查看: 3777|回复: 0
【CF】SM2232T AD [复制链接]
发表于 2012-6-27 10:47:34 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM2232T AD (решение не для этого контроллера)
Number of parts :  4
Memory chip marking :  29F16808JAMD2
Memory chip ID :  0x89D7943E
Capacity(Mb) :  32768
Variant 1 Author: Alexey_2763 [1]
Parts of memory chips (8)
Page XOR transformation (ID_XOR 42)
Block Number Type 9 [0x4001]
Even BlocksYes
GMT+8, 2026-8-26 19:15 , Processed in 0.101326 second(s), 13 queries .
