- 专业度
- 10059
- 元宝
- 114243
- 金钱
- 9999
- 最后登录
- 2026-9-8
- 注册时间
- 2011-7-19
- 精华
- 6
- 积分
- 145076
- 阅读权限
- 200
- 帖子
- 686
该用户从未签到 - 金钱
- 9999
- 元宝
- 114243
- 专业度
- 10059
PC3000FLASH SSD 升级版本6.2
没过一年升级有效期内的用户免费升级.超过一年免费升级有效期的用户可以付费升级
升级流程:
http://www.jundacheng.com/bbs/forum.php?mod=viewthread&tid=4050
Update for PC-3000 Flash SSD Edition, Ver. 6.2 is released!
- New “Readout” mode for NAND memory chips which has a huge count of bit errors;
- 新的读出模式为了闪存芯片位错误有大的计算.
- New Active Utilities for SSD drive based on Samsung MLC and native Intel controllers with hardware encryption (Intel 320, Intel X-25);
- 新的有效的实用程序为了SSD硬盘基于三星MLC芯片和native Intel 控制器用硬件加密(Intel 320, Intel X-25);
- New features in Indilinx and Marwell Active Utilities;
- 新的特征在主控 Indilinx 和 Marwell 可用的实用程序;
- New types of ECC, memory chips and XOR patterns;
- 新ECC校正类型,内存芯片和XOR 异或运算模式;
- Significant improvements and new options for most of data preparation modes;
- 重大的改进和新的选项为了更多的数据准备模式;
- New opportunity to get updates faster;
- 新的机会去获得快速的更新;
- Improvements and optimization of analysis algorithms;
- 分析算法的优化和改进;
- More
Progress in NAND technology is so fast, that solutions efficient earlier can be not so useful now. PC-3000 Flash SSD Edition exists already for many years and we recommend all PC-3000 Flash users to work on the latest version as only the latest version gives you the full functionality of the product you already have. From our side we work hard on adding the most important features and improving the existing modes to give you more chances to recover data from the current cases from your customers. 在闪存技术的研究进展是如此之快,有效的早期的解决方案,可现在不是那么有用。PC-3000闪存SSD版本已经存在了很多年,我们推荐所有的PC-3000 Flash用户只是用最新版本,你已经拥有的产品,最新的版本为你提供的全部功能。从我们的方面,我们努力工作添加更多重要的功能和改进现有的模式,从你的客户的当前案例,给你更多的机会来恢复数据。
PC-3000 Flash SSD Edition, New version 6.2
“Readout” mode for NAND memory chips which have a huge count of bit errors.
Modern flash chips have more complicated architecture than previous generations. It contain cells which has been produced with the help of the latest technical process and they have denser structure than before. Using TLC architecture, manufacturers can produced cheaper NAND flash chips and increase its capacity. The other side of this way is significant deterioration of quality of NAND flash structures and cells. It also influences on wear level and make it worse than in common Single- or Double level cells. In such cases, the power of ECC and active verification mode is not enough for fixing the most part of errors, and new Readout mode will help to compare the power of ECC codes and multiple readout of each page in NAND flash. It means that readout will be preformed at the same time, when software tries to performed ECC correction. This mode is very effective and it will help to get the best result of NAND chips.
现代的闪存芯片比前几代更复杂的架构。它包含与最新的技术工艺的帮助下产生的单元,这些单元有致密结构超过之前的。使用TLC的架构,制造商可以生产更便宜的NAND闪存芯片,并提高其容量。这种方式的另一面是NAND闪存结构和单元质量的显着恶化。它也影响耐久性标准,使情况变得更糟比常见的单层或双层单元。在这种情况下,ECC和起作用的校验模式是不足够的用于修理大部分的错误,新的读出模式将有助于比较ECC代码和多个读出的NAND闪存中的每个页面的能力。这意味着,读出将被预先在相同的时间,当软件试图执行ECC纠正。这种模式是非常有效的,这将有助于获得闪存芯片的最好结果.
This mode could be performed using the map and allow to read data only from those pages which have failed ECC correction.
这种模式下,能够执行使用地图和允许读取数据只能从那些有ECC修正失败的页。
Readout mode could be launched from the “Map” menu on any preparation result.
读出模式能启动从这个地图菜单在任何准备结果.
