查看: 3878|回复: 0
【CF】SM223TF [复制链接]
发表于 2012-6-27 09:14:41 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM223TF
Number of memory chips :  4
Memory chip ID :  0xECD755B6
Capacity(Mb) :  32768
Variant 1 Author: datalife [2]
Initial memory chips (4)
Parts of memory chips (8)
04152637
Change order (New order 0,4,1,5,2,6,3,7)
Marker Pos515
Block Size8192
ID3412
GMT+8, 2026-8-26 19:15 , Processed in 0.098271 second(s), 13 queries .
