查看: 17128|回复: 11
新版本 PC-3000 Ver. 5.5 and Data Extractor Ver. 5.0 [复制链接]
发表于 2013-8-21 00:03:00 |只看该作者 |倒序浏览
PC3000UDMA+DE  最新版本和升级流程:
New version for PC-3000 Ver. 5.5 and Data Extractor Ver. 5.0[/td][tr]
WD Marvell
  • Improved head map search algorithm in RAM, added support of new families;
  • 在RAM里改进磁头地图运输法则,添加支持的新的家族;
  • Modified algorithm for the head map in ROM for following families: Trails, Tressels, Diablo 3D;
  • 为了在ROM 里的磁头地图改进运算法则; 支持硬盘家族Trails, Tressels, Diablo 3D;
  • Fixed bug in "Search Modules in SA" mode, it did not perform "Apply Dir" in the past;
  • 修理问题在服务区模式模块搜索,在过去没有执行''应用目录';'
  • Fixed bug of grouping defects in the tracks;
  • 在磁道里修理分组缺陷问题;
  • Improved "Edit module catalog" mode, the differences between the structure of the Zephyr family drives are considered.
    Zephyr家族硬盘驱动器差异结构是考虑的.改进编辑模块目录模式,
WD Marvell USB
  • Improved COM/USB utility: (改进COM/USD 实用程序)
           - fixed bug of ROM writing;
             修理写ROM的问题
  •        - fixed bug of writing modules by ID (including modules with capacity more 256 sectors);
  •          修理由ID写模块的问题(包括模块容量超过256扇区)
           - added check of set port speed (earlier error of setting speed of port entailed data transfer errors).
             添加设置端口速度检查(早期设置端口速度错误引起数据传送错误)
  • Added full support for USB 3.0 drives.
  • 已添加完全支持USB3.0硬盘驱动器.
WD Caviar Cyl 32
  • Fixed bug of translator regeneration.
  • 重建翻译器问题已经修理.
WD Caviar Cyl 32 SATA
  • Fixed bug of translator regeneration for Odisey and Hercules families.
  • Odisey 和Hercules 硬盘家族重建翻译器错误已经修理.
Seagate F3
  • In the "View and edit HDD Resources" tool the Sys Files list shows all found copies of files with indicated origin in SA;
  • 在“查看和编辑硬盘资源”sys文件工具列表中显示找到的所有的文件副本指示起源于SA
  • Added search through the Sys Files list by Sys LBA;
  • 由系统LBA搜索系统文件表已添加;
  • HDD microcode to read/write ROM is placed to activation file to provide quick addition of the set of Flash ROM supported types;
  • 硬盘微代码去读/写ROM是放置到激活文件能提供快速的添加FLASH ROM 支持的文件类型;
  • Added support of мс WINBOND 25Q40BWS0, ManID = 1C for ROM writing;
  • 已添加支持写ROM .WINBOND 25Q40BWS0, ManID = 1C
  • Added Boot Code Mode autoinitialization (without short cut of ROM pins) for reading/writing ROM;
  • 读/写ROM已添加引导代码安装模式(不需像过去一样,要短路ROM引脚)
  • Fixed bug in the procedure for correcting the single LBA position (translator recovery, type 2);
  • 修正单一LBA位置的问题已修理(翻译器恢复,类型2)
  • Fixed bug in scanning the surface of drives with capacity more 2 Tb at translator recovery;
  • 硬盘容量超过2TB恢复翻译器扫描硬盘驱动器的问题已修理;
  • Modified translator recovery procedure (Media Cache effect);
  • 改良翻译器恢复程序(媒体缓存作用)
  • Added editing of Media Scratch Pad Control flag into procedure of editing ID in SA and in RAM;
  • 在服务区和缓存中编辑硬盘身份信息的程序 媒体高速暂存 已添加(为了数据恢复非常重要!)
  • Fixed procedure for making a defects list in the translator (Media Cache effect);
  • 在翻译器里标记缺陷表程序已修理(媒体缓存作用)
  • Added ability to edit defect flag fields in Non Resident Lists editors;
  • 在非常驻表编辑已添加标记字段缺陷;
  • Added System Files Reading/Writing - via ATA and via terminal;
  • 用ATA和终端2种方式读/写硬盘服务区系统文件已添加;
  • Added reservation of System Files into SA backup function. Backup of system files of 0 and 3 partitions is done. It is implemented both for backup of SA, translator recovery and translator recovery modes and solving "LED CC problem";
  • 添加服务区系统文件保留到硬盘服务区备份功能里.备份服务区系统文件0和3分区已完成. 它是执行硬盘服务区的备份,翻译器恢复和翻译器恢复模式和解决LED CC 问题;(此功能比较实用)
  • The following features are added in view of SA objects:
    在查看服务区目标里添加下列各项特征;
  •        - reading a selected group of Sys Files into folder via ATA and terminal;
  •          用ATA和终端读一个选择的服务区系统文件组到文件夹里;
           - output report of Sys Files list including the file ID and coordinate in SA, that allows to identify the damaged Sys File
  • 服务区系统文件清单,包括文件编号和坐标的输出报告,即允许查出损坏的系统文件(数据恢复很实用!)
