查看: 3556|回复: 0
【CF】SM223TF AC H28182 0810 S8T [复制链接]
发表于 2011-12-21 13:55:50 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM223TF AC H28182 0810 S8T
Memory chip ID :  0xECD514B6
Variant 1 Author: chekanoff [4]
Block Number Type 2 [SM32xx]
Use Add-insNo
Full blocksNo
GMT+8, 2026-8-26 23:45 , Processed in 0.202587 second(s), 14 queries .
