查看: 4705|回复: 0
【MS】D3469GA 550Y28V [复制链接]
发表于 2011-12-21 13:16:27 |只看该作者 |倒序浏览
Flash device type :  MS
Controller marking :  D3469GA 550Y28V
Memory chip marking :  TC58NVG3D4CTGI0
Memory chip ID :  0x98D385A5
Capacity(Mb) :  1024
Variant 1 Author: GreyDKang [146]
Split by dump (Dump number 4)
0234
Change order (New order 0,2,3,4)
Split by dump (Dump number 2)
Special action (description in comment)
Split by block (Block Size 246784)
Join by block for pairs (Block Size 987136)
Translator Type 3 [Memory Stick]
Bytes alternationNo
GMT+8, 2026-8-26 20:54 , Processed in 0.105824 second(s), 13 queries .