  • Improved BootCode initialization function;
  • 改良引导代码安装功能;
  • Improved automatic determing LBA 0 shift for drives with Media Cache and ability of manual positioning with fixing the entered value;
  • 为了硬盘驱动器转换,改良自动测试LBA0, 用媒体缓存和手工定位能力来修复输入的值;
  • Now data from ROM can be loaded in the following ways:
  • 现在从ROM中的数据可以通过以下方式被加载
           - via ATA;
  •          通过ATA;
           - via Boot Code;
  •          通过引导代码;
           - via terminal by System Files interface;
  •           由服务区系统文件表面通过终端;
           - from file.
  •          从文件.
  • Added SA setting scanner. It scans the following settings:
  • 添加硬盘服务区设置扫描器.它能扫描下面的设置;(数据恢复非常实用)
           - module table;
             模块表;
  •        - 0 and 3 partition file table;
  •          0和3分区文件表;
           - some additional parameters used to work with HDD ID in RAM.
  •          一些附加的参数使用在硬盘缓存里,用硬盘身份信息去工作(数据恢复比较实用)
  • The scanner is also included in the operating mode with ROM that allows to diagnose and work with freezing drives and not getting ready drives:
    这个扫描器同样包括, 硬盘驱动器冻结和驱动器不能准备好,在这个操作模式里用ROM 允许去诊断和工作;(数据恢复较实用)
  •        - Added HDD ID editor in RAM in the "Utility actions for Data Extractor" mode;
  •          数据提取模式在实用的操作菜单里已经添加,在缓存里面编辑硬盘身份信息;(数据恢复非常有用)
  •        - In operation with ROM patches are included. they disable freezing with "No Host FisReadyStatusFlags" messages, freezing with LED CC problem when it is impossible to work with 35 module of SMART at translator regeneration ("Init SMART Fail");
  •          在操作ROM补丁都包括在内。他们禁用冻结“No Host FisReadyStatusFlags”讯息..     冻结LED CC 问题时,它是不可能工作 用SMART 的35号模块重建翻译器.(像“初始化SMART故障”); (数据恢复比较实用)
  • Added defect list editors:
  • 添加缺陷表编辑
           - Non Resident G-List;
  •          非常驻G表
           - P-List;
  •          G表
           - Non Resident Primary DST List.
  •          非常驻主要的DST表
  • Modified algorithm of utility state dialogue work;
  • 改进算法的实用程序状态对话工作;
  • Added ID editor in RAM.
  • 在硬盘缓存添加硬盘身份信息编辑
Samsung
  • Fixed bug of changing the serial number on Mango drives;
  • Mango硬盘驱动器改变序列号问题已修复
  • Works are carried out to eliminate errors in the determination of some drives with USB interface;
  • 工程进行了测定一些驱动器,以消除带USB接口的错误,
  • Added MP4 2.5" drives family.
  • 添加MP4 2.5硬盘家族.
Toshiba
  • Added reading mode restoration at time-out error in task with using active utility in Data Extractor.
    新增读模式恢复任务超时错误,使用数据提取DE中的活跃的实用程序active utility
Data Extractor
  • Added new alternative and more compact version of map for tasks with "create copy" tasks. Selecting is performed during task creation (old "Binary file" format). "Default" value can be set in "Settings" menu in Data Extractor Task Manager. In the new format of storage map we have added fields of redundancy, which allow to recover map if key metadata is damaged. Recovery mechanism is implemented.
  • Added buttons of quick control of reading with the head map (they appear at the right panel, after building head map);
  • In the task form we have added a shortcut button for getting access to the main windows (the window associated with the task of utility, PC-3000 and DE managers);
  • Added interruption of the process of copy creation at "Work only with a copy" option;
  • Added automatic re-building of map after reading operation;
  • Implemented control the availability of recursive references for file systems and the correct response to them when saving files and directories or building map for them;
  • "Raw recovery" mode
           - significantly increased speed of execution through the use of multi-threading and optimization of the preliminary analysis mechanism;
           - added search and analysis of VMFS structures and directories;
           - added method of creating VMFS virtual partition launched from the relevant structures;
           - added analysis of ReiserFS tree blocks;
  • "Fast disk analysis" mode
           - significantly increased the speed of execution through the use of multi-threading;
           - added the ability to cancel usage of this mode;
           - fixed bug which allegedly caused that some users could not start the mode properly.
