查看: 19534|回复: 13
New version for PC-3000 UDMA 5.2.3 and Data Extractor Ver. 4.8.18 [复制链接]
发表于 2013-1-12 19:23:28 |只看该作者 |倒序浏览
PC3000UDMA+DE  最新版本和升级流程:
安装程序下载地址:
https://skydrive.live.com/?cid=b777795a80c58e25#cid=B777795A80C58E25&id=B777795A80C58E25%21574
Seagate F3
  • Possibility of HDD family detection has been added into utility.
  • 发现硬盘家族添加到实用程序.
  • Flash ROM writing has been added.
  • 添加写硬盘FLASH ROM (硬盘闪存)
  • Family code is displayed in SAP Control Flags editor while editing in RAM and ROM.
  • 家族代码显示在SAP(伺服适配参数)控制编辑寄存器而编辑在RAM(随机存储)和ROM(只读存储).
  • Possibility of work with multi-block QNR firmware has been added into “Work with flash ROM image file” menu.
  • 可能的工作用多重的块 QNR 固件有添加到 “Work with flash ROM image file” (工作用在FLASH ROM映像文件)菜单.
  • WWN and HDD capacity fields have been added in HDD ID editor in “Work with flash ROM image file” menu.
  • WWN和硬盘容量字段有添加在 HDD ID editor(硬盘身份编辑)  (工作用在FLASH ROM映像文件)菜单.
  • Detection of heads that physically present in HDA and filtration of modules of heads test that absent in HDA have been added.
  • 检测物理那磁头在HDA(盘体)和磁头测试的模块过滤,没有在HDA(盘体)已添加的模块。
  • Possibility of filtration of modules known now as not critical has been added into “Modules reading” and “SA backup” (during SA backup this function is enabled automatically).
  • 现在并不重要的模块过滤的可能性已经添加到“Modules reading“(模块读)”和“SA backup(服务区备份)”(在服务区备份期间这个功能是允许自动的).
  • Switcher of Media Cache use for work with user area has been added into HDD ID editor.
  • 开关媒体缓存使用为了工作和用户区有添加到HDD ID EDIT(硬盘身份编辑)
  • Media cache presence detection on HDD surface and User Data Offset detection have been added into utility. They are taken into account during head map building and reading from active utility in Data Extractor.
  • 实用工具已添加媒体缓存的存在对硬盘表面检测和用户数据的偏差检测。考虑在磁头地图建立和 reading from active utility in Data Extractor. 读从活跃的实用程序在数据提取.
  • Possibility of moving both all adaptive data (RAP+CAP+SAP+IAP) and part of it that responsible for donor heads compatibility has been added into function of adaptive data transplanting from one ROM dump to other. It helps to read faster and more stable on compatible donor heads.
  • 可能移动二者全部的磁头适配数据(RAP+CAP+SAP+IAP)和它的一部分那负责为了,配件盘磁头兼容性,有添加移植数据适配功能,从一个ROM转储文件到
  • 另外的.它帮助快速的和更稳定的读数据用兼容的配件磁头.
  • “Utility actions for Data Extractor” have been added into Seagate F3 utility:
           - turn power off/on;
           - regenerate translator with P-list;
           - clear Format Corrupt flag;
           - send Soft Reset.
    “Utility actions for Data Extractor” 实用程序做用为了数据提取有添加到希捷F3实用程序
                 电源关闭/打开;
                 用P表重建编译器;
                 清除格式损坏的标记;
                 传送软复位;
  • Possibility of reading modules and system files by sectors has been added into “HDD resources view and edit”. It may be useful when it is necessary to read corrupted translator module.
  • 可能的读模块和系统文件由扇区有添加到 “HDD resources view and edit”. (硬盘资源查看和编辑)。它可能是有用的,就在那个时侯它是去读损坏的编译器模块。
  • Command to clear Format Corrupt flag has been added into “Service commands” menu.
       命令去清除格式标记有添加到“Service commands” (服务命令)菜单。
  • Dialogue of sending commands of Set Features group has been added (“Service commands” menu):
           - write cache (enable/disable);
           - read look-ahead (enable/disable);
           - APM (enable + set level/disable);
           - AAM (enable + set level/disable);
           - Power-Up In standby (enable/spinup/disable).
