查看: 4004|回复: 0
【SD】Glued PCB SA IN368B [复制链接]
发表于 2011-12-21 12:37:10 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SA IN368B
Memory chip marking :  MT29F16G08MAA
Memory chip ID :  0x2CD5943E
Variant 1 Author: it-center [1]
Change order (New order 1,0)
Translator Type 38 [InCOMM IN368B/IN369CC-G]
Page size 4320
Sector size 539
0-512;512-27;
539-512;1051-27;
1078-512;1590-27;
1617-512;2129-27;
2156-512;2668-27;
2695-512;3207-27;
3234-512;3746-27;
3773-512;4285-27;
GMT+8, 2026-8-26 23:40 , Processed in 0.105460 second(s), 13 queries .