  • "GREP search" mode
           - Significantly increased speed of the search through the use of multi-threading.
  • NTFS file system
           - "Partition analysis" and "Search NTFS structure" modes: modified algorithm of "binding" with using information of Extend's. In previous version (in some very rare cases) there was not enough of RAM.
           - Changes in the procedure of saving compressed file. Now incorrectly unwrapped block is filled by $00 pattern, but saving is not interrupted. The corresponding message is written in log.
           - fixed bug of incorrectly builded map of compressed file (saving was performed correctly);
           - added Volume report for NTFS partitions;
           - added "Map of file $Bitmap" menu item;
           - fixed bug in the mechanism of building map for some files of large partitions (it used to appear for 12 Tb partition).
           - modified analysis mechanism of multiple attributes $30 in "MFT table scan" mode. Previously, if there were links to several directories, only one remained.
           - significantly increased rate of the first stage (search of structures) of "Partition data analysis" mode for NTFS partitions;
           - Removed excess output in log line with the name of saved compressed file.
  • Ext4 file system
           - implemented an optional accounting of "block group flags" at building maps of used/unused space, metadata maps and partition data analysis;
           - amended analysis of directory due to existence of versions of operation system with mismatch of flags "Inode" and directory storage form;
           - fixed situation, when u nder certain errors in the metadata file system structure, interrupted analysis of directory was interrupted for Native file system;
           - fixed bug in the analysis of dx_ catalogs consisting of several EXTEND's;
           - fixed bug in the implementation of the 48-bit addressing. It appears for 64 Tb partition size.
  • FAT file system
           - added opportunity to perform partition data analysis with an external file as FAT table.
  • VMFS file system
           - added support of file system (native).
  • ReiserFS file system
           - improved mode of adding a virtual partition in the quick analysis of drive and in raw recovery mode (it has become more "intelligent");
           - fixed bug of determining capacity of added virtual partition;
           - added "Partition analysis" method.
  • exFAT file system
           - in determining the type of file system for slot type $07 we have added the control of the probable copy of exFAT Boot partition.
           - fixed bug, previously statistics when making copies at multiple passes was not changed;
           - fixed bug of wrong head map processing for imaging in backward direction;
           - fixed bug of calculation of statistics for the map (the missing chains - sparsed etc. were taken into account);
           - fixed bug when the serial number of SAS devices was not displayed;
           - fixed a rarely occurred bug that caused overflow of the message queue (Out-of-quota message) and "leak" of memory;
           - fixed bug of "capturing" two extra sectors under certain conditions, at reading back with "jump" at the loss of "ready"-status or errors of reading;
           - modified GPT analysis (previously it used to be interrupted at the first "empty" slot);
           - fixed bug of GPT analysis for sector different from 512 bytes.
PC-3000 kernel software
  • The works to unify the PC-3000 software kernel to work with different hardware platforms. This enables to develop and install the same software on all existing controllers: high-speed PC-3000 Express, optimal PC-3000 UDMA and mobile PC-3000 Portable.
Mounting disks in the system
  • For users of PC-3000 Express and PC-3000 Portable we have developed a driver for mounting drives to OS connected via controller ports. The driver works under Windows 7, 8.
Device driver
  • For PC-3000 Express and PC-3000 Portable we have developed a new driver that allows you to work under Windows 7, 8, x86, x64.
Defects editor
  • added "Select similar defects" and "Inflate defects" commands.
专业数据恢复
    2014-3-10 08:36:58
    发表于 2013-8-21 08:46:29 |只看该作者
    不错啊又更新了,主要针对st的
    2014-11-13 08:53:39
  • 签到天数: 32 天
    发表于 2013-8-21 08:50:25 |只看该作者
    升级了
    武汉天浩数据
    2018-7-14 10:40:31
  • 签到天数: 333 天
    发表于 2013-8-21 09:06:41 |只看该作者
    支持支持,赶紧打款升级,呵呵
    发表于 2013-8-21 09:34:10 |只看该作者
    终于升级了
    2023-4-9 12:13:33
  • 签到天数: 34 天
    发表于 2013-8-21 13:08:57 |只看该作者
    升级一定要升级
    2024-10-19 10:48:25
  • 签到天数: 66 天
    发表于 2013-8-21 16:27:19 |只看该作者
    杠杠的
    发表于 2013-8-22 07:48:24 |只看该作者
    安装包从那下载
    难过
    2014-2-22 13:50:59
  • 签到天数: 127 天
    发表于 2013-8-22 12:55:21 |只看该作者
    升级看看
    难过
    2016-12-19 15:23:08
  • 签到天数: 52 天
    发表于 2013-8-23 23:29:36 |只看该作者
    好像没有更新日立硬盘呀!
    GMT+8, 2026-9-10 01:37 , Processed in 0.103451 second(s), 14 queries .
