查看: 4268|回复: 0
【SD】SK6602 [复制链接]
发表于 2011-12-21 13:16:14 |只看该作者 |倒序浏览
Controller marking :  SK6602
Memory chip marking :  TC58DVG14B1FT00
Memory chip ID :  0x98DA8095
Capacity(Mb) :  512
Variant 1 Author: mixa [2]
Block Size512
Mask0x03FF
Full BlockYES
Page size 4224
Sector size 538
0-512;4176-16;512-10;
522-512;4176-16;1034-10;
1044-512;4176-16;1556-10;
1566-512;4176-16;2078-10;
2088-512;4176-16;2600-10;
2610-512;4176-16;3122-10;
3132-512;4176-16;3644-10;
3654-512;4176-16;4166-10;
GMT+8, 2026-8-26 19:14 , Processed in 0.101109 second(s), 13 queries .
