PC3000FLASH SSD 高级用户可以下载它并获得密码。
密码咨询:军达成技术总监
视频下载地址:
https://skydrive.live.com/?cid=b ... 7795A80C58E25%21525
1.
根据特定参数和SA信息,分析2个DUMP之间的关系 ,Split(分离) .Join (结合)是否正确。查看服务区信息的变化位置,
本例是 Marker position 偏移:515 。块大小 Block Size (in sectors) 为 1024. 当515位置到数值到达 FF, 将进位到偏移516 ,516为 00- 01-02逐一递增数值 ,这就是  Identifier structure: 3412 标准。
2.
灵活运用以下运算法则的自动分析,找到真正的参数!
有时系统推荐自动执行的是非正确的参数,必须分析手工填写正确的参数,再一次执行运算法则分析,你将获得数据。
Applying method : Block number (Type 1) [0x0000]...
Algorithm parameters autodetection...Block size determenation
Shift of marker within sector:  513   Calculated value of block size:  1024   Probability:  142336   Mask: Undefined!   Identifier structure: Undefined! Variant is not correct and removed from analysis
Shift of marker within sector:  514   Calculated value of block size:  1024   Probability:  229376   Mask   : FFFF   Identifier structure: 1234
Shift of marker within sector:  515   Calculated value of block size:  1024   Probability:  227328   Mask   : FFFF   Identifier structure: 3412
Variants of marker position::
Most probable
Try other parameters in case of bad result .
The following parameters will be applied:
Marker position............. 514
..... 1024
Shift of the analysis start. 0
Mask........................ 0xFFFF
Identifier structure........ 1234
Blocks integrity testing.... YES
Marker analysis. Allocation by banks.
Bank 00 Block Number D: 000784 H: 0310
Bank 01 Block Number D: 000513 H: 0201
Bank 02 Block Number D: 000455 H: 01c7
Bank 03 Block Number D: 000006 H: 0006
Header of partition is not correct!It is recommended to use table of Versions and Quick disk analysis
Duration : 00:00:03
Marker position............. 515
Block Size (in sectors)..... 1024
Identifier structure........ 3412
Bank 00 Block Number D: 000969 H: 03c9
Bank 01 Block Number D: 000966 H: 03c6
Duration : 00:00:03
Ver: 2010/7/15 * 1899/12/30
Initializing FAT32 variables
...DataStart = 4111
File saving C:\Users\ADMINI~1\AppData\Local\Temp\tmp71BC.JPG complete
Saving process complete
    2013-8-22 09:32:07
    发表于 2011-10-20 22:51:21 |只看该作者
    2023-10-30 21:49:54
  • 签到天数: 20 天
    发表于 2011-10-21 13:15:21 |只看该作者
    我能得到他不?
    2013-7-15 13:57:03
    发表于 2011-10-29 11:09:30 |只看该作者
    好,,,顶一个,,
    2013-10-8 21:20:25
    发表于 2013-9-29 22:44:45 |只看该作者
    密码是多少
    GMT+8, 2026-9-10 02:55 , Processed in 0.086205 second(s), 12 queries .
