查看: 12979|回复: 2
PC-3000 for SCSI and Data Extractor SCSI Ver. 5.0.1 升级 [复制链接]
发表于 2011-9-19 18:50:52 |只看该作者 |倒序浏览
PC3000SCSI 5.01 升级信息英文中文对照
PC-3000 for SCSI and Data Extractor SCSI Ver. 5.0.1.new!   2011年9月9日
To enable proper working in Windows 7, mechanism of accessing disks has been changed. One more access method – SPTI has been added. Now, in utility settings you can choose access method between ASPI and SPTI without restarting your PC-3000 SCSI system
Utility interface has new improvements in the way they are done in PC-3000 UDMA system
Utility for working with Hitachi GST HDD has been added
We have revised utility codes, modified algorithms of CP and module reading/writing because SPTI has been added
Now you can start Seagate utility using module tables and CP by default, and also resources from profile or database
Fujitsu utility has changes with CP's and modules methods of reading and writing
允许工作在WINDOWS 7 ,磁盘访问机制已改变,更好的访问方法-SPTI 有添加,现在,在实用程序设置你能选择访问方法在ASPI 和SPTI 之间 不需要重新启动你的PC-3000 SCSI 系统。
实用程序界面有改进,它们稳定的工作在PC-3000 UDMA 系统。
实用程序工作在 HITACHI GST 硬盘 有添加支持。
我们有修正实用程序代码,修正的读写模块和CP (配置页)的运算法则,因为SPTI 有添加。
现在你能开始 希捷实用程序使用模块表和CP由默认的,同样加载资源固件从文件夹和数据库。
Fujitsu( 富士通)实用程序有改变的用读和写模块方法和配置页。
    发表于 2011-9-24 09:32:28 |只看该作者
    看来功能又增强了呀
    发表于 2012-12-28 15:55:39 |只看该作者
    支持支持
    GMT+8, 2026-9-10 01:38 , Processed in 0.100580 second(s), 14 queries .