        传送命令会话的设置特征组有添加“Service commands” 服务命令菜单。
                写高速缓存(允许/失效)
                预先读(允许/失效)
                高级电源管理(允许+设置标准/失效)
                自动降噪模式 (允许+设置标准/失效)
                在待命电源升高(允许/主轴电机起转/失效)
  • Update Microcode mode 3 has been added, it is necessary for block loading of loader file with big size (“Service commands” menu).
    更新微码模式3有添加,它是必须的为了块装入的LDR文件 用大的尺寸。
  • RAM read-write in "Boot Code" mode (in "View and edit HDD resources") has been added.
       随即存储器读写在引导代码模式("View and edit HDD resources"查看和编辑硬盘资源) 有添加。
  • ROM reading in "Boot Code" mode (in "View and edit HDD resources", "Work with ROM") has been added.
       只读存储器读在引导代码模式("View and edit HDD resources"查看和编辑硬盘资源,"Work with ROM"工作在只读存储器)有添加。
Samsung
  • New families MT2 and N3 has been added.
       新的家族 MT2 和N3 有添加。
  • Terminal access to service area of N2B family has been added.
    终端访问到服务区的N2B家族有添加。
Toshiba
  • New family MQ01ABD has been added.
    新的家族MQ01ABD有添加。
  • Memory usage has been optimized in virtual translator building.
       在虚拟编译器建立里内存使用有是优化的。
  • Defect reassign mode has been improved for hard disk drives with large sector size (>512bytes).
    缺陷再分配模式有是改进的为了硬盘驱动器用大扇区大小(大于512字节)。、
  • ID edit mode has been improved.
    硬盘身份编辑模式有改进的。
  • Technological reading mode has been improved, new option for reading drives with corrupted G-list is added.
    技术读模式有改进,新的选项为了读驱动器用损坏的G表是添加的。
  • Read/write SA modes have been improved (number of unread sectors is greatly decreased).
    读写服务区模式有改进的(未读扇区的数量大大减少)
WD Marvell
  • New families Diablo3D, Tahoe XL, Tressels have been added.
    新的家族 Diablo3D,Tahoe XL,Tressels 有添加。
  • "View and edit HDD resources" mode error has been fixed (Index -1 out of bounds).
       查看和编辑硬盘资源错误有修理(索引-1超出范围)
  • Old mode "Edit head map in RAM" has been removed.
    老的模式 编辑磁头地图在随机存储器有添加
  • "Modules search in SA" function has been improved, now it is possible to search modules in saved tracks/regions and save data to image.
    模块搜索在服务区功能有改进,现在它是可能的去搜索模块在保存的磁道/区域和保存数据到映像
Maxtor
  • Auto recovery mode error has been fixed.
    有修理自动恢复模式错误
Hitachi-IBM-ARM
  • Head map building algorithm in Data Extractor has been improved as a result speed is greatly increased.
    磁头地图建立运算法测在数据提取里有改进在一个结果速度是大大的增加
  • Password unlock algorithm has been improved.
    口令解锁运算法则有改进
  • ID Edit mode has been added (SN, WWN, FW version, Max LBA, Auto reassign flag).
    硬盘身份编辑模式有添加(SN, WWN, FW version, Max LBA, Auto reassign flag).
    Decoding of data from modules FEAT, IDNT, WWNM has been added into SA structure test report.
       数据的解码从模块FEAT,IDNT,WWNM有添加到服务区状态测式报告
Data Extractor
数据提取器
NEW FORENSIC FEATURES!!!
    新的法院特征
  • MD5 and SHA1 check sum control for the image, file, chain of sectors in map has been added.
    MD5和SHA1校验和控制为了这个映像,文件 ,在地图里扇区的链有添加
  • New mode for exporting list of folders and files into CSV file with filter, hash control (MD5/SHA1), read/unread sectors control has been introduced.
    新的模式用过滤器为了输出文件夹的目录和文件到CSV文件,有控制(MD5/SHA1), 已读/未读扇区控制引入
NTFS:
  • New implementation of "Partition analysis", "Scan unused space", "NTFS structure search".
    新的实现的 分区分析,扫描未使用空间,NTFS结构搜索
  • Error for >2Tb partitions in MFT record editor has been fixed.
    错误 为了大于 2TB分区在MFT记录编辑有改进
  • Error for used/unused space map building has been fixed.
    错误为了已用的/未用的空间地图建立有改进
HFS+:
  • New implementation of scan methods (Catalog File, partition, used/unused space).
    新的扫描方法 实现(Catalog File, partition, used/unused space).
