查看: 15723|回复: 12
PC3000FLASH SSD 已升级 5.08 [复制链接]
发表于 2012-2-28 22:16:26 |只看该作者 |倒序浏览
中国正式用户可以在一年有效免费升级期内下载软件,从你们独立的FTP帐号。
On-line resource synchronization
New option for PC-3000 Flash resources online synchronization is available. To perform synchronization you should choose “Database Update” in online service menu. Your PC should have Internet connection.
If the new version of software is available in the server, PC-3000 Flash SSD Edition will download it. If your database is the latest one, you will see following message: "The latest database version is already installed."
It is recommended to check PC-3000 Flash SSD Edition for database updates at least twice a week.
PC-3000 Flash SSD Edition resources include:
Flash chips information;
Reading parameters for flash chips;
XOR patterns for the pages;
Power configurations for flash chip reading;
ECC configurations;
Adding your own ECC format combinations
Now you can make your own ECC format combination.
You should launched “Page designer” on preparation result and select the range of SA which contains ECC. Then, you should select your new ranges and pushing the “SHIFT” key, select “ADD ECC” operation. After that, new ECC combination will be added into database.
3 分钟前 上传
下载附件 (68.47 KB)
For current example: on the page with 4320 byte size posted 4 ranges by 1070 bytes (512+512 DA + 46 ECC) and one range with page marker.
You can use this mode, for example, when dump is read with the size less than necessary and you can't reread it. In this case ECC area for the last diapason is not full. To solve it, you can create your own ECC describer, that eliminates the last diapason. It will help to correct errors in good ones.
To make added format become detected, it is necessary to do “ECC autodetection” once again.
If you meet ECC format that is in PC-3000 Flash database, please e-mail our Technical Support
[url=mailto:%20ts2@acelab.ru]ts2@acelab.ru[/url] and describe this format. We will add it into PC-3000 Flash database.
If you meet unsupported ECC format, please contact our Technical Support
[url=mailto:%20ts2@acelab.ru]ts2@acelab.ru[/url] and we will inform you what to do to add new ECC into PC-3000 Flash as soon as possible.
Analysis method for controllers
New controller algorithm for SSD SM2244G (SSD RunCore) has been added. It includes autodetection for preparation results, special XOR and ECC.
Available new opportunity for saving and applying solutions based on Data Analysis method.
Added new preparation methods:
Separation by bank. In case when two banks have its own parts of the blocks (for example, the first one have only even blocks, and second one has only odd blocks), this preparation help to build all blocks in right order (one by one);
Joining by byte for N parts (useful for case which is contain 4 or more parts, and use double joining by bytes);
In «channel synchronization» group, new type of synchronization «by markers» has been added. It will allow you to synchronize a couple of case results, based on markers coincidence by specified offsets.
New option for searching translator algorithm by the controller name
To make easier the choice of specialized algorithms, new option for searching translator algorithm by the controller name has been added.
1 分钟前 上传
下载附件 (53.64 KB)
11 秒前 上传
下载附件 (60.35 KB)
In this example only those algorithms which have “PS” in their name are remained.
New XOR combinations have been added.
    发表于 2012-2-28 22:28:29 |只看该作者
    功能又增
    强了呀,
    2017-2-9 15:01:11
    发表于 2012-2-28 22:48:34 |只看该作者
    没增多少
    武汉天浩数据
    2018-7-14 10:40:31
  • 签到天数: 333 天
    发表于 2012-2-29 09:12:17 |只看该作者
    好东西,想整一套呀,呵呵
    XXXXXXXXXXXXXXXXXXX
    2017-7-2 11:51:48
    发表于 2012-2-29 10:32:09 |只看该作者
    好东西呀..
    发表于 2012-2-29 11:55:28 |只看该作者
    蓝网科技 发表于 2012-2-28 22:48
    没增多少
    功能增加很多,有很多有用的XOR 。
    2017-2-28 10:54:44
  • 签到天数: 7 天
    发表于 2012-2-29 13:53:57 |只看该作者
    好东西呀..
    发表于 2012-2-29 17:07:38 |只看该作者
    看看
    发表于 2012-4-2 20:51:40 |只看该作者
    支持下 增加了好多功能
    2013-6-24 23:43:39
    发表于 2012-5-29 17:02:34 |只看该作者
    貌似功能是增强了许多了!!
    GMT+8, 2026-7-26 22:55 , Processed in 0.104702 second(s), 12 queries .
