查看: 4165|回复: 0
【SD】Glued PCB SDC805 [复制链接]
发表于 2011-12-21 13:55:22 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC805
Memory chip marking :  MT29F16G08MAA
Memory chip ID :  0x2CD5943E
Variant 1 Author: Karol [217]
Block Rotate (Block Size 4096,Marker Pos 512,Id 12 34,Mask 0x0FF0,Small Block 16)
Full BlockYES
#||#Variant 2 Author: Karol [217]
Translator Type 35 [Phison PS800x]
Page size 4320
Sector size 538
0-512;512-26;
538-512;1050-26;
1076-512;1588-26;
1614-512;2126-26;
2152-512;2664-26;
2690-512;3202-26;
3228-512;3740-26;
3766-512;4278-26;#||#Page size 4320
Sector size 538
0-512;512-26;
538-512;1050-26;
1076-512;1588-26;
1614-512;2126-26;
2152-512;2664-26;
2690-512;3202-26;
3228-512;3740-26;
3766-512;4278-26;
GMT+8, 2026-8-26 19:15 , Processed in 0.099999 second(s), 13 queries .
