查看: 11028|回复: 7
Hot news! PC-3000 Portable, version 1.5.1 [复制链接]
发表于 2012-8-8 11:01:55 |只看该作者 |倒序浏览
Hot news! PC-3000 Portable, version 1.5.118th of July 2012WD Marvell
  • New HDD families have been added into support list: SADLE 2D, MZTGP, Draco;
  • New SA access mode by ABA in ABA/CHS translation mode has been added for ROYL drives;
  • New selection feature (by ID/by ABA) has been added for all SA module checking modes;
  • Control of hidden defects in SA according to the module 30 has been added.
Seagate F3
  • Descriptions for DR (Drive Tables, “before – CP”) and service modules have been added;
  • Utility menu structure has been changed;
  • Added support for defect hide cmd Rev 3;
  • Fixed error of outputting DT description in protocol, during reading in profile and DB.
Seagate Classic (Baracuda)
  • New HDD families have been added into support list: LD25.1(MLite), LD25.2(Mustang);
  • Terminal speed control feature is available from utility menu.
Samsung
  • New HDD families have been added into support list: МН80, M8E, N1 1.8;
  • Before you choose family, terminal tab is activated at the background which enables to monitor drive start log without initializing the utility;
  • New attention log about untypical LBA size during utility launching has been added;
  • New feature of auto switching micro program in test mode during ROM reading/writing problems (via terminal);
  • New “View ROM dump info” test has been added for following HDD families: VOYAGER11+, VICTOR, PUMA, VICTORPLUS, VERNA, VERNALITE, VANGO, VANGOPLUS, PANGO, VELOCE, PALO, Poseidon, DELPHI, Caesar, P80M, Trident, T166, Storm2, Trident3, MAGMA, M40S, M60, M80, MANGO, M5P1, PARAGON, M6, MT1;
  • The ability of heads selection has been added in SA structure test;
  • New option of errors ignoring during composite reading has been added in “Reading Modules” test;
  • «Platform Id get error» has been fixed. This error can occur during Trinity drive ROM analysis (disassembling);
  • “Unknown tech key” error has been fixed. This error can occur when you press “skip” button at reading service track test.
Toshiba
  • New HDD families have been added into support list: 34GAL, 56GSY, 59GSXP, 61GSY, 64GSY, 65GSX.
HITACHI-IBM-ARM
  • New special utility has been added for Hitachi HDD based on ARM architecture.
PC-3000 Kernel
  • Output buffering added in terminal (prevents program crash during large data transfer at high speed in terminal);
  • Mechanism of mutual exclusion for access to PC-3000 Portable adapter has been seriously improved. During commands execution, new technique of power control has been added.
Data Extractor
  • Added feature to export RAW recovery result into .CSV file;
  • Raw Recovery mode algorithm has been improved. Execution speed increased by 20-30%;
  • In Raw Recovery result, new ”Comment” field has been added. There you will find the most typical information for current result, which enables to see difference in list-view results (for example: distinguish between the different partitions of superblocks);
  • In log context menu, new option “open as LBA” has been added. It allows selecting numeric value, and immediately open sector editor for it;
  • The algorithm of forming a new name for the duplicate file when you save with the "rename" has been changed and improved;
  • Disk Analysis mode has been improved
    - New file systems have been added into support list: UFS1/UFS2, ReiserFS;
    - Implemented creation of virtual FAT16 and FAT32 partitions even in case when BOOT or/and FAT Tables are lost;
    - Implemented correct addition of virtual XFS, ExtX, UFS1/UFS2 partitions even iwhen the first superblock has been damaged;
    - Added single automatically launching method when MBR, GPT, APM are lost or damaged.
  • New File systems have been added into support list: EXT4, XFS, ReiserFS;
  • NTFS File System: Partition data analysis method has been added;
  • FAT File System: Partition data analysis method has been added;
  • UFS2, UFS3 File Systems: Partition data analysis method has been added;
  • In Raw Recovery mode, searching for service structures has been added for the following file systems: exFAT, HFS+, XFS, ExtX, UFS1/UFS2, ReiserFS.
    2014-2-6 10:09:10
    发表于 2012-8-24 22:59:01 |只看该作者
    什么时候放出来啊,我们在一年的,怎么升级啊
    发表于 2012-8-25 19:53:05 |只看该作者
    可以下载从你们的FTP
    2014-2-6 10:09:10
    发表于 2012-8-31 10:45:33 |只看该作者
    张总,我的FTP 有时间,帮我问一下啊,现在里面还没有新程序啊,
    发表于 2012-9-20 20:31:29 |只看该作者
    现在已经有了
    头像被屏蔽
    2013-7-13 09:59:08
    发表于 2012-10-11 21:36:11 |只看该作者
    提示: 该帖被管理员或版主屏蔽
    发表于 2012-12-28 15:43:02 |只看该作者
    学习一下..
    发表于 2013-4-26 09:38:16 |只看该作者
    现在升级什么版本了
    GMT+8, 2026-9-10 02:25 , Processed in 0.103647 second(s), 14 queries .
