查看: 20841|回复: 13
Barracuda Green ST2000DL003寻道不认盘,LED:000000BD FAddr:00007C14报错 [复制链接]
    2014-7-28 12:56:32
    发表于 2012-8-16 22:04:22 |只看该作者 |倒序浏览
    如题:Barracuda Green ST2000DL003寻道不认盘,LED:000000BD FAddr:00007C14报错!那们高手可以指点下!完整报错信息如下
    Rst 0x40M
    MC Internal LPC Process
    (P) SATA Reset
    User Data Base  009920F0
    MCMainPOR: Start:
    Check MCMT Version: Current
    MCMainPOR: Non-Init Case
    MC Seg Disc and Cache Nodes:  4011A624  40118734
    Seg Write Preamble VBM start: 000010A7 end: 000010CE
      Footer - start: 000010D0 end: 000010F7
    Seg Read Preamble VBM - start: 000010F9 end: 00001120
      Footer - start: 00001122 end: 00001149
    Reconstruction: MCMT Reconstruction Start
      Max number of MC segments 22E0
    Nonvolatile MCMT sequence number 00002BA7
    [RSRS] 1FB6
    ProcessRWError -Read-   at LBA 0011578F  Sense Code=40000087
    InitiateMarkPendingReallocateRequest for disc_lba: 0011578F!
    Reconstruction: EXCEPTION: Seg Read Fail: Status = 0000
    Continuing after error
    ReadFooters (Forward): Segment 1FB6 StartLBA 008ABC40 Starting Footer LBA 008ABE48
      SeqNum 00002BA8  TotalUserBlocks 01C2
      Footer Status = 0001
    Reconstruction: EXCEPTION: Segment Overall Sequence Number Mismatch, No Valid Footer  00002BA8 FFFFFFFF
    Reconstruction: ProcessIncompletelyWrittenSegment
    Adds  LBA/Len
      005E002F/0008  005E0047/0008  005F71FF/0010  00600037/0008  0060E93F/0008  0060E9E7/0008  34D1398F/0008  3767B12F/0008  3A472687/0080  3A478207/0001  3A478487/0001  3A478707/0001  3A478987/0001  3A478C07/0001  3A478E87/0001  3A479000/002F  3A479D87/0001  3A479F00/000F  3A479F0F/0001  3A47A207/0001  3A47A487/0001  3A47A707/0001  3A47A987/0001  3A47AC07/0001  3A47AE87/0001  3A47D007/0001  3A47D287/0001  3A47D507/0001  3A47D787/0001  3A47DA07/0001  3A47DC87/0001  3A47DF07/0001  3A47E187/0001  3A47E407/0001  3A47E687/0001  3A47E907/0001  3A47EB87/0001  3A47EE07/0001  3A47F087/0080  3A47FF87/0001  3A480100/0007  3A480107/0001  3A481D87/0001  3A482007/0001  3A482287/0001  3A482507/0001  3A482787/0001  3A482A07/0001  3A482C87/0001  3A482F07/0001  3A483187/0001  3A483300/0007  3A487657/0001  3A4878D7/0001  3A487B57/0001  3A487DD7/0001  3A488057/0001  3A4882D7/0001  3A488557/0001  3A4887D7/0001
      Add Count 0000003C
    Rems  LBA/Len
      0060E9E7/0008
    Remove 0000 LBA 0060E9E7 End 0060E9EF
        Add 0000 LBA 005E002F End 005E0037
        Add 0001 LBA 005E0047 End 005E004F
        Add 0002 LBA 005F71FF End 005F720F
        Add 0003 LBA 00600037 End 0060003F
        Add 0004 LBA 0060E93F End 0060E947
        Add 0005 LBA 0060E9E7 End 0060E9EF
    Reconstruction: ProcInCmptSeg: OverlapDetected: With previous Add/Rem
    Reconstruction: Last Chance
    Rst 0x40M
    2015-12-2 18:51:12
  • 签到天数: 41 天
    发表于 2012-8-18 10:50:24 |只看该作者
    关注,正在研究这个问题
    发表于 2012-8-20 13:32:08 |只看该作者
    关注关注关注
    2021-4-24 05:15:25
  • 签到天数: 224 天
    发表于 2012-10-6 04:13:22 |只看该作者
    同问~~~
    关注
    2013-7-13 09:59:08
    发表于 2012-10-12 00:39:03 |只看该作者
    关注关注关注[/quote]
    VECOTOR
    不会看错吧
    发表于 2013-3-5 13:49:41 |只看该作者
    短接试一下
    2015-3-17 13:06:35
    发表于 2013-3-12 17:17:25 |只看该作者
    短接哪两点呢?
    专业数据恢复
    2014-3-10 08:36:58
    发表于 2013-3-17 08:58:25 |只看该作者
    看一下,现在好多这样的问题
    2021-3-10 11:45:24
  • 签到天数: 14 天
    发表于 2013-3-19 20:11:34 |只看该作者
    看一下,我也遇到过.
    2017-5-19 10:38:16
  • 签到天数: 41 天
    发表于 2013-5-30 15:23:55 |只看该作者
    我也遇到过.
    GMT+8, 2026-8-26 19:16 , Processed in 0.100696 second(s), 12 queries .
