查看: 11021|回复: 7
WD5000BMVW砍头 [复制链接]
发表于 2012-3-12 14:22:17 |只看该作者 |倒序浏览
硬盘信息:
Model : WDC WD5000BMVW-11AMCS0
Serial : WD-WXG1EC0PUV65
Firmware : 01.01A01
Capacity : 465.76 GB (976 773 168)
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 4
Cyl Count............................... : 256
Zone allocation table................... : Ok
SA SPT.................................. : 1098
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 09.0UA
ROM generation.......................... : 09.0UA
Link table version...................... : 02.0L.
Consolidated ROM version................ : 0009000U
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
SA regions address...................... : by default
Heads configuration..................... : by map
Heads number in use..................... : 4
Switched off heads...................... : No
Heads map............................... : 0,1,2,3
ROM Firmware version.................... : 0009000U
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : Copy 0,Copy 1
Configuration reading................... : Ok
Master Password......................... : has not been set
User Password........................... : has not been set
Victoria检测结果:遇到坏道的时候硬盘灯的状态有问题
Vic_test
UDMA检测磁头的结果:
HD3_Err
发现3头损坏,需要砍掉。
    2014-2-22 13:44:11
    发表于 2012-3-16 16:04:22 |只看该作者
    就是啊!怎么弄呢哪位大哥能说一下呢?
    2014-2-22 13:44:11
    发表于 2012-3-16 16:04:28 |只看该作者
    就是啊!怎么弄呢哪位大哥能说一下呢?
    2014-2-22 13:44:11
    发表于 2012-3-16 16:04:52 |只看该作者
    就是啊!怎么弄呢哪位大哥能说一下呢?
    发表于 2012-3-16 18:00:47 |只看该作者
    呵呵呵,的却很厉害呀
    发表于 2012-3-20 14:05:38 |只看该作者
    把案例发上来,等答案的
    2015-5-4 11:53:42
    发表于 2012-3-23 15:44:35 |只看该作者
    以前的盘,
    1步,手工停用译码表
    2步,关磁头
    3步,编辑P表,把关掉的磁头在P表里面的缺陷删掉,
    4步,改LBA值
    5步,重建译码表,
    6步,FORMAT 全盘,OK搞定
    但现在的盘一关头就会敲的,不知道哪个模块要改过来,哪位大侠会?
    发表于 2023-7-27 10:53:05 |只看该作者
    学习了,感谢分享。
    GMT+8, 2026-7-26 18:05 , Processed in 0.111012 second(s), 15 queries .
