查看: 3271|回复: 0
【MMC】Glued PCB DV69C K80217 Vincent SA IN368B [复制链接]
发表于 2011-12-21 11:19:21 |只看该作者 |倒序浏览
Flash device type :  MMC
Controller marking :  Glued PCB DV69C K80217 Vincent SA IN368B
Memory chip marking :  MT29F16G08MAA
Memory chip ID :  0x2CD5943E
Variant 1 Author: KuttingEdge [137]
Mask0x00FF
ID3412
Full BlockYES
Page size 4304
Sector size 539
0-512;512-27;
539-512;1051-27;
1078-512;1590-27;
1617-512;2129-27;
2156-512;2668-27;
2695-512;3207-27;
3234-512;3746-27;
3773-512;4285-19;0-8;
GMT+8, 2026-8-26 23:40 , Processed in 0.106889 second(s), 13 queries .
