查看: 3061|回复: 0
【SD】Glued PCB IN369CC SA IN368B [复制链接]
发表于 2011-12-21 10:39:55 |只看该作者 |倒序浏览
Controller marking :  Glued PCB IN369CC SA IN368B
Memory chip ID :  0x89D5943E
Variant 1 Author: mr.flash [10]
Translator Type 38 [InCOMM IN368B/IN369CC-G]
Page size 4304
Sector size 539
0-512;512-27;
539-512;1051-27;
1078-512;1590-27;
1617-512;2129-27;
2156-512;2668-27;
2695-512;3207-27;
3234-512;3746-27;
3773-512;4285-19;
GMT+8, 2026-8-26 19:27 , Processed in 0.094845 second(s), 13 queries .