    Hardlink support has been added (hardlink is copied and initial file is opened).
    硬的链接支择有添加(硬链接是复制和初始文件 是开放的)
  • Error bug with additional extends has been fixed.
    错误故障用外部附加的有修理
  • Interpreting error in Apple Partition MAP for sectors different from 512 bytes has been fixed.
    解释错误在苹果分区地图为了不同的扇区从512字节有添加
  • Error bug with Building map of used space for HDD with sector size more than 512 byte has been fixed.
    错误故障用建立使用空间的地图为了硬盘用扇区尺寸超过512字节有添加
  • Error bug with adding a huge virtual partition from “Disc Analysis” has been fixed (wrong partition size had been set before).
    错误故障用添加一个具大的虚拟分区从 磁盘分析 有修理的(之前已经设置了错误的分区大小)
FAT:
  • For deleted files and folders long name is used without check sum (short name was used before).
    对于已删除的文件和文件夹长名称不使用校验和(简称之前使用)。
  • Error bug with building map of used/unused partition space has been corrected (last chain was ignored before).
    建立地图的使用/未使用的分区空间已被校正错误的BUG(之前最后链被忽略)。
EXT2(3,4):
  • While building map of used/unused partition space bitmap sector accounting has been added (for that ones which were not read or read with error).
    建立已使用的地图/未使用的分区空间位图扇区数量地图,为了那无法读取或读取错误。
RAW Recovery:
  • Possibility of file types/structures grouping by categories has been added.
  • Error with adding new reference to Raw Recovery Reference Book has been fixed.
  • Specified test criteria for some file types has been improved.
  • Error bug with wrong check size of .tiff files has been fixed.
  • Error with Raw Recovery reference book import has been fixed.
  • Added new ability that allows to import/export contents from/to internal/external file in Raw Recovery Reference Book.
  • New ability of raw recovery result exportation to .csv file.
  • Ability of import/export content from/in internal/external file has been added in “GREP” reference book.
  • At opened task additional identification data control has been added for standard connected drives.
  • Ability to show standard connected drives used right now in the list of sources has been added.
  • The control of used drives, ATA ports and opened tasks has been changed (now used drives/ports are not shown in the list or shown with “attention” icon).
  • The timeout for standard connected drives has been increased (previous timeout was insufficient to exit from sleep mode for modern “GREEN” HDD).
  • Map ”jumping” during tabs switching has been fixed.
  • New statistic item has been added in task form main menu (for cases with making a copy).
  • Bug of skipping sectors during image creation has been fixed (this bug was more often during backward data copy).
  • Bug with sector reading interruption in sector edit that could led interruption of running process has been fixed.
  • Form of task name input has been changed.
  • File size filter has been increased from 1 Kb to 1 byte.
  • Power management in object map mode has been added.
  • New ability of saving bad files into special sub-folder has been added (all paths will be stored).
  • The dialog box of saving bad files has been removed. Now such files will be saved automatically with their own unique information. This message will be shown in the log.
  • In context log menu new file open item has been added (you should select required block and tap on it).
发表于 2013-1-12 20:30:38 |只看该作者
我们什么时候可以升级啊
发表于 2013-1-13 00:04:35 |只看该作者
jinmuma 发表于 2013-1-12 20:30
我们什么时候可以升级啊
15号以后
    2014-3-3 09:33:56
  • 签到天数: 213 天
    发表于 2013-1-13 10:06:05 |只看该作者
    15号以后[/quote]
    USB的什么时候升级啊
    发表于 2013-1-13 11:27:59 |只看该作者
    升级好,升级需要银子呀
    武汉天浩数据
    2018-7-14 10:40:31
  • 签到天数: 333 天
    发表于 2013-1-13 11:45:26 |只看该作者
    我11号收到ACE升级的邮件,
    又要花钱了,呵呵
    XXXXXXXXXXXXXXXXXXX
    发表于 2013-1-13 19:12:20 |只看该作者
    周二可以升级了
    发表于 2013-1-13 19:12:46 |只看该作者
    装个SEVER 2012试试
    发表于 2013-1-14 12:58:42 |只看该作者
    新年的开始,也希望升级后给我们大家带来好运,带来惊喜
    2018-8-13 17:27:11
    发表于 2013-1-18 15:13:58 |只看该作者
    大家一起加油呀。。。。。。。。。
    GMT+8, 2026-9-10 07:26 , Processed in 0.099613 second(s), 13 queries .
