查看: 3027|回复: 0
【CF】SM223TF [复制链接]
发表于 2011-12-21 11:19:27 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM223TF
Number of memory chips :  4
Memory chip ID :  0xECD755B6
Capacity(Mb) :  32768
Variant 1 Author: datalife [2]
Initial memory chips (4)
Parts of memory chips (8)
04152637
Change order (New order 0,4,1,5,2,6,3,7)
Marker Pos515
Block Size8192
ID3412
GMT+8, 2026-8-26 23:40 , Processed in 0.097300 second(s), 13 queries .
