查看: 3624|回复: 0
【CF】SM223TF AC [复制链接]
发表于 2011-12-21 13:55:42 |只看该作者 |倒序浏览
Flash device type :  CF
Controller marking :  SM223TF AC
Number of memory chips :  4
Memory chip ID :  0xECD755B6
Capacity(Mb) :  16384
Variant 1 Author: dataok [8]
Initial memory chips (4)
Block Number Type 2 [SM32xx]
Block Size8192
Use Add-insNo
Full blocksNo
GMT+8, 2026-8-26 23:40 , Processed in 0.098291 second(s), 13 queries .
