查看: 15600|回复: 11
Seagate 7200.12 strange problem [复制链接]
发表于 2011-10-14 11:15:31 |只看该作者 |倒序浏览
in terminal command
Tech Key...
Error starting command  "En Tech"  (Drive is not ready)
专业数据恢复
    2014-3-10 08:36:58
    发表于 2011-10-22 15:50:11 |只看该作者
    现在新盘。12这样的问题比较多啊
    发表于 2011-11-14 10:12:23 |只看该作者
    All HP** Firmwares have disabled terminal access. To reach terminal on these drives you have to download another firmware update from Seagate website and update the drive.
    To make the drive reach readinnes you must unscrew the logic board, connect cables, switch on power supply and wait for hard drive readinnes. Then, put the logic board back to drive and launch firmware update.
    To make the process safer, you could also unsolder the ROM chip and read its dump from a programmer device, then solder it back to logic board.
    2014-1-15 17:00:22
    发表于 2011-11-14 19:12:42 |只看该作者
    遇到好几个了
    发表于 2011-11-19 10:42:04 |只看该作者
    你那样操作,后来硬盘还正常识别了没有呀?不要让我们猜
    2016-4-12 15:38:37
    发表于 2011-11-19 11:15:59 |只看该作者
    这个功能是专门解决:LED:00000000CC 报错的 能修复大部分这种故障的希捷7200.11 7200.12的硬盘
    上面的是要短接电路板(PC3000-UDMA的正版说明书里详细的短路点位图)
    下面的是要按提示,隔离电机
    北京军达成数据恢复培训部
    手机 15011029138
    QQ 1297101924
    发表于 2011-11-19 14:15:42 |只看该作者
    All HP** Firmwares have disabled terminal access. To reach terminal on these drives you have to down ...[/quote]
    Thanks a lot
    专业数据恢复
    2014-3-10 08:36:58
    发表于 2012-8-5 11:57:56 |只看该作者
    这样的盘多数是磁头有问题了,最近才发现
    2015-5-4 11:53:42
    发表于 2012-8-6 18:42:15 |只看该作者
    看看,需要呀
    难过
    2014-3-5 09:40:45
    发表于 2012-10-26 23:11:26 |只看该作者
    看看,需要呀
    GMT+8, 2026-8-26 19:18 , Processed in 0.106839 second(s), 16 queries .
