查看: 10200|回复: 3
希捷硬盘 7200.11 解密 [复制链接]
发表于 2012-3-17 20:12:53 |只看该作者 |倒序浏览
数据恢复,恢复数据。
希捷硬盘 7200.11 解密
进入程序后,选择 Reset password。即可自动完成解密。(需要注意必须连接终端,选择通过终端解密。)如下图。
ATTENTION! Security-locked HDD.
Tech Key...
Error starting command  "En Tech"  (ABR)
Detecting Phys Sct Size...
Result.................................. : Error
Test  : Reset password
HDD power supply switching OFF/ON...
Found passwords:
Master:
  Text: SeaGate.........................
  Hex : 53 65 61 47 61 74 65 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E 2E
User  :
  Text: 11111111111111111111111111111111
  Hex : 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31 31
Checking...
Unlocking...
Unlocked!
Collecting Sys Files Infos...
  ID        Len
   0          4  Reserved Defect Table (SA defect table)
   1          2  Drive Information File (DIF)
   2         16  Performance Parameter File (PPF)
   3       3787  Primary Defect File (P-List))
   4         12  Servo Adaptive Parameter File (SAP)
   5          4  Manufacturing Information File (MIF)
   6         66  Read Adaptive Parameters File (RAP)
   7          1  Controller Adaptive Parameters File (CAP)
   8       4800
   9          1  SMART Configuration File
   A       2251  SMART Data File
   B       1000
   C      64000  Serial Port Test Results File (Self Scan Log)
   D        160
   E        432  Data Integrity Check (DIC), HEAD 0
   F        223  DIC Dummy File
  13          8  Disc Registry File (settings, security, etc)
  15        100  BGMS File (Directed Offline Scan)
  16          2
  17         40
  19         24  Log File
  1A         33  Log File
  1B          1  Log File
  1C          9
  1D        128  Physical Overlay File 0
  1E        128  Physical Overlay File 1
  1F        640  Physical Overlay File 2
  22         80  Drive Self Test (DST), Head 0
  23         80  Drive Self Test (DST), Head 1
  2A          9  Saved Mode Pages (HDD settings)
  2B        928  R/W Operating Parameters (translator, etc)
  2C        432  Data Integrity Check (DIC), HEAD 1
  33       4576
  34        640  Packed CONGEN XML definition
  35         26  SMART Data
Collecting Sys File Infos completed
Collecting DT Infos...
ROM:
  ID     MemOffs        Len
   0     6020100      33792  Read Adaptive Parameters File (RAP)
   1     6020000        256  Controller Adaptive Parameters File (CAP)
   4     4001000       4096  Servo Adaptive Parameter File (SAP)
         602BE00       4096
              total    8192
   5       6C000      81920  Servo Firmware Table
   8    10070000        948
   A     60A4D54       1024  Seek Profile
  12    100D4000        104
  13     60B00C4        544  Dependent Zone Table for User Area
  14     60B02E4         64  Dependent Zone Table for System Area
  15           0     524288  Flash ROM
  1B     60AF3EC       3288  Dependent Zone Group Tables for User Area
  1C     60AF2AC        320  Dependent Zone Group Tables for System Area
  1D     6020120        208  VBAR Configuration File
  1E     6020310       2320  Zone Format Parameters File
RAM:
  ID     MemOffs        Len
   2     60201F0        288  Zone Table
         602BE00       4096
              total    8192
   6      203044      40996  Servo Flaw Table
   8    10070000        948
  12    100D4000        104
  16     6020100         32  Drive Configuration Table
  17     6021F20       1744  Temperature Control Configuration
  1F     6144684       1224  RW working user preamp table
  20     6144B4C         72  RW working system preamp table
Collecting DT Infos completed
HDD is not security locked!
提示解锁成功。
    发表于 2012-3-18 22:12:28 |只看该作者
    现在的功能的却很好了
    2014-3-3 09:33:56
  • 签到天数: 213 天
    发表于 2012-3-20 14:58:34 |只看该作者
    现在的功能的却很好了
    2017-4-16 21:14:09
  • 签到天数: 174 天
    发表于 2013-6-2 14:42:43 |只看该作者
    好好的学学啊我是低手
    GMT+8, 2026-9-10 02:54 , Processed in 0.109216 second(s), 17 queries .
