- 专业度
- 10059
- 元宝
- 114221
- 金钱
- 9999
- 最后登录
- 2026-8-13
- 注册时间
- 2011-7-19
- 精华
- 6
- 积分
- 145054
- 阅读权限
- 200
- 帖子
- 686
该用户从未签到 - 金钱
- 9999
- 元宝
- 114221
- 专业度
- 10059
数据恢复,恢复数据
PC3000UDMA 新功能-改变RAM 磁头地图-日志
Selected family......................... : Barracuda 7200.9 Tonka2
Selected model.......................... : ST3802110A
Model by ID............................. : ST380811AS
Detection of HDD COM port baud rate..... : 9600
Test : HDD initialization with head map changing in RAM
Initializing Safe Mode...
Switching HDD power supply OFF
Switching HDD power supply ON
COM transfer baud rate set to 921000
Test : Saving LDR from HDD
HDD profile file......... : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.9 Tonka2\ST380811AS-3-AAE-6PS42QGN\Data\HDDInit\SgLDR_App.ldr
Will be stored........... : App
App code reading...
HDD SpinUp.............................. : Ok
Reading boot SA elements...
Result.................................. : Ok
Detecting App code parameters...
Detecting App code parameters........... : Ok
App cylinder............................ : 0x16322
App length.............................. : 0x238
App buffer.............................. : 0x60
Terminal : detecting SA bounds...
Detection of SA bounds by MUX
SA bounds identified
App code reading........................ : Ok
ROM image reading...
Test : HDD initialization by utility...
Switch HDD PWR supply.... : No
Terminal Reset........... : No
Terminal work speed...... : 921000
Used LDR................. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.9 Tonka2\ST380811AS-3-AAE-6PS42QGN\Data\HDDInit\SgLDR_App.ldr
Loaded from.............. : C:\Program Files\ACE Lab\PC-3000\Bin\!Profiles\SeagateBara\Barracuda 7200.9 Tonka2\ST380811AS-3-AAE-6PS42QGN\Data\HDDInit\SgLDR_Utl.ldr
Work with HDD through.... : ATA
App...................... : Loading from LDR
Used modifications....... : Fix 'Pending Bug', Fix 'Pending Bug' (fix 2), Fix 'Not Handled Soft Path' Bug, Fix 'Failed sys sect. write', Alow ATA LBA->PCHS conversion, Fix 'Ovl 1 not loaded' problem, Block saving Alt-list, Block saving System Sectors, Blo
Load Ovl 0............... : No
Loading App Loader...
App patching...
Downloading App code...
App code downloading.................... : Ok
Reading boot adaptives.................. : Ok
Reading Reserve track defect list....... : Ok
Starting App code...
cmd 2A, params 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000 0000
P)SATA Reset
cmd 58, params
Starting App code....................... : Ok
