查看: 5653|回复: 2
新版本PC-3000 Flash 6.2.1 [复制链接]
发表于 2013-5-4 22:00:46 |只看该作者 |倒序浏览
PC3000FLASH SSD  升级版本6.2.1
没过一年升级有效期内的用户免费升级.超过一年免费升级有效期的用户可以付费升级
升级流程:
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=4050
New version of PC-3000 Flash SSD Edition (v. 6.2.1) software is available.
This version contains the following innovations and additions:
    这个版本包含以下内容的创新和补充:
  • New multi-threading mode for fast ECC autodetection and correction, which allows to increase speed of ECC correction 4-8 times in comparison with PC-3000 Flash SSD Edition 6.2; *
    新的多线程模式快速ECC自动侦测和修正,与PC-3000闪存SSD版6.2相比这允许ECC校正速度增加4-8倍;
  • New multi-threading mode for data analysis during GREP search; *
    在grep命令搜索期间用新的多线程模式做数据分析;
  • Significant improvement of ECC type autodetection;
  显著改善ECC自动类型发现;
  • Readout mode has been significantly improved and optimized for better speed performance;
    读出模式已明显改善和优化以获得更好的高速性能;
  • New "hardware retries" feature has been added to read and readout modes. It will allow to increase the quality of reading results for some types of "problem" memory chips;
    新的“硬件重试”功能已被添加到读和读出模式。它将允许增加某些类型的“问题”内存芯片的读取结果的质量;
  • New button has been added on toolbar which enables to perform fast and practical switching between opened task in Kernel and Active Utility window. This new feature will be useful during SSD recovery process.
  • 在工具栏上已添加新的按钮,打开任务在核心模式和活跃的实用程序之间可以进行快速和实用的开关。在SSD恢复过程中这个新功能将是有益的。
  • Bug fix in Samsung utility. Previously, this utility contained the bug which sometimes caused problems at launching Samsung Active Utility.
    修理三星实用程序,在以前,这个实用程序包含故障,在开始三星实用程序有时引起问题。
* New algorithm requires powerful hardware PC configuration, which should include 2- or better 4-core CPU (Hyper Threading is not effective, algorithm uses physical CPU cores, not virtual), and at least 4 Gb of RAM. In this case new features will be the most effective and will help to spend much less time during ECC correction or GREP search. Please, don't forget that new features will load your CPU at 100% (all PC resources will be focus on your Flash task).
*新算法需要强大的硬件的PC配置,其中应包括2 - 或4核CPU(超线程并不是有效,算法使用物理CPU核心,而不是虚拟的),至少有4 GB的内存。在这种情况下,新的功能将是最有效的,将花费少得多的时间在ECC校正或grep搜索。请不要忘记,新的功能将加载你的CPU在100%(所有PC资源将集中于您的Flash任务)。
We recommend to use Intel Core i5 2xxx/3xxx or AMD FX 8xxx processors.
我们推荐去使用Intel Core I5 2xxx/3xxx or AMDFX 8XXX 处理器。
PC-3000FLASH 装机推荐配置看这里
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=3899
发表于 2013-5-5 16:14:16 |只看该作者
终于抢到沙发了。。。。
    发表于 2013-5-5 16:43:31 |只看该作者
    真的不错噢,功能越来越厉害了哦
    GMT+8, 2026-9-10 02:25 , Processed in 0.097314 second(s), 12 queries .
