查看: 4005|回复: 0
【SD】Glued PCB SDC805DAG1-M1 [复制链接]
发表于 2011-12-21 10:39:56 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC805DAG1-M1
Memory chip marking :  TC58NVG4D1DTG00
Memory chip ID :  0x98D594BA
Variant 1 Author: KuttingEdge [137]
Split by dump (Dump number 2)
Block Rotate (Block Size 0,Marker Pos 0,Id 1234,Mask 0x0000,Small Block 0)
Page size 4304
Sector size 538
0-512;512-26;
538-512;1050-26;
1076-512;1588-26;
1614-512;2126-26;
2152-512;2664-26;
2690-512;3202-26;
3228-512;3740-26;
3766-512;4278-26;
GMT+8, 2026-7-12 17:25 , Processed in 0.102525 second(s), 13 queries .
