查看: 3206|回复: 0
【SD】SK6612 AARC 00538 [复制链接]
发表于 2011-12-21 11:58:05 |只看该作者 |倒序浏览
Controller marking :  SK6612 AARC 00538
Memory chip marking :  HY27UG(H)084G2A
Memory chip ID :  0xADDC8015
Capacity(Mb) :  1024
Variant 1 Author: positivebit [1]
Change order (New order 1,0)
Block Size512
Mask0x03FF
Page size 4224
Sector size 538
0-512;4176-16;512-10;
522-512;4176-16;1034-10;
1044-512;4176-16;1556-10;
1566-512;4176-16;2078-10;
2088-512;4176-16;2600-10;
2610-512;4176-16;3122-10;
3132-512;4176-16;3644-10;
3654-512;4176-16;4166-10;
GMT+8, 2026-7-12 19:46 , Processed in 0.089794 second(s), 13 queries .
