- 专业度
- 10059
- 元宝
- 114243
- 金钱
- 9999
- 最后登录
- 2026-9-8
- 注册时间
- 2011-7-19
- 精华
- 6
- 积分
- 145076
- 阅读权限
- 200
- 帖子
- 686
该用户从未签到 - 金钱
- 9999
- 元宝
- 114243
- 专业度
- 10059
General changes in the software complex PC-3000Flash SSD Edition
A. Starting with version 6.0.1, software hardware and software PC-3000Flash SSD Edition includes two parts:
a set of specialized tools to work with some types of SSD in the technological regime;
nucleus of PC-3000Flash, including data recovery tools directly from the dump of the memory chips store.
A set of specialized tools in this version of the complex is an optional component. Its presence in the installed software in a system defined by the presence of one of the following products ACE: PC-3000 UDMA, PC-3000 Portable. In this case, the specialized tools of the complex PC-3000Flash SSD Edition will work with the drive connected to SATA port the corresponding controller. In the absence of a system of any of the above devices, the composition of complex software is a standard similar to previous versions.
If the system contains more of these devices, when the program starts, a dialog box to choose the device you want to work.
Not need to work through the regular SATA ports of the motherboard due to the specific process conditions and the need to eliminate the possible influence of the operating system.
For all technical issues associated with the new organization of the program and the characteristics of her work, please contact our technical support department of the product.
Two. Update FW readers.
Version 6.0.1 on the first run on-demand updates the FW reader FlashReader. It is recommended not to give up this update. This update includes support for chips with software Chip Enable, and correction of errors in reading the identifier.
Changes in the making
In the "system solutions" added a new mode of "most probable solution."
Allows you to take the most likely sequence of operations to restore a specific task, based on statistics on such cases. Due to the fact that when you restore the same type of controllers, similar operations are performed that are specific to the controller, this mode is very effective when working on new tasks.
Mode is available after applying the filter, and called on the link above the list of found solutions. Feature of the regime that even in the absence in the 'solutions' would fit the criteria for selection problems, this mode will be available and will provide recommendations for restoration.
If you switch to this mode the following items:
Complete coincidence - the formation of the most likely solution will be implemented based on the tasks, all under the appropriate search parameters.
These memory chips - to form the most likely solution will take into account not only completely appropriate for your search tasks and tasks that use chips with parameters identical to the original problem.
The overlap - to form the most likely solution will take into account not only fully fit the parameters of the search problem, but the problem with the controller, which is marked overlap with the given parameters in the search.
The overlap of these chips + - simultaneous consideration of the conditions described in paragraphs 2 and 3.
When you select a specific item in addition to the actual sequence of actions for the recovery task, there will be comments and recommendations for restoration, the application of these methods, and ways to improve the result.
Feature of the regime in that each newly added solution immediately involved in the analysis, which increases the probability of correctness of the proposed mode of this solution to your particular problem.
Changes in the core of the complex
A. Background analysis of reading the memory chips.
The background analysis during reading was significantly reworked in order to correct errors. He also became optional. By default, when you start reading the memory chips, the flag "background analysis" is not installed. This mode is not recommended for use on platforms with a single nucleus, as this may lead to a significant slowdown in the process of reading. In the case of more productive systems, it is recommended to use this mode to assess the problem and obtain information about possible recovery features already finished reading the chip. Enable / Disable background analysis is possible from the dialog box select the settings read.
Two. The new mode of research "Isolation of XOR».
In carrying out this mode as a result of the screen will list the probability of matching XOR patterns prisutctvuyuschih in the base complex, the task at hand. At the same time in the task directory will be created a special file format. In the absence of complex XOR pattern is needed to restore the current task, you must send the generated file to address those. Support to obtain the desired XOR and connect it to the complex. After the addition of a centralized XOR, all users can get an updated resource base, using the built-in set of synchronization service resources.
Three. Added support for chips with software CE (chip enable).
To read data circuits with self-add them to the base of the complex is necessary to choose the type of reading "Type 9 (READ PAGE EXT)». And the extra point. parameters, including: the initial value of CE, the final value of CE, a step change in CE, read the rules for each CE.
4.
For circuits with multiple parts (used in several CE), set automatically reading the ID on all CE, thereby determining the number of parts in the memory chip. In the previous version of the software in case of error or an incorrect reading of ID for the next CE process is stopped. The new version adds a special flag that allows you to continue reading the IDs of all the CE, even if an error occurs. This option allows you to correctly identify the chip with an error when reading the ID of one of the parts. The flag is available in the dialog box "Read ID memory chips."
Five.
If the utility is started the complex, which supports the direct process of reading, when you create a task PC-3000Flash SSD Edition in the list of devices to create an additional problem will drive connected to one port of the above products «ACE». A task created on the basis of active utilities, as a whole is identical to the problem of PC-3000Flash, except for the following features.
when creating a task ID chips and their number will be obtained automatically from the utility;
If the utility implements direct treatment process of reading, you can not read dump chips in the files, and to work "directly" connected to the drive. Ability to count chips and a standard problem «PC-3000Flash» well preserved. Select the type of reading done in the dialog box "Reading memory chips";
If the utility implements the reading of the logic (ie, LBA), then create a task PC-3000Flash based on the active tool, the tree will present the results of another node, which is a logical way to restore the data storage device that allows you to store data without having to perform Operations on the analysis of the contents of the memory chips.
Changes to the complex set of tools
Universal utility.
Provides a general functional, versatile for all types of SSD, as described in the specification ATAPI. Among the features - Work with subsystem password function read sector, write sector, SMART, etc.
Utility Marvell.88SS9174-BKK2
Supported Drives:
- Intel 510 Series
The possibility of obtaining User / Master password.
Implemented the password reset feature.
The mode of the direct process of reading pages of memory chips.
The mode of reading chip IDs via the drive.
Ability to read dump files into memory chips.
Ability to read the logic. That is, utility, using the necessary data collected from the drive itself is a machine translation and allows direct sector-based access to user data.
Utility Indilinx.Barefoot.
Supported Drives:
- Corsair Extreme Series
- Crucial M225
- OCZ Solid 2
- OCZ Vertex
Implemented interactive mode of direct technological reading pages of memory chips.
