查看: 3271|回复: 0
【SD】Glued PCB SDC805 [复制链接]
发表于 2011-12-21 12:37:09 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC805
Memory chip marking :  HY27UA08T2MTR
Memory chip ID :  0xADD514B6
Variant 1 Author: Karol [217]
Block Rotate (Block Size 2048,Marker Pos 512,Id 12 34,Mask 0x0FF0,Small Block 16)
GMT+8, 2026-8-26 19:27 , Processed in 0.776563 second(s), 13 queries .
