查看: 3168|回复: 0
【SD】IN368B GLUED SD (INTENSO) [复制链接]
发表于 2011-12-21 11:19:00 |只看该作者 |倒序浏览
Controller marking :  IN368B GLUED SD (INTENSO)
Memory chip ID :  0xECD514B6
Variant 1 Author: KuttingEdge [137]
Translator Type 38 [InCOMM IN368B/IN369CC-G]
GMT+8, 2026-7-12 18:12 , Processed in 0.103162 second(s), 13 queries .
