查看: 7883|回复: 2
PC-3000 SCSI 4.2升级 [复制链接]
    发表于 2011-7-21 17:30:49 |只看该作者 |倒序浏览
    [/td][tr]
    It has many new useful features and improvements for recovering data from SCSI/SAS drives:
    Seagate
    • Cheetah 15K.7, Barracuda ES.2, Constellation, Constellation ES drive families have been added.
    • SA Structure test now has SA Modules checksum verification.
    • Modules reading is now available for SCSI drives.
    • Cheetah 15K.3 translator regeneration error has been fixed.
    • Problem with getting incomplete serial number for some drives has been fixed.
    • Methods for new families autodetection have been updated.
    • SA Structure test algorithm have been updated.
    • S.M.A.R.T. reset is now available for SAS drives.
    Fujitsu
    • "S.M.A.R.T. Reset" test is now available
    • TechnoOn and TechnoOff commands are now available within utility status window.
    Universal utility
    • Error with Format test has been fixed.
    Data Extractor
    • Now there is no "Process aborted" error that occurred when task data has been written to network storage with its active usage by several processes.
    • Memory leak that happened when files were saved with Explorer mode has been fixed.
    • FAT16 Translator: Wrong shift points problem, that occurred when FAT tables were analyzed and translator was regenerated has been fixed.
    • Translator recovery text field LBA is available for input. Now it is possible to set the value manually.
    • There is no problem of saving catalogues with forbidden symbol '/' in the name (relevant to HFS+).
    • HFS+ indexes have been added. They speed up results processing.
    • Files with the size more than 2 Gb could not appear in Explorer in some cases. This bug has been fixed.
    • We have solved the problem when the last symbol of file or catalogue name was "." (relevat to HFS+).
    • Pattern used to fill the empty sectors is now saved not in task but globally in Data Extractor software.
    • Ext2(3): filesystem incomplete directories listing error has been fixed.
    • Error that caused crash when Data Extractor took actions on UFS1 filesystem has been fixed.
    • HFS+: data disassembler at Catalog-file analysis have been improved.
    Kernel
    • Log sense display error has been fixed.
    Installation setup
    • Uninstallation error "Install.log not found" error has been fixed.
    • Now all PC-3000 products are compatible. Deletion of one PC-3000 (UDMA, Portable, SCSI) tool won't disturb the work of all other PC-3000 tools.
    • Problem that happened when the software was installed to non-default folder has been fixed.
    专业数据恢复
    2014-3-10 08:36:58
    发表于 2011-7-22 14:23:26 |只看该作者
    没有这个软件,用的太少了
    石家庄七星数据恢复中心     卡号  000177
    发表于 2011-8-27 20:33:29 |只看该作者
    用到时真的是很有用呢,不错呀
    GMT+8, 2026-9-10 07:23 , Processed in 0.186550 second(s), 13 queries .
