查看: 3270|回复: 0
【CF】SM2234H AB H56756 [复制链接]
发表于 2011-12-21 11:19:28 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM2234H AB H56756
Number of memory chips :  4
Memory chip marking :  JS29F32G08ACMD1
Memory chip ID :  0x89680446
Capacity(Mb) :  16384
Variant 1 Author: majedawad [3]
Initial memory chips (4)
1032
Change order (New order 1,0,3,2)
Split by block (Block Size 8192)
Marker Pos513
Block Size16384
Page size 17280
Sector size 520
0-512;2048-8;
512-512;2048-8;
1024-512;2048-8;
1536-512;2048-8;
2160-512;2048-8;
2672-512;2048-8;
3184-512;2048-8;
3696-512;2048-8;
4312-512;2048-8;
4824-512;2048-8;
5336-512;2048-8;
5848-512;2048-8;
6464-512;2048-8;
6976-512;2048-8;
7488-512;2048-8;
8000-512;2048-8;
8616-512;2048-8;
9128-512;2048-8;
9640-512;2048-8;
10152-512;2048-8;
10768-512;2048-8;
11280-512;2048-8;
11792-512;2048-8;
12304-512;2048-8;
12920-512;2048-8;
13432-512;2048-8;
13944-512;2048-8;
14456-512;2048-8;
15072-512;2048-8;
15584-512;2048-8;
16096-512;2048-8;
16608-512;2048-8;
GMT+8, 2026-8-26 19:21 , Processed in 0.095046 second(s), 13 queries .
