查看: 4225|回复: 0
【SD】Glued PCB SDC805 [复制链接]
发表于 2011-12-21 13:16:13 |只看该作者 |倒序浏览
Controller marking :  Glued PCB SDC805
Memory chip marking :  HY27UA08T2MTR
Memory chip ID :  0xADD514B6
Variant 1 Author: Karol [217]
GMT+8, 2026-8-26 20:57 , Processed in 1.475213 second(s), 14 queries .
